Question about Toshiba 13A24 13" TV
Toshiba televisoion problem
Toshiba television video mode problem i have a toshiba tv with "core fs made in japan" model which is still in good condition however i have lost my remote and could'nt set the tv to video mode. is there a way to set the tv manually without using a universal control as an option to this problem? waiting for your response, thank you. mile
  • 81 Answers
There should be a control on the set at the panel to switch this over to video. Might be in a door area or right up front if not U will to obtain a remote
Posted on Dec 13, 2006
Need to know the size of screws that goes into TV stand for a Toshiba TV model number 40S51u
58 cents each mail order. Not only do they have to be right diameter and thread, also the correct length.
40S51U Toshiba Tv, 40" 1080P Led Lcd Replacement Parts
https://www.encompassparts.com/model/TBA40S51U/_/_/Toshiba/40S51U/Tv,_40
  1. Cached
Toshiba from Encompass parts & accessories. ... 40S51U Toshiba Tv, 40" 1080P Led Lcd. 40S51U Tv, 40 ... 75024004, Toshiba Screw, Stand, Mac000, 0.77.
Toshiba 40S51U Parts List - PartStore.com
https://www.partstore.com/Model/Toshiba/Toshiba/40S51U.aspx
  1. Cached
  2. Similar
List of Spare Parts for Toshiba 40S51U Parts List. 40S51U UNKNOWN ... Toshiba TV Mounting & Installation. 75024004. SCREW, STAND, MAC000. $0.58.
Toshiba TV Stand for 40S51U Complete with Neck and Screws ' eBay
www.ebay.com > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
TOSHIBA TV STAND FOR 40S51U COMPLETE WITH NECK AND SCREWS in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio Parts ' eBay.
Toshiba TV model number 40S51u Google Search
Nov 27, 2016 | Toshiba Televison & Video
Toshiba Televisor Core FS full auto 3 System
Hola necesito saber como programar los canales manualmente en mi toshiba core FS full auto3 system
Jun 14, 2014 | Toshiba Televison & Video
Go to av mode without remote in toshiba 27d46 tv
Here is a manual for that tv. Page 27 says to push the tv/video button but that is on the remote. Do you have a tv/video button on the tv itself? If so, push it until it cycles through to the video input you want
http://www.manualowl.com/m/Toshiba/27D46/Manual/33233
Jul 28, 2012 | Toshiba 27D46 27" TV
Have a toshiba 27df47 flat screen tv. how do you
First make sure the video inputs are not locked using these instructions:
To set up the video lock:
1. Press MENU, then press or to display the LOCKS menu.
2. Press  or to display the password entering mode.
3. Use the Channel Number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
4. Press  or to highlight VIDEO LOCK.
5. Press or to select:
• OFF: Unlocks all video input sources.
Then it appears that choosing Video 2 using the TV/VIDEO button should enable the front input.
An entire manual is avialable here that should closely match your tv:
http://www.tacp.toshiba.com/tacpassets-images/models/27DF46/docs/27DF46_om_E.pdf
Aug 29, 2009 | Toshiba 27DF47 27" TV
Toshiba television will change from tv/video mode to
I would check to see if the Input button is stuck on the front panel of TV. If it is not stuck then it is probably still bad. Tactile switches are notorious for failing in this manor. The only real fix if it is not stuck down is replacing the switch.
I hope this helps,
Skyassoc
Jun 22, 2009 | Toshiba 36A43 36" TV
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Jan 12, 2009 | Toshiba 14AF44 14" TV
Only getting sound but no picture!
Well, i had a look at the back of that Toshiba TV - make sure that the red, white, and yellow cables are hooked into the Video-1 slot of the Toshiba and that the Toshiba channel is changed to Video 1.
Then check your nameless DVD player and make sure the red, white, and yello cables are all hooked to OUTPUT slots that are in the same column or row - if I had you DVD manufacturer and model #, I could suggest some additional steps to check. Also, make sure your dvd player is in dvd playback mode.
-Tha Mp3 Doctor
Dec 31, 2008 | Toshiba 42HL167 42 in. LCD Television
Not able to get to tv-video on Toshiba 27A45
For TV video switching change program (-) button till you get 1 or 0. After 1 or 0 again press program (-) button you get video mode. Or try any other option in menu features to change video mode. I hope the above information is helpful to you.
Sep 03, 2007 | Toshiba 27A45 27" TV
Toshiba 13A24 13" TV Logo
368 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
