Question about Technics SL-MC4 61-Disc CD Changer
Unit is locked
Unit got moved with discs still in it. Unit locked up and continues to display 'checking discs'. Can't open door to check status of discs.
  • tricky nicky Dec 12, 2008
    My technics SL-MC4 60+1 cd player won't open for me.  I have already removed the top of it to get the cds out that have fallen from moving it, but I still cannot get it to open on its own.  It says "checking disk" but will not allow me to open the front.  Also, when i turn the power off it will not turn back on, i have to unplug it from the power outlet and replug it in.  Please help
Take the 4 screws from the sides and the two in the top back of the unit. What has probably happened is that you have a cd laying on the bottom of the unit and the arm can not make the entire sweep. cdt
Posted on Oct 08, 2007
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
Why does the message F5E1 come up on the oven display after I auto-cleaned the oven. The oven is still locked. MOD: RF 265LXTY3, Serial #RW-1117104-X. I have a manual, but it doesn't tell anythi
The F5E1 message means that the door lock mechanism isn't working. This could be a fault at the lock, the mechanism or the wiring.
First press and hold Cancel to clear the error temporarily. Another code should appear. Press Cancel again to clear the second error. (Some models require unplugging the power cord to reset the code.)
To unlock the door, take a metal wire hanger and bend it. Slide it into the door opening and try to get the lock to move. (The lock is in the middle of the opening.) Then try to open the door. Otherwise, see below to see if you can unlock the door from the back of the unit.
You can check some of the parts by taking off the back panel and attempting to move the lock. Similarly check the motor and the cam that controls the lock. It should take a bit of force to move but not a lot.
I hope this helps.
Jan 08, 2013 | Whirlpool Kitchen Ranges
I have several problems with my Whirlpool washing machine AWO 12763: 1 .- For a long time do not make spin until we press the door. 2 .- For the past few weeks, when entering water, says suddenly we...
Hi.
F-22 is door lock error. The door lock was already defective and now has failed completely. You need to replace the door lock.
Here the error explained in detail:
F22
DOOR LOCK ERROR
Theme Door Lock message is prompted when the door cannot be locked. The CCU (central control unit) will try to lock the door six times before displaying the F 22 error code.
Possible Causes:
The door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
Repair Procedure:
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock, and the central control unit.
Regards.
Ginko
Jun 04, 2011 | Washing Machines
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue...
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a kenmore elite 3 washer...stopped with 8 mins left in cycle...try to restart but getting F DL code...cannot open washer door
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
Replace the door lock mech if the wiring is ok
Oct 11, 2009 | Kenmore Washing Machines
Ge xl44 after self clean cycle the door won't open and the display says "locked door" flashing.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Sep 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Kenmore Elite Quiet Pak 4 HE3T Washer. The door is locked with clothes in it. The displays is saying F dL. What has happened and how can we open the door.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Apr 12, 2009 | Washing Machines
Driver's side door won't open in the cold
Power Door Lock Operation (Front Doors)
The front doors do not have traditional door lock actuators. They have electronically controlled door latches that will operate depending on the status of the door lock system. This status is determined by the front door modules and the last known state of the lock system. If the last known state is LOCK, the latches will not release when the door handles are operated. If the last known state is UNLOCK, the latches will release when the door handles are operated. The front doors are also equipped with red door lock status indicators. The front door modules will supply power and ground to the indicators to illuminate them when the lock system is in a virtual state of lock. The indicators will not continuously illuminate when the vehicle is locked. They will illuminate for approximately 5 seconds after a lock switch activation or after a door handle has been operated and the front door modules are in a virtual state of lock. For further information on the front door latches, refer to Power Door Latch Description and Operation .
I would assume they check for DTC'S - diagnostic trouble codes ?
DTC B3062 Front Door Key Lock Switch Circuit
• DTC B3067 Front Door Key Unlock Switch Circuit
DTC B3849 Exterior Door Handle Switch Circuit
The left front exterior door handle and right front exterior door handle switch signal circuits provide inputs to the driver door module (DDM) and passenger door module (PDM) when an exterior door handle switch is activated. These inputs allow the door module to detect a door open request. The door modules provide voltage to the door handle switches. If the door module detects that a ground is applied for greater than 30 seconds continuously, a DTC is set and the door module will ignore the door handle switch input.
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model and engine size . Under system click body & accesories .Then under subsystem click power locks . Click the search button then the blue links
Cadillac CTS Door Handle Repair Micro Switches Replacement 2nd Gen
Aug 10, 2017 | 2006 Cadillac STS
Won't eject DVD
I was able to fix this problem by disconnecting the Bose power cord from the back of the unit. When I reconnected it the door functioned again. Cleaning the disc helped avoid further lock ups.
Apr 02, 2008 | Bose (321GS) System
Technics SL-MC4 61-Disc CD Changer Logo
358 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
