Question about Jenn-Air JED8430 Electric Cooktop
Wire for stove top burners
Have a c202 Jenn-Air cooktop. Wiring from power supply input to the switches on the cooktop is tired where it connects to the switches, but is too short to cut back and reinstall clips. Wire appears to be same type and gauge as that which runs from the switches to the burners. I am replacing the switches, but would like to renew the wiring while I'm at it. Where can I obtain this wire?
  • doug_tindal Dec 06, 2008
    The on-line parts dealers I've found thru Google say that they do not have it. Ideas? Is there any reason I can't just buy high temperature wire someplace and replace the harness one wire at a time, wire for wire?
  • 324 Answers
Same place you got the switches,you can usually get the whole harness.
Posted on Dec 06, 2008
Why Is my cooktop tripping the breaker?
my blower switch shorted out. Could smell the plastic once removed. Liquids dripped into contacts during cleaning. Switch replacement obsolete. Found switch @ Ace. Made modifucation to panel to accept rectangular switch.
Mar 28, 2015 | Jenn-Air Cooktops
Why are lights not working under the ceramic JennAir stove top?
You have probably accidentally disconnected some wiring whilst moving it need to re explore
Apr 27, 2014 | Jenn-Air JED8430 Electric Cooktop
I have obtained a replacement element Whirlpool AP5653770 for my Jenn-Air JEC8430ADS cooktop. I have lost the secmatic I made showing the colopr of wires going to each position on the element. I have a...
This is the correct way to wire the right front burner on Jenn-Air JEC8430ADS cooktop. Let's do the red wires first. The red wire that comes from #2 on the switch goes to the common connection for the element that should be labeled 2a. The other red wire goes to either of the "b", hot surface indicator switch contacts and the black to the other. Use 1b or 2b for these connections whichever reaches easiest. The yellow wire goes to the inside loop of the burner and the tan to the outside element.
Dec 04, 2013 | Jenn-Air JED8430 Electric Cooktop
I have a 4 burner Jenn-Air JED8430ADB electric radiant heat stove that has recently stopped working. It has been installed for many years (came with the house) and worked fine until now. When I turn one...
The cook top is connected to 220 volts. In the house wiring there are two legs each 115 volts. Usually they connect with a red wire, black wire and the third a neutral. It is likely that at the connection to the unit or at the electrical box a connection has failed or the 220 volt circuit breaker has failed on one leg. A qualified electrician needs to do the repair!
project1-nbbnxwvnfadegsi2zsme4jri-2-2.jpg Hope this helps?
May 04, 2017 | Jenn-Air JED8430 Electric Cooktop
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
Dec 26, 2009 | Jenn-Air JED8230 Electric Cooktop
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
786 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
