Question about Canon imageRUNNER 5000 Copier
Saving a copy job
Doing 400 copies from manual feed on top, how do I save if I want to print more again without recopying the originals again? Thanks for your help.
  • Anonymous Nov 19, 2008
    blank copies
  • 318 Answers
Hi
Try to scan your originals to your mailbox on the IR machine and save it there.If you need copies of the originals again go to the mailbox highlight the job and reprint it again.
Posted on Nov 18, 2008
I have not my Epson Stylus Photo for quite some time. Now I want to use it again, I 've put in some new cartridges. The print shows repeating (green) lines. Any idea what could be the problem ?
To help complete the pattern, feed copy papers to the printer and do atleast 40 blank photocopies and afterwards clean the head and check the nozzle.if it has not improved, repeat the same procedure until the pattern completes.mine also had the same problem but after doing that, it was solved for good.
NB: Command copies without putting any printed paper to save ink.
Oct 12, 2012 | Epson Stylus Photo R220 InkJet Printer
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
I bought a used Lexmark Optra SC 1275 a few years ago for a home office. It took a LONG time to spool up and for some jobs it just took forever, so I really didn't use it much after I got it. I...
Hi Robert
In short....Sticking Transfer roller solenoid..
Lets start with HERE is the service manual, you will need it to understand me, no fear it is free today;)
and THIS is your PARTS manual
What the machine is trying to tell you is written on page 61 of service manual aka transfer roller aint lifting
The problem is SL5 its a soleniod (page 30 of your parts manual)
Yours works but sticks, what goes on as these age is there is or was a little pad that stops the metal from clicking when the arm of the solenoid hits home. a solenoid is just a spring loaded arm that is moved by a electro magnet, when the electro magnet it "turned on" the arm moves to the magnet and allows the transfer roller to turn, what yours is probally doing is when it is turned on there is a delay cause it is sticking so the whole timing goes out of whack. The pad on the solenoid goes all gunky and holds back the arm from getting attracted instantly to the magnet, You need to clean the underside of the armerture of SL5. Metho or alcohol is what i would use, but you need to get into it and do it properly and get rid of the sticky junk on the solenoid, no lube required, just clean, Read the manuals I gave you regarding SL5 and the transfer roller.
.I dont think it is a tray problem is is to do with image transfer not paper feed so using the bypass (manual feed) wont help you, but to use it just tell the printer driver in your windows/printers/propertys to use MP tray.
You want to print 1000 pages,!!!
i think it is more economical to use a print shop than fork out for the consumables like belts toners paper drums, once you work out the true running cost of machines compared to high volume machines made for the job, you tend to lose out everytime. In my understanding it better to wear out someone else machine let them take the heart ache and expense of keeping quality supplies up to printing big runs, but thats only my educated understanding, in truth I make more from you buying toners and drums endlessly;) rather than paying 10cent a print or whatever. Work out your running costs, factor in toners, drums, fuser, belts, feed rollers and paper. Get the life of each one and divide it up into per page, you will end up 10 - 20 cents per page. Use original supplies not aftermarket if you dont want to cost yourself more than you save by using crud. Its easy to sell crud aka aftermarket recyle save the planet heaps cheaper printer consuamables but it creates 90% of my service calls @ 120/hour and wrecks machines most days from saving a buck, in the end I take all the savings and customers go off to buy another machine only to do it again when some salesman entices them with cheap promises...
anyway enough of the reality I see but you did ask for my thoughts......, get into that solenoid and clean it up, you should be right.. oh and the forever to spool, try a different printer driver like a postscrip one or something if my guess is right and your forever to spool issue is when you are trying to print Adobe PDF files;)
cheers
Steve
Drivers
Nov 18, 2011 | Lexmark Optra SC 1275 Laser Printer
My colors are printing separately, divided and do not overlap or blend. I use a Roland 540 printer, and I have replaced chips, motherboard, and encoder sheet. What would cause this?
If a gap is present decrease the value by going to Menu, Calibration, Setting and pressing the Down Arrow to decrease the percentage shown to match what setting is best on the test pattern. Press Enter to save the value. If the printer does not show multiple test patterns perform the Feed Calibration, Test Print again to check the results.
If an overlap is present increase the value by going to Menu, Calibration, Setting and pressing the Up Arrow to increase the percentage shown to match what setting is best on the test pattern. Press Enter to save the value. If the printer does not show multiple test patterns perform the Feed Calibration, Test Print again to check the results.
Tech Tip: The Feed Calibration is a very fine adjustment meaning that an incremental adjustment of .05% or 10% is very small. Some media will require an adjustment in much larger steps.
Note: The Feed Calibration setting on the printer will be overridden by Versaworks as a default. This can lead to a very confusing scenario where the Feed Calibration setting doesn't appear to make any adjustment. Please see the next page for information on setting the Feed Calibration in Versaworks.
Once the proper Feed Calibration has been established on the printer it is important to make sure this setting is correct in Versaworks. Once Versaworks is open and a job has been loaded, perform the following steps:
A. Double click on the print job to bring up the Job Settings window and set up your media size, copies and other relevant items under Layout.
B. Select the Quality tab and Select the proper Media Type for the job. This step is critical because the Feed Calibration is tied to the type of media being used. When the Media Type is changed the Feed Calibration setting will change to the setting which is default for the Media Type.
C. Next select the Printer Controls tab on the left hand side and under Feed Calibration Controls choose Use Printer Setting.
D. Select OK to save the settings.
Tech Tip: In step C you can also select Use Custom Settings and enter in a value for the Feed Calibration. This allows for making corrections to the Feed Calibration without changing the settings manually on the printer. If you choose Use Default Media Settings or Use Custom Settings the value that has been set on the printer will always be overridden.
Tech Tip: In addition to having multiple test patterns which make for a quick and easy selection to be made the RS, XJ & AJ printer models allow adjustment of the Feed Calibration mid-print by taking the following steps:
A. Press the Menu key
B. Scroll to Calibration, Setting and pressing the Down Arrow to decrease the percentage shown or Press the Up Arrow to increase the value.
C. Press Enter to save the change in value.
Jan 18, 2011 | Office Equipment & Supplies
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
How do I print off a copy of the desk top?
Hi there.
Hit Prt Scr on the top right hand side of the keyboard, open paint and paste the screen shot in there, the click file and save as, save the file to your desktop or documents, then open the saved paint file and you should be able to print it off.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Microsoft DA900013 Keyboard
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
Brother MFC5840 CN Print heads
I guess you have used generic ink carts.
You should buy an original brother ink cart.
When done so make sure all other carts are at full level:
Press menu then start b/k copy then fourtimes arrow up (tel.index). Machine will be in maintenance mode. press 7 then 6 then 4 then start b/k copy. Machine will refresh ink within tubes and print head and do some power cleaning. when finished press 7 then 6 then 3 then start bk copy to run an extra power purge.
Leave maintenance by pressing 9 then 9.
Do run a quality test print.
If you re lucky the it will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintenance mode.
If you like to save money refill ORIGINAL Carts by drilling a 2mm hole into the top (O of brother brandname) . You can leave the hole open to refill the cart next time directly without taking it out of the printer.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of distilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
For bk mix 1 ml glycerin alc with 4ml dest. water and 15 ml bk DYE ink (shake well before refill).
This is -nearly- the exact mixture of original brother ink.
Mar 12, 2008 | Office Equipment & Supplies
Stuts,
If you re lucky the ph will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintnenace mode.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of destilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
This is -nearly- the exacte mixture of original brother ink.
Mar 02, 2008 | Brother MFC-5840CN All-In-One InkJet...
Canon imageRUNNER 5000 Copier Logo
85 people viewed this question
old marine
old marine
