Question about Samsung SGH-X830 Cellular Phone
Samsung x830 Charger Port cracked
My charger port broke on my phone, so I bought a BAITAI Rechargeable Battery. I take out my battery and have it plugged in the wall while its charging, than put it back on my phone. Anyways, this only worked once, and than the thing broke (Made in China).
Is there anything else I can do?
Is there anyone in the United States, Houston, TX that can fix my port at a decent price?
Is there a better Recharge Battery Machine that I can buy?
  • 50 Answers
You can take your Samsung Phone for Repair to Dr. Cell Phone in Houston, TX. They do all kinds of Samsung Phone Repairs.
Posted on Apr 02, 2010
Broken charger port
You could use another phone of the same type to charge your battery there. Or a charged battery from another phone.
Dec 30, 2013 | Casio G-zone Commando
My phone will not charge. why is that
1) You have corrosion in the charging port and it is shorting it out. Remove battery and clean inside port hole with alcohol and a long bristle brush.
2) The charging port needs to me resoldered. That is a daily repair for my shop. the TWO OUTTER pins are the ones that do the charging the middle are for USB. Just reflow the solder, sometimes they have a crack in them where they bend down to solder into the board. in that case you will have to use a super fine wire to jump the pins where they are broken and solder them to the board. Not for everyone and you need magnification super small iron and flux to relow the solder. never add solder just reflow it with flux. i charger $25 in my shop.
Jan 12, 2013 | Samsung Galaxy Prevail
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
The charger slot on the phone does not work when plugged in, think it needs a new port
Why don't you use the charger to charge a similar phone or use a similar charger aside yours to charge your phone to see if it is the charger or the charging port.
If your charger charges a similar phone as yours, it means the charging port of your phone is bad.
But if it does not, the charger is the problem.
If it is the charging port, all you need to do is to replace the charging port and your phone will charge.
Take care.
Apr 21, 2010 | Samsung Instinct Cell Phone
Phone will not charge it has a new battery and charger
Try put the battery on a similar phone and charge with your new charger, if it charges, it means your new battery and charger are good.
The problem with the phone is the charging port, you will need to replace the charging port because it does not charge your phone battery anylonger.
Take care.
Apr 14, 2010 | Samsung BlackJack II Smartphone
My phone samsung d900 is charging up witout charger installed
The charging port on your D900 may be broken. Have you tried a different charger first?
You have 3 options when the charge port breaks.
1. get it repaired, under warranty if possible
2. Get a new D900
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on Ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Jun 03, 2009 | Samsung SGH-D900 Cellular Phone
Charger port seems faulty and wont take a charge SGH a 437
Umm, that means it was exposed to moisture or is water damaged.
The water dmage may have caused the charg port on you D900 to short out.
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay
Samsung SGH-D900 charging problem repair
Dec 04, 2008 | Samsung SGH-D900 Cellular Phone
Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
2. Get a new one
Samsung SGH-D900 will not charge problem
Aug 29, 2008 | Samsung D900i Cell Phone
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
Charger port problem
http://www.accessorygeeks.com/universal-travel-charger.html
or google BTC-UNI
iT'S little cheesy but hey for $10 and free shipping I can eat a lot of cheese.
Just plug your battery into this little clugy thing, plug the thing into the wall, wait until battery is charged and then put your battery back into your phone...presto...for this kind of money who cares if the VX9900 has a dead battery charge port.
I bought two, they were on sale for $7 each. It's ugly and takes a bit of patience but it works.
Feb 26, 2008 | LG enV VX9900 Cellular Phone
Samsung SGH-X830 Cellular Phone Logo
173 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
