Question about Akai PT5492S 54" Rear Projection Television
I have no green color
Is it the bulb or circuit board or no power to it
  • enzociardi Nov 17, 2008
    i might have said it wrong i have red and blue colors the green color does not light up
  • enzociardi Nov 18, 2008
    ihave opened the rear panel and saw that the red and blue bulbs were lit but not the green one
    thank you
  • 10,594 Answers
Check filament / heater connection of green gun at CRT socket mounted on board, might have cold / dry solder joints.
Posted on Nov 18, 2008
  • 4,806 Answers
The green lamp has gone in the back of the TV, just like light bulbs they only have a short life cycle
best regards
Posted on Nov 17, 2008
  • Lee Hodgson
    Lee Hodgson Nov 17, 2008
    oppps i forgot to say that you can change these yourself :)
  • Lee Hodgson
    Lee Hodgson Nov 18, 2008
    to take the green bulb out is should just unscrew, take it to a store and purchase another one, before you do that you can check that the green connection works by screwing one of the other bulbs to it, this will not damage the tv at all, if the bulb lights up then you know its the bulb and you have to replace it to get a decent picture
    kind regards
  • Akai Master
  • 19,396 Answers
If there is not power at all, not even the red led on , then test a different power outlet.
If it is not the power outlet, then it is a faulty power supply board.
  • Ginko
    Ginko Nov 17, 2008
    If the model is the same listed on title, ti should not have any green lamp.
    The fact is that the Color convergence is not working because one of the convergence ICs is faulty.
    The convergence board should be tested.
    If your model is different from the one in title, then it can be a faulty crt.
I have a mitsubishi wd 65638 . it powers up just fine then about an hour or so in it starts to slutter the colors then settles into a weird silver and grey colors setting like black and white but not
this sounds ilke the board maybe tring to go bad although i know it doe have colored bulbs but it has to be the circuit board this is what control the power distabution
Apr 09, 2014 | Mitsubishi WD-65638 65" DLP HDTV
Lost green color in picture
I would start by obtaining the service manual. It will have circuit diagrams and diagnostic procedures.
Nov 04, 2007 | Jensen TS2050J 20" TV
Why are circuit boards green?
There is a lot of debate about why circuit boards are green but the reason is because its the color of the insulating varnish that is used to to protect the board from short circuiting and the copper from corroding. It is also an indicator that your circuit board is made out of glass-epoxy whose natural color is green.
Sep 02, 2013 | Electronics - Others
Mitsubishi wd-65738 flickering
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
May 25, 2017 | Mitsubishi WD-57833 57" HDTV
On my z71 1996 model rear bake lights don't work but the third light works, could it be the brake switch ?
No, it is not the brake lamp switch. If the brake lamp switch was not working, the high mount (3rd) brake lamp would also not function.
Chevrolet trucks are notorious for bad tail lamp circuit boards.
Disconnect the electrical connector from the circuit boards. Check for power at the circuit board connector (with the brake pedal depressed) on each side. The brake/turn lamp circuit for the left side is the YELLOW wire. The brake/turn lamp circuit for the right side is the GREEN wire. If there is power at the connector, check the GROUND (BLACK wires) to make sure they are getting a good ground. If the power and ground circuits are OK at the connector, replace the circuit boards.
NOTE: DORMAN makes a kit that includes circuit boards for both sides it is DORMAN Part Number 70001
If there is no power on the YELLOW and GREEN wires at the circuit board connectors, the most likely cause would be a defective turn signal switch.
Apr 28, 2012 | 1996 Chevrolet K1500
Red light flashing screen is green turn off itself
your color wheel/ color main bored has gone bad (red flashing indictating one of 3 things depending on flashing. no power to main board. or to much power/bad board on one of the color boards) or you just need to replace the bulb in it. i doubt its a bulb issue bc you do see a greenness to it at first. but *** will auto shut down till the board is fixed. sorry for the bad news but this is your solution. . if you can tell me what model the tv is i cna find out exactly what it is and how many flashes.
Mar 19, 2011 | Sony Televison & Video
The colors are not sharp any more and they all blend in together, its either too much red or too much green or blue what can be the problem?
manual convergence should fix the problem if it does not the set most likely either has a bulb burnt out or a bulbs power / focus needs to be adjusted by taking off the panel and finding a 6 screw control panel
should look like that 3 screws in a row on top of another three screws each of thees control the power and focus of each color this is a somewhat delicate process and is a huge pain on larger tvs that you cannot completely see the picture or color while you are directly under in front of it so I had my gf come in the room and sit across to let me know which color was doing what if you dont have someone you will need to check after each adjustment
now the diagnostic
as i said each screw controls a colors power and focus the focus is used if you see an outline of a color around pictures if everyone looks like a dead jedi with a blue aura around them the blue focus needs to be adjusted and so on for each color if you skies or blue screens seem feint your blue power probably needs to be turned up and so on for each color
if through the course of this you can see the bulbs and notice one is out your probably looking at dealing with the color issue until the time you can purchase a new tv as the cost of the bulb and the technician needed to install it as they are wired to a circuit board and requires technical knowledge and tools
hope this helped
Robb
Jun 12, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Image is green color............what is wrong with the tv?
It means that the blue and/or red picture tube (bulb) is not working properly. It could be the tube(s) or the circuits that drive the tube. My money is on the circuits.
Apr 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
Green color
...try to soldering all the electronic components of the circuit board...sometimes there's a loose soldering of a electronic component...
Jul 09, 2009 | Televison & Video
Tv Problem
check the circuit board for possible loose connection,try to resolder the horizontal circuit and the crt board.
Jul 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
18 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
