Question about Whirlpool GHW9100L Front Load Washer
No cold water Whirlpool top load washer AP595033
Water pressure is good, hoses clear, screen traps are clear. Water goes to washer but will not go in. On warm water cycle there is only hot.
  • 370 Answers
Your cold water celenoid has gone out. There is no way to just replace the cold itself, So you have to buy the whole water valve. That will fix ya up!
Posted on Nov 19, 2008
Code f 20 what does that mean and how can I fix it.
A possible solution to an f 20 fill error for a whirlpool duet washing machine. Blow out the pressure hose that connects to the pressure switch.
Before doing any of these fixes first ask yourself if you have over loaded the machine. Too many Bulky - heavy items will cause this same message.
How to fix Whirlpool Duet F20 Error:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.zTyr5Yy1.dpuf
Oct 16, 2014 | Whirlpool duet Washing Machines
Got a f20 code on my washer and i have a question
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.FHzIAYn8.dpuf
Oct 05, 2014 | Whirlpool duet Washing Machines
How do I fix F20 code
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.2RAhsfLg.dpuf
Sep 19, 2014 | Whirlpool duet Washing Machines
What does F20 on the washer mean?
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Whirlpool duet washer LF error
LF error means "Long Fill". Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the LF error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
One last thing to check is the fill hoses. These front load washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses. If the hoses are good and you haven't found anything slowing down the flow of the water, your electronic inlet water valve is just faulty on the back of your washer and will need to be replaced because it's just not allowing water flow into the washer correctly.
Nov 24, 2012 | Washing Machines
LF COMES ON MY FRONT LOADER LED SCREEN
Here is the valve to order in case it is faulty.
Nov 09, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
WTW6600SW1 whirlpool cabrio washer keeps giving an F1 error, why??
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
Sep 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cold water tricles in . no normal flow does the washer valve need to be replaced
There are debri screens in many styles of washer fill hoses that can block up. And the end that connects to the back of your machine also has a reachable screen filter up inside the water valve inlet that can also block up.
Disconnect the water fill hose at the machine and check screens ... clean or replace if needed.
The screen are usually attached to the hose washer and will pop out manually with a small screwdriver or knife. Then turn the water valve on with the free end of the hose aimed into your washer tub to make sure you have free water flow from the faucet to the water valve. If all screens are clean and clear but still no water pressure going into the washer after reconnecting your hoses then you can suspect the water valve inlet assembly.
Dec 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Slow cold water flow
Hi, Did you clean the screen inside the mixer valve or at the valve end of the hose at the wall (not always applies)? If the screen is clear and there is good pressure to the washer, you will need to change the inlet valve.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 30, 2009 | Kenmore 22422 Top Load Washer
Whirlpool GHW9100L Front Load Washer Logo
226 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
