Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Sony KF-50WE610 flahing red light (6 blinks)
The TV shuts off and the standby light blinks 6 times. I can unplug it for a few minutes and it will work for a short time once plugged back in.
Just replaced the thermal fuse (by a service tech guy -$149). Same problem happened as soon as he left.
Any ideas?
  • 1 more comment
  • Anonymous Dec 05, 2008
    same issue here .... read on other boards that a new G board is required.
  • karnold754 Dec 11, 2008
    I have the same problem Jeff. Did you find a solution?
  • jeffmorris1 Feb 03, 2009
    Hey, thanks for the tip... we had just about given up on doing anything with this TV and were about to go buy a new one- not something we wanted to do. I'll check out the Sony site and go from there. My repair shop had no clue and then told me $500 would motivate them to find an answer. Needless to say I took the set back.
    I'll let you know what happens.
    Thanks again!
Jeff, did you look at the Sony web site? They had a problem with 9 different TV models that were from 2003 and 2004, KF-42WE610, KF-50WE610, KF-60WE610 and 6 other models.
This is what it states: It haas come to our attention that a limited number of Grand WEGA rear projection TV's may exhibit warping to the lamp access door. In rare cases, some additional components may also become damaged as a result. and so on........
You probably have some components melted on the inside around the lamp. I have a 42 inch and I just replaced the lamp at Christmas and the door was melted shut. This is the second lamp that I have replaced, the door was starting to melt the first time. They never sent me anything about this problem, and as of today I am still trying to work something out with them. The repair shop who has it told me that it can't be repaired. The parts that are melted are not in stock and they don't make them anymore. They are supposed to get back with me and make me some kind of offer.
They will only fix this problem through March 31, 2009.
Posted on Feb 03, 2009
    Scholar:
  • 170 Answers
Bypass thermal fuse, and door switch. if you still have problems either replaced the G1 board. (Power Supply) or replace the bad ic labled mcz3001. sonys are know for this ic to be faulty.
Posted on Dec 16, 2010
No tv red blinking lights
Blinking of standby light are fault indications. How many times the standby light blinks at a time. Count it, and inform me.
Sep 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
50 inch kf-50we610 SONY TV blinking light
Thats usually caused by a regulator having failed.or could also be a wire cable not connected correctly. Troubleshooting the power supply will verify if the +17V line is missing
Dec 16, 2009 | Televison & Video
Sony KF-50WE610 Tv won't turn on, red light blinks 6 times
3 times means Lamp and 6 means you have lost a voltage. You may have a thermal fuse blown.
This set has a common trouble with overheating caused by the drum fan located on top of the lamp housing clogged up with dust. When the lamp is getting old it runs hotter and that combined with the fan being clogged the thermal fuse blows. You must replace the lamp and thermal fuse. You must also clean out or replace the lamp fan. This drum type fan should be cleaned out every year or two depending on the environment.
Apr 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony kf-60we610 stand by blinks 5 times
Hey there,
I've had my Sony KF-50WE610 for approx. 4years now and have just experienced the prob you described (though I didn't think to count the number of red blinks). I called Sony TV technical support (888-772-7669, #3 for TV/digital cameras, #1 for TV, then #1 again I think). They said that if the power/standby light blinks 5x, that means there's something wrong with the lamp driver and service will be required. Needless to say, I better go home and count my red blinks! Good luck, I hope this helps a bit. Have a happy and safe holiday!
Dec 09, 2008 | Sony XL-2100U Projector Lamp for...
TV shuts down and blinks red 6 times
Lamp or Fan is going bad.Take lamp out see if it looks good if so listen/watch to see if Fan keeps runningwhen turned on if Fan stops running ,Lamp and power will not come on.!
Nov 13, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Won't piwer on
Tried to turn it on? Sounds like you need to replace the lamp. However, I got an additional week out of my unit. Although poorly dimmed and the red Lamp light blinked constantly for that one week, at least it gave me enough warning to seek out a replacement. But so long as you're not mistaking the Power/Standby or Timer light for the Lamp light then I would have to agree with you. http://store.l-f-l.com/prod/A-1606-034-B Includes shipping to the United States and no sales tax outside of California.
Aug 16, 2007 | Sony XL-2100U Projector Lamp for...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
3,584 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
