Question about Dynex 19 in. LCD Flat-Panel HDTV
19'' Dynex TV does not come up as a Computer Monitor.
I read the manual. Cable connected. Pressed both "fn" and "f4" at the same time. Computer (Compaq Presario Laptop) screen blanked. OK. But the Dynex TV screen stayed blank. Tried all the buttons on the TV Remote. No go. Pressed fn + f4 ... laptop screen back ... again, off ... again, back ... etc. Tv screen stayed blank.
This TV works fine for my DVD player. Channel TV too, though I don't care to watch it.
  • 4 more comments
  • Anonymous Nov 29, 2008
    I'm trying to connect a vga cable from my computer to my Dynex TV. It's not working.
  • bdmaher Jan 02, 2009
    I have the same problem but wit a 26" I have found it will display in safe mode but a get a mode not supported message when starting normally.
  • todlamb2 Jan 11, 2009
    When you say video driver, what are you refering to? I am working through the PC connection - when I try to bump up the resolution to what the TV should be capable, the tv goes black and gives me a message about 'the signal not being supported'
  • Anonymous Mar 29, 2009
    Same sa me but i have a 26" DYNEX LCD and mine says "NO SIGNAL"
  • Anonymous Apr 07, 2009
    I plug in to the Tv Via a VGA cable, then turn on my Presario, I get an error message saying VGA4 not supported.
    The solution is to reinstall the driver with TV connected (apparently), but no directions are given on how to do any of this.
    Please give step by step on how to solve the problem.
  • mon50cent May 02, 2009
    dvd player mode is not working, its says No Signal
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Posted on Jan 03, 2010
    Problem Solver:
  • 5 Answers
I had this same problem with the 19" model as well. I had to reinstall video driver with the tv hooked up in order for the resolutions to work properly. In order to do this I used an S-video cable which worked well enough to reinstall the video driver. I did not try safe mode which might have been easier, I just did not think of it at the time. With the video driver reinstalled while the TV is attached to my computer, I know enjoy a crisp 1440x900 screen resolution. Hope this helps.
Posted on Jan 06, 2009
How to fix no signal cable on laptop
Select Fn+ F4 (check 2 monitors) for check the change monitor . if not fix press with out FN.
if not fix go to display resolution and select dual display and duplicate .also select video dislpy LCD or VGA out to Both.
use user manual to more info
Oct 07, 2015 | Samsung Computers & Internet
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
When i connect my notebook to LCD TV with hdmi port, screen goes black but on TV "No signal" message appear and can`t view the monitor on TV. I have windows XP sp3 on the netbook HP 425
From page 47 of the user manual for the HP 425, "Press fn+f4 to switch the image between the display devices connected to the computer."
Press and hold the "fn" key on the keyboard of the laptop while pressing the F4 key to toggle the image between the laptop screen and the external monitor.
Thanks for using FixYa
Apr 23, 2011 | HEWLETT-PACKARD HP 425 WZ266UT Notebook
How do I get the HDMI connection on my HP Pavilion dv9000 to work. I have a HDMI connection on my Pioneer HD TV but I don't know how to get the connection on my computer to work. It there some trick I...
Normally the computer will detect that you have hooked in the HDMI cable and will automatically send an signal to the HDMI cable. It sounds like the "automagic" didn't work.
What you need to do is press fn+f4 to cycle the display mode to send a signal through the HDMI port. This works in a multi-mode way. You hold down fn and press f4 one time. Don't let go of fn and you should see a mode indicator on the laptop display. Each time you press f4 it will cycle to another mode. Depending on your specific configuration you might need to cycle through VGA first to get to HDMI.
Jan 09, 2010 | HP Pavilion dv9000z Notebook
I have an Acer Aspire 8930G trying to connect to my TV with HDMI
After you connected the HDMI Cable to the TV...Did you press the FN + F4 Key on the keyboard... The first screen you will see is the notebook screen is blank and the TV has got the desktop on top of it...The second time you press the FN + F4 then you will see thedesktop on the notebook and as well as the TV...The third time you press the FN+F4 you will see the desktop on the Notebook...
Aug 15, 2009 | Computers & Internet
No picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Feb 17, 2009 | Toshiba Computers & Internet
Connect computer HDMI to Projection TV HDMI to watch web TV
use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
Jan 28, 2009 | HP Pavilion dv6000z Notebook
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
Rely pc to tv
get yourself a s-video lead ...plug one end in pc and other in tv ( usually terminal with input/output rca jacks) audio / video jacks)
yellow white and red.
on pc press fn and f4 together (Usually f4 , look on the f keys and its the one with a square on it (usually blue colour)
assuming its f4 .....press fn and f4 together for laptop and tv monitor press fn/f4 again for tv mon only ....press fn/f4 again to return to pc only
Jun 25, 2008 | Compaq Pavilion ZT3280US Notebook
Dynex 19 in. LCD Flat-Panel HDTV Logo
7,327 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
