Question about Reddy R60A Utility Heater
Heavy smell I have an All-Pro Kero Heater Model # R60A . I purchased it from Home Depot last Oct. It worked great for heating my garage, and there was very little odor. This year when I run it, the odor or fumes are so bad you can't stand it. I cannot fine my manual. Is this a adjustment problem, or a bad part?
  • djdsr Nov 24, 2008
    I have en older model that does the same thing. My unit also runs for a minute then cuts out and restarts a half second or so later. I have cleaned out all old kero, flushed tank with denatured alcohol, let it dry a day, then filled with new kero. Still smokes, smells, and cuts out. I keep it, hopping that I can find out what it needs. I have almost given up on it.
  • 232 Answers
This is a fuel delivery problem. Look for:
  1. always start troubleshooting fuel problems on a Hot Surface Ignitor heater by checking the pump pressure!
  2. restricted fuel filter
  3. air leak
  4. restricted nozzle
Troubleshooting tips
Posted on Nov 29, 2008
Slow start it starts late and gives off a kero smell
jja53huebner,
See my tip at
http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters
and this will solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 18, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Hi i have a dyno glo pro heater model number RMC-KFA170TDGP it worked great last year this year its been nothing but a pain flames shoot out the front by times sounds like its getting to much air but the...
did you try cleaning the lens of the photocell, they git dirty from smoke ver time which regulates the flame or replace the nozzle, sounds like it could be getting plugged up? usually any heating store would have a nozzle for a couple bucks if you get the number off it. the nozzle is right where it comes out and they are common to plug up at times with wear
Jan 18, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
CAN I PUT DIESEL IN MY KERO REDDY HEATER 150,000 BTU HEATER AND WILL IT SMELL OR RUIN IT
since the combustion temp of diesel is different from KERO, expect the heater to shut down from overheating at times.
since it will probably heat up faster than on KERO.
Jan 31, 2010 | Reddy R60A Utility Heater
I have a Remington 100 Heater. Was running fine until we had to refuel with kero that has a die in it. The heater will run for about 10-15 mins. then just start smoking with a heavy fuel smell. Cleaned the...
Similar heaters that use diesel have to routinely cope with the dye added to untaxed fuel, ditto similar heaters that use both fuels. Unless there was an excess of dye in the fuel you used the problem was probably a coincidence.
Dirt can be a big problem due to corrosion forming in the fuel tank caused by a relatively large percentage of moisture naturally in the fuel and the formation of condensation. Fuel is generally filtered through a fine gauze when the tank is filled but there is little or no filtration preventing dirt already in the tank from being picked up and finding a way into the spray head which generally jams the spinner affecting the quality of the fuel spray.
Cleaning the spinner and nozzle might work for a while but only a major clean out will restore reliability until the next time. It is also wise to check and adjust the pressure of the air pump.
Feb 18, 2018 | All-Pro Kerosene Garage Shop Heaters - All...
Ihave a R60A heater that when I turn it on it
This is in referance to the R60a 60,000 B.T.U. Multi fuel heater
Sounds like the your ignitor has burned out. Had the same problem. Now looking for a replacement. Checked mine and for some reason the filiment has broken/burned off. Ran across this on a search for one. Good luck!
Oct 11, 2009 | Reddy Heater RLP100 Portable Forced Air...
Where can I purchase parts for my All-Pro
there is no clutch on this unit.it is an air pump that has rotor and vains.All pro heater parts are getting few and far between. try this place they have some of the parts but not all.if your ignitor ever goes out there are non to be found.they are no longer avalible.......www.portableparts.com
Feb 19, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Filters for dyna-glo pro
You can make your own filters out of felt and I have also found that with some minor modifications most of the parts from Mr. Heater will work with Dyna Glo. I have a 170btu kerosene heater and just installed an ignition, a high limit control and a flame sensor from Mr. Heater and it works like new.
Nov 03, 2008 | Desa International ALL-PRO® SPC-85 Utility...
Reddy R60A Utility Heater Logo
177 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
