No Display I tied to connect to external monitor plus changed the ram also still no display is coming . I have doubt about mother Board but i am un able to find it at reasonable price any body can help where i can find
    Scholar:
  • 135 Answers
Please do some test before changing anythings
1. Out your all rams from mother Bord then power on your system did some beep beep soud comes
2. When you press power button is you processor fan start working
3. Change your rams and try with other ram to start your system.
4. If you have another monitor then check out CPU on another monitor.
5. If you have any external video card then place it and check either it give display
Please follow the above test I hope you will get your problem if you can't then send me the above test result I will tell you you have problem in which device with the help of these test.
I hope it will help you let me know I can further help you regard this problem.
Regards
nidostyle
Posted on Nov 17, 2008
  • 40 Answers
Ebay has always been there for me but it is risky. Make sure you know what your bidding on. Do your research. Pricewatch.com is another. Also make sure the settings in your bios hasen't changed. Set all values to Default may also help. Hope this helps.
Come on screen but at that time when I press the menu all menu function come on screen but pc display not come. I change display cable & video board also but problem not solve.So, Pls. guide me. Thanks.
If again again display problem create then i suggest you change mother board and purchase own device supported mother board. If change mother board then display problem solved, but one step you change RAM may be your RAM device week and damage. So you first of all change RAM then finally change motherboard.
Thanks...
Oct 09, 2013 | LG 700M 17" CRT Monitor
Display ic motherboard
A> Check you Power all connection proper connected.
B> Check you SMPS power proper working or not.
C> If direct display not coming then sec option is external display card connect in mother board and check display come or not. if display come then you internal display cheap damage. If both option used or display no then you mother board problem.
D> Check you RAM, section if RAM problem then display no.
E> And finally one time mother board bios batter disconnect and few sec wait and re-connect bios batter. Remember batter disconnect before all power cut.
Thanks...
Aug 26, 2013 | Dell OptiPlex Computers & Internet
HI, My husbands Tecra A6 display went off, so i replaced the monitor - no difference - replaced motherboard - got beeps. Moved Ram - working but no display. I have checked all cables to do with monitor and...
From your story. I'm assuming that your connection ribbon mother board to the display is faulty. You can try to send the notebook to any service center and got it fixed.
Good luck ;)
Mar 04, 2011 | Toshiba Computers & Internet
When I turn on the power on my thinkpad the picture on the monitor is garbled and it's almost near impossible to get it ungarbled. It does it right when it starts up
connect an external monitor and check how is the display,if the display is fine on external monitor,then it would be your
LCD OR VIDEO CONNECTION OR CABLE NEED TO CHECK .
If you are getting the garbled picture on the external monitor also it could be
SHARED MEMORY AT FAULT( If the laptop uses shared video memory (part of the main memory is used for the video purposes), it's possible that you have a faulty RAM stick.)
OR
VIDEO CARD (if the video card is discrete replace take out that and check the video with integrated video card and if the video card is integrated then you have to replace the mother board)
Sep 17, 2010 | IBM ThinkPad A31 Notebook
My acer aspire one is working but not showing display it was totally black....
Connect the laptop to an external monitor to confirm that the system is worrking in perfect condition. If so then there is a possiblity that the LCD display is at fault.
1. Check using the external monitor for any errrors in the display drive. if so reinstall.
2. If not, there could be a possible break in the lines that go through the hinges. check the continuity of the connection from the mother board.
3. possible failure of the mother board/display drive. This might be expensive and so take help.
Helpful.
Aug 21, 2010 | Acer Aspire One PC Notebook
No Display on Mother Board
Have you try troubleshoot with working monitor, display card or your matherboard and processor,
Usually no display problem occur becouse of one hardware between monitor, ram, motherboard, displaycard and can be your processor problems.
You can try troubleshooting one by one of your computer hardware to get problem occur
Jul 21, 2010 | Intel Desktop Board D845WN Motherboard
HP Mini-1101 Atom 1.6GHz 10.1in 2GB 160GB Laptop.Its screen has turned green.Nothing visible. where could be the problem. Thanks
The problem could be with the monitor or the mother board. I would suggest you to take it to the Authorized Service Center.
Just to confirm, I would also suggest you to get the display connected to an external monitor. This could help you to confirm, whether the problem is with the monitor or the mother board. To do this
Connect a external monitor by fixing the wires to the display out and toggling the display from the laptop to the external monitor by pressing Fn + F5
Mar 11, 2010 | Computers & Internet
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
Computers & Internet Logo
43 people viewed this question
Alun Cox
David Payne
David Payne
