Question about Epson Stylus CX6400 All-In-One InkJet Printer
Won't print changed the ink and now it won't print.  comes out blank or paper doesn't feed at all.  would like to know how to open the ink casing again to make sure it is in correctly but do not know how to get to it when ink does not need to be replaced.  when you open the top the grey casing is all the way to the right and cannot be opened.  need help a.s.a.p
  • 96 Answers
Try to power off the printer, and your computer completely.
Power up only the printer.
On the front console of the printer select test print...
If the print out has blanks between colors perfom a cleaning cycle.
Note: ALSO VERY important to check that you removed the yellow tape fom the cartridges when you chnged them....
Posted on Nov 29, 2008
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
My printer Conon MG5320 is not printing ink is good feeds ok but paper comes out blank
Go the the setup menu and choose maintenance. Select "print nozzle check pattern". If nothing prints again, then select "clean". Try the check pattern again and If this does not change anything then you may have to manually clean the printheads. I will post separate instructions for this if you need.
Mar 05, 2015 | Canon Pixma Mg5320 Wireless Inkjet Photo...
Brother DCP-350C magenta ink won't clean and print quality check shows multiple visible gaps
You have a blockage in the print head and/or feed line from the ink cartridge to the print head. One possible fix would be to make a pad of paper kitchen towel wet it and sit the print head on it overnight. With luck the pad will soak the blockage and draw ink through the head. Give the machine two self cleans and try a print quality test to see if you have made ANY improvement. If no improvement - forget it as the blockage has been there too long.
Oct 30, 2017 | Brother DCP-350C InkJet Printer
Doesn't print on cardstock
Inkjet should always prints no matter what type of printing material you use since they only spray inks (laser will be different). Even if it is not compatible you will still see inks / smudge all over the surface. Try check your actual colour againts the paper it might be too similar hence not visible.
Sep 28, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Won't print black, prints every other colour ok
1. try to cleaning head
2. remove the black cartridge only, (if it doesn,t changed after you cleaned head)
3. provide some warm/hot water on a bowl or plate.
4. enter the HEAD of black cartridge in to hot water. soak with depth about 2mm up to 5mm. while you see the ink is come out....
5. after the black ink has come out. pat dry with a paper towels/tissue.
6. replace the cartridge in to printer.
7. cleaning head again and print test page
good luck....
Jun 19, 2011 | Canon Pixma MP500 All-In-One InkJet...
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
Machine not printing sounds like it is and feeds paper thou
Change the ink cartridge first an foremost,
then do a few print head cleans to flush out the blocked nozzles. it may come back after 4 or 5 cleans
good luck!
Jan 15, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
Not printing
the you remove the film clear on the front look like cover a little hole ?
Nov 17, 2008 | Brother MFC 420CN All-In-One InkJet...
HP Photosmart 3200 All-In-One not printing yellow
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 20, 2008 | HP PhotoSmart InkJet Printer
Not printing at all!
Change your cartridge and then try again
Sep 23, 2007 | Canon i9900 InkJet Photo Printer
Epson Stylus CX6400 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
