Question about Whirlpool MH6150XMS Microwave Oven
Door-activated power switch is loose and/or has a short
On this 1997 or 98 model year Whirlpool, over the range, 1.7 cu ft black plastic door w/glass turntable model, there are two prongs on the door that couple with small square openings in the white interior door frame. The lower opening contains a small white plastic power switch or interlock that seems to be loose or is shorting; no switch visible in the upper opening. When the door is closed the interior oven light and fan operate non-stop even though the "cook" command is not entered, however the turntable does not spin and the microwave generator does not appear to fire up. Normally when the door is closed the oven is completely off unless a cooking command is entered. Question -- how do I access and repair or replace this switch? What is the part called? And do I have to de-install the over-range unit to make repairs or is there access to this area from underneath?
Thanks!
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Posted on Nov 18, 2008
2 Suggested Answers
MicrowaveSvc
  • 9030 Answers
SOURCE: What does F4 on microwave display mean?
This Kenmore is made by LG for Whirlpool. Confused yet? :D
F4 means you have an open humidity sensor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site here, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
But Sears parts can usually be obtained for far less here by entering either the part number.
Posted on Apr 24, 2010
Turns on when door opened
There is an power interlock inside the oven that breaks the power connection to the magnetron when the door is open. Most likely, something is stopping the switch from opening.
Check for a small plastic probe on the door that may have broken off inside the oven keeping the circuit made. Otherwise, open the oven and see is some foreign object is keeping the connection made or if the interlock needs to be cleaned out so it can function.
Jul 11, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Microwave not working unless I hold & push up the door. what's wrong?
You have a defective bottom door switch or possibly its mount is loose.
The service manual is here.
Also see my help file on door switches here.
May 31, 2012 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Sometimes when I go to heat something in the microwave it doesn't heat but when I open the door and then close it it sometimes will work?
Sounds like the door switch is going bad this is the switch that "tells" the microwave the door is closed so that way it doesn't run with it open
Apr 26, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Microwave timer counts down but doesn't turn on when started
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Aug 26, 2009 | Whirlpool MH6150XLS Microwave Oven
Door switch went out- second time in two and a half years.
sounds like the door switch has been used to stop the unit while heating instead of using the stop button.
Phil
Jun 10, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Microwave door locked
open the cover of the oven you can see see the lock near the key pad. Press the lock the door will open. You can adjust the alignment by refixinfg the screws.
May 12, 2009 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
May 14, 2006 | KitchenAid KEMC377K Convection / Microwave...
Whirlpool MH6150XMS Microwave Oven Logo
145 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Gerry Harvey
Gerry Harvey
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
