Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
¿Could it work with 2 Cards RAM of 1G/800? ¿Could PC work with this mother board and 2 Cards RAM of 1G/800?
    President:
  • 2,351 Answers
That's a pretty big jumb from 667 to 800MHz. (Motherboard does not support 800MHz).
Manual says:
This motherboard accommodates two memory modules. It can support two 240-pin
DDR2 667/533/400. The total memory capacity is 2 GB.
Yet, ECS web site says it supports up to 4 GB.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
BIOS for 945GCT-M/1333 (PCB:3.x) version 08/07/18 does not include information pertaining to increased memory speed up to 800MHz. (Bios link).
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Bios&MenuID=44&LanID=0
Mike
Posted on Nov 17, 2008
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
INSTALLED NEW RAM UPGRADE TO BOOST FROM 1G TO 2G COMPUTER DOES NOT RECOGNIZE NEW RAM STILL SHOWS 1G.
Make sure it is the correct ram for your computer. If you just added one ram chip then try swapping them and make sure they have a tight fit.
To test the new chip replace the old one with it and turn on your machine. If it doesn't see it then it is either bad or not the correct one.
Let me know how it goes.
Dec 14, 2010 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Ram install problem
with RAM there can be a few problems
1) the frequency of ram which *********** board supports might be less than the freq at which the ram you are puttin works, hence in this case RAM wont work on this mother board and ull have to get the RAM replaced
2) some motherboards do not support a 2 x 1 GB RAM where as they might support a 1 X 2 RAM (if you do have 2 mem slots for ram)
and then there is the most trivial problem of the slot not being clean or arm not being put properly, i can think of ne other reason for the ram not working properly..
cheers
Kushal
Aug 21, 2008 | IBM NetVista PC Desktop
P23g PC Chip Mother Board and DDR2 Ram
probably your motherboard does not recognise the faster ram go to BIOS setup and check ram is set for auto
Jul 17, 2008 | PC Chips P23G Motherboard
ASUS P5N-E SLI
Try RAM with a different speed. My 800 mhz RAM didn't work until I installed 533 mhz RAM and adjusted to 800 mhz in BIOS. Newly built PC, default must be set as 533 mhz because I reset the CMOS and still couldn't POST to BIOS. Only taking out all RAM gave me any sort of audible error code. Luckily I found some 533 RAM before I RMA'd the board.
Jul 06, 2008 | ASUS P5N-E SLI Motherboard
Ram Compatability
just check the speed of the mother board for ram,if your ram speed is compatible with *********** board then you may have bad ram check it on another mother board
May 05, 2008 | Intel Desktop Board D845BG (KD845BGPAK10)...
P4VMM2 Motherboard problems with RAM Cards changing fron SDRAM to DDR
Depending on your version of motherboard, it may only take ddr when you change the motherboard jumpers, as i assume you have 2 SDRAM and 2 DDR slots, but you will need to refer to your manual
Apr 10, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
139 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
