Question about Citizen Eco-Drive BL006056H Wrist Watch
Condensation in crystal of eco watch
How can I remove moisture condensation in crystal area of my eco drive? I would prefer not to disassemble as there are no reliable repair shops where I live? Any suggestions? I love this watch but it is getting hard to read the face.
    Novelist:
  • 100 Answers
If there is water in the watch, it's going to quit working sooner or later. If sooner, then the watch (at least the back) will have to be opened anyway. If later, then there will likely be some rust that could cause the watch to never work again.
In the meantime, I'd advise putting the watch near some dry heat -- like a radiant room heater, or maybe a hair dryer. Don't "burn it up" trying to dry out the water. You don't want the crystal to melt, etc.
Water in a watch is bad. The best solution would be to have it repaired now.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Posted on Nov 17, 2008
What's the best way to put the crystal back on my echo drive? Mine fell off and I was lucky enough to find it. Just not sure if I should take it to a jewelry repairman or try to fix it myself. It...
The answer just depends on your preference: you can use a glass to glass adhesive and it should hold up fine. Just make sure that when you are attaching the crystal it is in the exact spot you need it to be in and also to have a small clamp ready to press over it. This will help to seal it better and make it last longer. If you don't feel up to it, I would take it by and let a jeweler take a look at it. Either way it's going to be a small fix. Hope this helps!
FlamePants
Jun 01, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Water (vapor) under the crystal
Water condensation on the inside of your watch crystal means that moisture has entered your watch, most likely through the hole in which the setting crown/stem is fitted, or, possibly, through the door of your battery compartment. It's usually easier for water to enter a watch then to leave it again. Water inside a watch can quickly corrode delicate parts, causing erratic timekeeping and premature failure of the watch, so you'll want to get it out of your watch as quickly as possible.
Fortunately, it's not that difficult to get moisture out of a Swatch. Pull the crown out into the time setting position and remove the back battery hatch. Then, turn the watch face down and leave it in the sun for a few hours. If you're worried about dust and/or rain getting into your watch, leave it inside a parked car that's in the sun--that will actually speed up the drying process, as car interiors, with the windows closed, quickly heat up far beyond outside ambient temperatures (except in winter). If it's dark outside, you can accelerate the drying process by using a hair dryer set to low / medium heat and heating the crystal gently until the moisture has evaporated. You don't want to heat the crystal too much or else it may start to melt or crack.
Once the water is out of the watch, close up the battery compartment and update the time/date for your watch. You should be good to go, as long as you try to keep your watch dry when doing things like washing hands and the like. If you had been doing so, it's also time to stop wearing your watch when you shower, wash your car, or engage in other activities where the watch is exposed to a lot of water.
Jun 01, 2011 | Swatch Watches
I need new pins for my womens eco drive citizens watch to re size. where do i but them and what size do i need.
mcdevito75 here, besides the pins, you"ll need a special tool called a Pin Removal tool. By the time you order and recieve, it"s better to look for a small watch repair shop in your area for the removal / Install of these pins and links.
Aug 02, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
My tag heure chrono's minute and second hands turned black and moisture got in ?
mcdevito75 here, I hope you have a warrantee on your Tag Heur watch, if so, contact Tag Heur, if not, your on your own, (Sorry) sounds as though it"s lost some of it"s waterproofing ability or the seal around the crystal, usually a crystal sealer. Best Bet look for a small watch repair shop in your area, have them take a look at your watch. The Fog on the crystal is the tempersture change of the air in your watch, no watch is air proof, re-sealing the crystal should help, also, replaceing the rubber seal on the back of the watch.
Jul 18, 2010 | Tag Heuer Watches
Replacement mineral glass for Citizen Skyhawk AT
mcdevito75 here, Yes, there should be, look for a small watch repair shop in your area, for this crystal.
Jul 05, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Taking off a link from a citizen eco drive watch band
mcdevito75 here, Best Bet, look for a small watch repair shop in your area, You"d need a tool to remove that link, by the time you get the tool, the time to remove the link, is about the same cost of haveing a shop do the job.
Jul 04, 2010 | Citizen Eco-Drive Aqualand BJ2004-08E...
How to remove moisture inside the dial?my watch is Tissot Le Locle.
mcdevito75 here, No watch is air proof and all air contains water, the condensation in your watch is the air changeing temperature, hot / Cold, Best Bet, if you have a warantee on the watch use it so the watch can be re-sealed (crystal / Back cver) if you don"t have a warantee see any small watch repair shop in your area about thios problem. Or you can visit our repair service directory here at fixya, bottom of page click on repair service directory then watches.
Jul 04, 2010 | Tissot Le Locle Automatic T41.1.183.33...
Submariner water under crystal
You definetely have to ask for watchmakers help to dry out your watch properly. Moisture may not be visible to your eye, but it's still in the watch case and ruins your watch movement permanently and quite quick.
Sooner or later your watch will stop or show some other faults, but by that time the price for repair can be sky-high.
I've been replacing whole movements, just because the owners thought it's not a big deal or didn't want to pay for such a job. It just sounds 'drying out', but actually it's not, as watch must be disassembled completely (incl. movement), cleaned, oiled and properly re-adjusted.
Rolex repairs has never been cheap, but better do it as soon as possible.
Do not forget to rate, please.
Jan 20, 2009 | Rolex Submariner 16618 Wristwatch
Citizen Eco-Drive BL006056H Wrist Watch Logo
532 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
