Question about Zyxel Computers & Internet
Configuring Zyxel Prestige 324, unable to log in
Zyxel Prestige 324 purchased Dec 2002. ok as a switch linking 2 PCs ADSL technology, without using WAN. New internet prrovider needs to use WAN to link both PCs and use available IP No. But unable to log on to configure the Zyxel. Get 4 spot passord on the log in dialog box; when I click on it, string of black spots appear and immediately vanish. No logging in. How do I proceed? (Note: never changed the password, presumably it is the factory set 1234)
  • 47 Answers
SOURCE: Zyxel P660HW-D1 drivers
Since you are referring to a router you can access the configuration using the web configuration you just need to type the router default ip address on your browser to access the configuration.
the default ip address is 192.168.1.1
http://www.zyxel.com/web/product_family_detail.php?PC1indexflag=20040812093058&CategoryGroupNo=AC5783AE-9475-41AD-BDA5-0997187F44AA
http://dl01.zyxel.com/DownloadLibary_ShortName/P-660HW-D1/quick_start_guide/P-660HW-D1_1.pdf
Posted on Mar 05, 2008
SOURCE: Can't Open Internet Explorer
You have to contact your service provider. That's a thing which is done by them to secure there internet service. They will give you the username and password. I evn tried that and they asked me to type the modem name and 'admin' as a password. For example, my modem is STstarcom. so the username wax starcom and password: admin.
Thank you.
Posted on Sep 12, 2008
kakee
  • 1269 Answers
SOURCE: configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Posted on Nov 01, 2008
SOURCE: cannot configure d-link 524 router to cable modem
You probably have to "clone" your computer's MAC address to the router. Usually the cable providers register your computer's physical address (aka hardware or MAC address). So in order to let your router get connected your router has to send the same MAC address. This is called MAC address cloning.
To get your machine's MAC you go run->cmd and on the command line write "ipconfig /all". This will show you the info of all adapters you have on your computer. Search for the ethernet adapter and get its physical address. It should look like (xx-xx-xx-xx-xx-xx-xx-xx) where x is a number 0-9 or a letter A-F.
Once you have that you need to go to your router's configuration page and find where you can insert the clone MAC. You may also need to enable the cloning from the same page.
Hope that will help.
Posted on Jan 18, 2009
  • 10 Answers
SOURCE: want instructions on how to secure a zyxel prestige 900 router
I thought the 900 series zyxel was a multi ip address router modem, if your connecting a router or switch try supplying your gateway, dns info from your isp to the device.
Posted on Apr 13, 2009
What is the default username and password
In case you haven't changed your router's default administrative settings, fire up an internet browser, and, preferably through a wired connection, go to 'http://192.168.1.1'. When a login prompt screeb comes up, enter '1234' (without the quotes) as password.
Hope it works for you.
By the way, if your router's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if you need further informations.
Regards, Carlos
Aug 21, 2011 | Zyxel Communications ZyXEL Prestige...
I no longer have a linksy's device connected to my computer and want the ZyXel P-660R-D1 device to work on my AOL.Com connection so how can I do this for DSL or Broadband connection
First of all good purchase, i use similar router P-660HW-D1 as it supports SNMP for monitoring and log server features.
Have you tried the wizard ? did it give any errors ?
The official settings are :
Connection protocol: PPPoE
VPI: 0
VCI: 38
Username: yourusername@aol.com
Password: youraolpassword
Authentication: CHAP
I had issues with AOL a year back for a friend and we were never able to get a ZyXel working over the connection, hopefully this has changed and they are now using standard ADSL authentication.
On the home page of your router there is a "packet status" link click that and it will give you info about the link status. Also look in the log for any PPP activity and reply to this thread with the info it contains if it does not work.
Hope it helps, Lee :)
Dec 22, 2010 | Zyxel Prestige 660R Router (91004397002)
How do I bridge mode a ZyXEL 600 series ? help please
Try setting both internal and external interfaces to DHCP rather than static, or if you have legal static IP address put it on INTERNAL interface only.and leave external as automatic.
Feb 24, 2010 | Zyxel Prestige 650HW - ADSL Router...
Zyxel Prestige 660RU Adsl 2+ Ethernet USB Router drops my dsl connection after 5 minutes of usage. Sometimes it does not connect at all. I tried restarting everytime it does it. Even unplugging it. The...
First of all, please chk if this happens without the router. If it does, then talk to your ISP . Else, I would suggest you check if you can upgrade teh firmware of your router. The router's website, should be able to give you directions on that
Hope this helps
Thanks
Ranjit
Oct 30, 2009 | Zyxel Prestige 660RU Adsl 2+ Ethernet USB...
Zyxel 660HW DSL LED keeps flashing
Try to change the Local or LAN IP Address of your Zyxel to 192.168.5.1 and do not configure the Zyxel router for PPPoE Connection. It should be configured as Obtain IP Automatically or Automtic DHCP.
Oct 21, 2009 | Zyxel Prestige 660HW Wireless Router...
Cable Network Routing with Zyxel 600
You have to set different ip address. To clear this up this how I got my setup. I have verizon internet. I use a westell 6100g modem, I have the local ip address set for 192.168.1.1 and I got a linksys wireless router and the ip address set for 192.168.9.1. Then I plug my modem into the wan port and it works. What am I doing is setting a static ip address from my modem to the router and using the router to distribute my address through the network. If you have any printers on the network you need to change that numter to 192.168.9.x number. If you don't have two different numbers set the router will take over.
Aug 09, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
Please read the problem
Hi there.
The router is around 4-5 years old and is ADSL/1
Here are the power specs for you >>>>
Thanks for choosing FixYa!!
Jun 01, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
After configuring network TCP/IP automatic Dns server automatic or preferred and alternate dns as given by isp, setting router to mode router encaps..pppoa (second trial RFC1483) multiplex..llc virtual...
ftp://ftp.zyxel.com/
this the web site download the user manual from this site what ur configuration go thought it i think you get it and maybe the problem in the pppoa line its working or not just check it
Apr 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Network speed.
the speed of the network adaptor is 100mps but the system speed is constrained by the maximum speed that your broadband provider.
What is the rated speed of the internet connection to your home? this will be the limiting factor.
Jul 22, 2008 | Zyxel Prestige 650HW - ADSL Router...
Computers & Internet Logo
435 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
