Question about JVC HD-52G786 52" Rear Projection HDTV
HDMI INPUT HAS FAILED
My HDMI input has failed and needs to be replaced. Diagnostics have been done by two different techs.  All other Inputs and Outputs work fine. I think, as an engineer myself, I can replace the board myself.  The service place wants $700.00 to fix it.  Isn't it just a card / board that I can change out? Also, I can't find a part number online.
  • 1 more comment
  • Anonymous Nov 18, 2008
    Worked for me! I was getting no signal from my PS3 through HDMI, resetting in Service mode, now I can see in 1080i. Thanks!
  • wherewithal1 Dec 24, 2008
    I have never been able to get my HDMI connect to work, ever. Settled for composite cables instead...over last 1 1/2 years. I recently bought a blu-ray player w/ HDMI cable and have experienced the same problem. I am connecting directly to HDMI inputs, going to digital mode and keep getting a green screen. Am I just setting this up wrong or do I need to reset/ or get a technician? Thanks.
  • Anonymous Mar 15, 2014
    i have a lg 55" led tv (55le5300) which none of the 4 hdmi inputs are working. I supose to change the main board, but now i have doubts if i have to change the main board or de power board. which of them should i change and where can i find it? thanks
    Genius:
  • 1,030 Answers
DId the technicians try to reset the HDMI.
The HDMI module will need to be reset after service
. Enter the service
menu and select “2”, the Self Check option. Power off the unit using the
Remote. Allow the unit to complete its Cool Down cycle, then unplug the AC
Power. Reconnect the AC Power and power on unit. Confirm HDMI input
operation
sorry the font change on me. this unit has compatbilty issue with some hdmi sorces. there is also a safety interlock sensor if it see extra light it thinks your trying to do something wrong and locks up hdmi.
WARNING. Service mode can result in further damage to set. Care should be taken not to mess with settings unless you know what they are.
1) Set to "0 minutes" using the [SLEEP TIMER] key.
(2) Press the [VIDEO STATUS] key and [DISPLAY] key
simultaneously, then enter the SERVICE MODE.
(3) When the Main Menu is displayed, press [2] key to enter
the self check mode.
(4) Turn off the power by pressing the [POWER] key on the
remote control
Posted on Nov 17, 2008
Switched the input on 42LK450 from TV to HDMI3. Now, the Input selection only shows HDMI3. All other choices are grayed out. It seems that something failed with the Input selector. Any ideas?
try plugging the hdmi 3 device into hdmi 1 and see if the hdmi 1 input is still greyed out ?
check the orginal device is powered on that was in hdmi -1
the tv greys out inputs that are not detected according to page 43
of user manual
https://www.manualslib.com/download/697971/Lg-19lv2500.html
May 29, 2018 | Televison & Video
Hdmi input not working
If it works on your cable or tv input then the problem lies with your input circuitry. Since those inputs are on your main board, then it is that board that has the issue and needs to be replaced.
Nov 18, 2015 | Televison & Video
I have a TV, when switching to the component cable input it only displays a fully green screen. HDMI does not work at all. Would that be a sign of a failed T-Con board? TV is a Sony Bravia KDL-46WL135
Hello. Judging by your question, the on-screen graphics are working, since you are able to see what input you're on. If that is the case, the T CON is okay and the Main board (the one with all the inputs) is defective. Also an indication is different displays for different inputs. If the T CON were bad, the picture would remain the same, since the T CON doesn't know or care what input is being used. Good luck.
Oct 26, 2015 | Sony Televison & Video
How do I fix bad HDMI inputs on LG 55LM6400 Smart TV
You need to replace the main board.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Aug 18, 2015 | LG Televison & Video
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Video is different from HDMI. From what I have seen you should have video inputs and component inputs. instead of trying these video inputs, look for tv/component button on your remote or tv settings.
Feb 01, 2014 | Toshiba Regza 52XV645U LCD TV
My AV2 doesnt work and either does my HDMI port does not work either??? but AV1 does ?????? what the hell????
The AV inputs are routed and controlled by the control processor on the mainboard.If one input has failed but another is just fine then definitely the circuits corresponding to those inputs have been fried. This usually happens during power outages, or when you connect units that are at a different electrical potential - they get damaged by the power surge.
There is nothing that can be done to revive them - the entire mainboard will have to be replaced.
Nov 26, 2010 | LG 60LD550 60 in. High-definition LCD TV
RCA HD52LP: Composite video inputs don't work
RCA Authorized service tech looked at it. He determined that the DM Module need to be replaced. The part alone costs $550 + labor. Since the HDMI and component video inputs seem to work, he suggested buying a VCR DVD combo with HDMI output which would be far less than repairing the tv itself. I'n researching the possibility of purchasing the part myself.
Jun 08, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
HDMI Input Failed
I've been seeing alot of this out in the field. The cable is thick and heavy, after awhile the HDMI connectiion inside the set comes apart and breaks from the main board. In my opinion the only difference between Component jacks and HDMI inputs is the thought of reducing the amount of wire mass in the back of the unit. It's more pleasing to the eye. If it's under any kind of warranty, call a servicer. The main PCB will need to be replaced. If it's not under warranty, use component input cables, you'll get the same performance from your set and save a few bucks.
Dec 24, 2006 | Toshiba 30HFX84 30" TV
JVC HD-52G786 52" Rear Projection HDTV Logo
521 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
