Question about Sony VAIO PCG-K23 Notebook
Lcd bulb - how and where do you get and how to install
Got the solution but how/where do I get and how to put in?
    Sergeant:
    Champion:
  • 270 Answers
Here is a helpful website...
CLICK HERE
Posted on Nov 30, 2008
Hitachi pj tx 100..put in after maeket bulb...woeked great for 300 hrs then went very dark....put another bulb in no difference ??
you need a new Original lamp
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Mar 17, 2014 | Hitachi projector replacement lamps pj tx...
Red screen on E152fpc monitor
A red or pink tint on LCD monitor indicates that the CFL backlight bulbs are failing. These are just like the florescent bulbs you use at home and the office but much smaller. When they are about the fail they will have a red tint to the light instead of white. They can be replaced but on a 15" LCD its not worth the price and trouble to do it. The bulbs will run about $35 and then about 1 hour to install if you know what you are doing. It would be better for you to get a replacement monitor.
May 07, 2012 | Dell E152FP 15" Flat Panel LCD Monitor
Put in new blub and heard a zapping sound is bulb bad or tv?
Check the bulb is not damaged and is inserted fully into the socket. The bulb needs several thousand volts to ignite which would be the sparking noise you heard if not connected properly.
Mar 08, 2011 | Mitsubishi WD-52526 LCD TV
How to install lamp
Here is a link to Hitachi DIY LCD TV Bulb and Lamp Installation Guide. It shows the 50V500a and 60V500a lamp location and bulb replacement. Check your user manual for information regarding safety and bulb disposal issues.
easyab
Feb 23, 2011 | Hitachi 60V500 60" Rear Projection...
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Sony vaio desktop all in one back light not working
To fix your problem please follow the below given steps
Step1
Power on your computer and wait until there should be an image displaying on your LCD monitor. Look directly into the monitor from a distance of about 1 inch way. Cup your hands around your face to block out the light in the room and get a clearer view of the LCD screen. Check to see if there is a faint light visible in the screen, which will indicate that the cold cathode backlight has gone out, or no image at all, which will indicate a different problem.
Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb
Step3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
Step4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the back light directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
Step5
Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
Step6
Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
Step7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the back light bulb was installed correctly.
Please rate me if this solution works for you
Thanks......Have a great time.
  • Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb.
  • Step 3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
  • Step 4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the backlight directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
  • Step 5 Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
  • Step 6 Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
  • Step 7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the backlight bulb was installed correctly.
  • Read more: How to Diagnose & Repair Desktop LCD Backlight Problems | eHow.com http://www.ehow.com/how_5038642_diagnose-desktop-lcd-backlight-problems.html#ixzz0uJr4tmU8
    Jul 20, 2010 | Sony VAIO PCV-V200G PC Desktop
    Put a new projection bulb in.. whats the green
    it is very possible you did take out the bulb housing and make sure you installed the new bulb correctly inside the housing and double check the way you slide in the bulb housing slowly making sure you do not force it in then make sure you reinstall bulb cover properly also!
    techman
    May 09, 2010 | Televison & Video
    Can i purchase a bulb and put it in myself in my vizio lcd tv?
    if the part is replacable you may be able to do it, I wouldn't try it unless you were experienced with electrical proceedures.
    Jan 05, 2010 | Vizio VX42L 42 in. LCD TV
    Replcing bulb
    There is lamp cover at bottom of projector, unscrew it, take it off, you will see Lamp inside that also fixed with screw, unscrew it and take it out, place new lamp and put thing in same way.
    Jun 09, 2009 | NEC MultiSync LT280 LCD Projector
    Replaced bulb in a kdf-e42a10 and worked for about 8 hours
    3 times red light blinks shows that Lamp Cover is Open. Please put back lamp cover properly.
    I would recommend to always replace with Original Sony Lamp and avoid aftermarket or compatible lamps.
    Feb 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
    Sony VAIO PCG-K23 Notebook Logo
    48 people viewed this question
    Top Sony Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Computer Links
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
