Question about Microsoft Windows Vista Ultimate Edition
I want to open dll file which i downloaded from internet ?
I downloaded a theme which is dll but when i open it it shows download approapraite program from internet to open it
  • Justin Case
    Justin Case May 11, 2010
    Dear Imo,
    Char1ieJ is correct. A .dll file (Dynamic Link Library) is not something that you can execute or open in and of itself. It is meant to be referenced by an executable program. Whether this program should have accompanied your .dll file or was pre-existing is not something we can determine from the information you provided.
    As it stands, your best bet for advice remains unchanged. Make sure you downloaded to the correct location. Meaning double check the instructions that should have been made available from the download source. Then recheck your Themes selection.
    I would like for you to reconsider the 'Inappropriate' rating you gave Char1ieJ.
    This rating is worst type of insult. It can reduce rank and have a profoundly negative effect on an experts overall ratings. It should only be used in the rare case that the advice you received was totally irrelevant to the problem or outrightly profane in which case should be reported as abuse. Neither one of these was the case here. Your rating of Inappropriate was inappropriate.
    For the most part, Experts here volunteer their services. Their only compensation may be the satisfaction of helping others and pride in the ratings they receive.
    If you check his profile, you will find only one IA rating, yours. You blasted a lot of hard work and the reputation of someone that was trying to help you. I would think this is something you would want to rectify.
    Also keep in mind that Experts here pick you, not the other way around. An Asker who doles out IA's for helpful advice without any interaction, even as a mistake (which I think it must be) is unlikely to be helped by a second Expert.
    He pointed you in the right direction. He was being helpful with his advice. If you have additional questions or need clarification, we are happy to respond. Most problems cannot be solved without several question and answer volleys.
    If you provide a description with a higher level of detail, we can provide a better solution for you. If you comment back with questions, we can walk you right up to the Solutions door and knock for you.
    It depends on your level of commitment. Now it also depends on you either getting that IA removed or improved. Until then, you have the only solution you are likely to get. It's a Karma thing.
    I don't make the rules, I'm just letting you know you shot yourself in the foot.
    You know how to fix it.
    You know you should fix it.
    So Fix it.
    The balls in your court. Good luck.
    Mike258
  • Justin Case
    Thank You Imo,
    It may seem like a little thing to most folks. But it means a lot to us.
    The rating system here isn't the most intuitive. We take it for granted and sometimes forget it can be confusing for the people on the other side of our screens. Mistakes can be made too.
    Whatever happened, I try to think the best of people, give them the benefit of the doubt. Hence, my earlier post. Your response reinforces that belief.
    Your gesture was truly appreciated.
    Thank you again
    Mike
    Novelist:
  • 100 Answers
Themes are not just DLL files. It sounds like you may have received only part of the download. Try downloading the program again.
I hope this helps!
CharlieJ
Posted on Nov 17, 2008
  • Charlie Jarman
    Charlie Jarman Nov 17, 2008
    Not sure why you picked this as the best solution, but then rated it Inappropriate. ???
Can't install because sliprt.dll was not found
Open this website:www.dll-files.com/dllindex/dll-files.shtml?sliprt
Click DOWNLOAD ZIP-FILE button
Extract sliprt.dll from sliprt.zip. We recommend that you extract sliprt.dll to the installation directory of the program that is requesting sliprt.dll.
If that doesn't work, you will have to extract sliprt.dll to your system directory. By default, this is:
C:\Windows\System32 (Windows XP, Vista, 7)
The problem will be fixed.
If problem still occurs then use system utility tool Reginout for an instant fix.
Aug 06, 2012 | Adobe Systems Adobe Flash Player
I just downloaded this Vista theme for my Hp but it's saying there's no available application for it.
You must have downloaded a file file from the internet that is being called "Vista Theme". If this is true that its a file every file has an extension and requires proper application to run. There are many different types of files and this difference is marked by file extensions. Different files are different from each other because they have different extensions.
To run a file you need to know the file extension and have a related software to run it on your computer. How to find the file extension. Just right click the file and take the properties of it a window will open and show you the the file extension and if your lucky it will show an installed program on your PC that can run the file.
If you do not find a software indicated there you have to go to an internet search engine like Google.com or Yahoo.com. Type the file extension of the Vista theme there and augment with these key words FILE EXTENSION.
You will have access to the information that will tell you which program or application can run that particular file extension. Obtain or download that program or Application. Run it and enjoy!
Good Luck!
Jul 27, 2010 | Microsoft Windows Vista Home Basic Edition...
How should i install vista theme through net
i want free windows vista theme for xp... how to apply the theme
Aug 27, 2009 | Microsoft Windows Vista Ultimate Edition
How to install window vista theme?
it depends on what kind of file you downloaded...it can get tricky when you download themes, because sometimes you're actually downloading themes that HAVE to go through "windows blinds" program or such...so first, check what kind of file it is, if it's a .theme file than you're set, all you have to do is right click on the desktop, then click on properties, then on the first tab, click the little arrow next to where it says "themes" and go down to the buttom of the list where it says "browse" then simply find the file you downloaded (assuming it's .theme) and open it, then you can select it in the drop down box and click ok....your set.
Feb 05, 2009 | Microsoft Windows Vista Ultimate Edition
ConnAPI.DLL how do I re-install?
Open web page http://www.dll-files.com/dllindex/dll-files.shtml?connapi
Download the file. Remember location to save. Reinstall the Roxio software. When installation prompts for ConnAPI.dll file, show the path. Use the same procedure for the other dll files if necessary Search and download these files at http://www.dll-files.com/
Jan 01, 2009 | Roxio Easy CD & DVD Creator 6...
Google Chrome Theme
Google Crash Complain Free here - Gmail Is Up or Down
Dec 17, 2008 | Google Chrome
About installation of themes
Step 1: Download Windows Vista UxTheme patch.
How to install
1. Login as a user with Administrative privileges -or- have Administrative credentials ready (check under the keyboard for a slip of paper).
2. Navigate to %systemroot%\System32
3. Right-click uxtheme.dll and click properties.
4. Take ownership of the file and close dialogs.
5. Repeat steps 3 and 4 for themeui.dll and shsvcs.dll
6. Right-click uxtheme.dll and click properties.
7. Give yourself (or group) Full Control permissions and close dialogs.
8. Repeat steps 6 and 7 for themeui.dll and shsvcs.dll.
9. Rename uxtheme.dll to uxtheme.old.
10. Rename themeui.dll to themeui.old.
11. Rename shsvcs.dll to shsvcs.old.
12. Copy patched files into %systemroot%\System32
13. Reboot
Step 1b: If you find the above too intimidating, download VistaGlazz and just run it, it automates the whole patching process so you don’t have to worry about it!
Step 2: Download a Windows Vista Visual Style from a free Windows Vista Themes gallery, and copy the theme to Windows/Resources/Themes folder.
Step 3: Right click on desktop and click on Personalize. From the page that pops up, click on Theme and choose your newly installed theme!
Jul 13, 2008 | Microsoft Windows Vista Ultimate Edition
About themes
How to install
1. Login as a user with Administrative privileges -or- have Administrative credentials already.
13. Reboot the computer.
Step 1b: If you find the above too intimidating, download VistaGlazz and just run it, it automates the whole patching process so you don’t have to worry about it.
Step 2: Download a Windows Vista Theme and copy the theme to Windows/Resources/Themes folder.
I want vista theme
How to install
13. Reboot (yes, this is really required)
Jul 11, 2008 | Microsoft Windows Vista Ultimate Edition
XP Themes
i wanna full version themes for my desktops
Aug 24, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows Vista Ultimate Edition Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
