Question about RCA D52W135D 52 in. TV/DVD Combo
Tv will not turn on
I have a mitsubishi projection tv model#cu5002k i beleive it is a 1991 model.I moved the tv and it played fine for a couple of days.Now when i turn it on the red power button will flash on and right back off,i mean on for just a split second.You can hear it clik on when you hit the power button but it goes right back off,no sound,no picture nothing. I would appreciate any help you could give me.I do not want to spend more than a few hundred dollars to fix this tv as it is an older model and newer tv are coming down in price
    Genius:
  • 1,030 Answers
Please confirm model and make of tv
Posted on Nov 17, 2008
  • Willie Howell Nov 18, 2008
    The model doesnt cross with mitsubishi.. this is listed under rca, then google search of the model indicates a hitachi products. Trying to pull up service manual so i can get a idea of the unit problem
  • RCA Master
  • 19,396 Answers
When this happens it means that there is an internal error and the tv is in protect mode.
The TV protection circuit detects that there is an internal problem, as a wrong voltage, a short, a capacitor that has blown or a different defectivecomponent.
After detecting the fault the TV set itself to Protect mode activating a safety switch that will prevent the TV from starting up to avoid further damage.
The safety switch that keeps turning TV off is also the clicking noise that you often hear when the TV is in this state.
If the protection circuit was wrong and there is no real problem you can fix this by leaving the TV set unplugged for a couple of hours, so to drain power completely and reset TV eeproms and protection circuit. This for example happens often after a power surge.
If that does not work, then it means that there is a real fault, in this case you will need to call a technician to test the internal parts.
I do not think you can fix this by yourself.
If you need to call service you can use the phone number listed on the owner manual.
The lamp went out in my TV. I replaced the lamp and it worked fine. I moved the TV and when I went to turn it on it wouldn't stay on. It will come on for about 10 seconds and then shut back off. The red...
Recheck all the projection lamp conections again.Still getting,the same result.Replace the projection lamp again,some how the move,it got the projection lamp shorted.
Oct 03, 2010 | Mitsubishi WD-60735 Projection Television
Picture goes out - but has sound
i have had this problem on one of my tv s all i did was remove the back of the tv and re-solder all the joints around the tuner (thats where the arieal goes) they go with time because the joints there get so hot . hope this helps
puggy
Jul 07, 2009 | Televison & Video
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Vs-60705
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility that works on rear-projection TV's should be able to repair your set. I bought the set on Jan 1, 2000. Coming up on 9 years and the set works like new.
Jul 30, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi (2001 ?) 60 inch projection TV Model VS-60609. DVDs and video games work perfectly but NO tv reception- we have Comcast. I've plugged cable into every possible hole on the TV- no luck. THX!
My mitsubishi 2001 tv model 60609 plays sometimes for a couple of minutes and then turns off; but you can still hear the volume and if you try to turn it back on it will turn right back off.
please help me!
Apr 23, 2008 | Televison & Video
RCA D52W135D 52 in. TV/DVD Combo Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
