Question about Acer Aspire 5315 Notebook
The sound drags & vibrates. Very slow
Notebook plugged into electrical outlet. Any suggestions?
  • Jennifer Helms Apr 21, 2009
    I am also having this same problem. It first started when i played music or videos from youtube, itunes etc. Now it does it with ANY sound...rather it be systems sounds (clicks, aim, etc) or any music or anything. I am really getting frustrated. Is there some sort of fix for this? I googled the problem and there are several people with the same issue. I actually have an Acer Aspire One Mini Laptop.
  • 458 Answers
Run A Bios Update and Check If Your Audio Driver Is Updated...
Also Run MSCONFIG And Uncheck any unneeded Programs from running at startup/
Posted on Nov 17, 2008
Nuvo Essentia won't power up
First, try unplugging all of the sound system and plugging the amplifier into an outlet on a circuit that was not changed by the electrical work. Also, plug an outlet tester into the outlet you were using for the amplifier to make sure it is correctly wired. If one outlet in a system has hot and neutral reversed and others don't, this could cause problems with some designs.
If you are lucky, dirty power from sparking inside the circuit breaker crashed the control circuitry in the amp, and it just needs a hard reset (power disconnect/reconnect) to be made functional again. In the worst case, something got fried and you'll have to use instruments to track it down.
Apr 23, 2014 | Nuvo Essentia Amplifier
Sears Galaxy side by side refrigerator lights interior lights suddenly went dim and now the freezer side is making a low, slow sound like something is trying to work. Ice dispenser works but makes odd...
Your outlet may need replacing. I have been replacing all the outlets here, the installer did not attach the power wires to the screw on the outlet, he just jammed them into a hole in it, the lazy way.
Plug something into the same outlet, if it runs slow or dim, that's your problem.
Turn off the breaker before you mess with an outlet.
Nov 27, 2013 | Refrigerators
ELECTRICAL POWER DOES NOT SEEM TO WORK EVEN THOUGH PLUGGED IN
Try another outlet in your home. Or if it is plugged into a surge protector remove it for the surge and plug it directly into another outlet
Jun 11, 2009 | HP Compaq nc8000 Notebook
Dvd video running choppy and slow, but sound ok most of time
u should to clean the DVD-ROM & check if ur DVDs or CDS back is clear (there is no crashes on them)
Jun 08, 2009 | Acer Aspire 3690-2050 PC Notebook
Dryer won't start or it starts and runs for a minute or two only
When it does start does it seem to hesitate or have a louder hum than normal upon startup? Please write back with the model number and I can further assist you. The vibration from the dryer being on could be disconnecting the power behind the plug in the wall. turn off breaker to that dryer and make sure connections are good to the outlet...I have seen this happen before. If it seems slow to start when it does start and make a hesitating humming sound before it gets going your motor maybe going on overload and shutting off. Therefore you would need a new motor....please let me know...
May 12, 2009 | Whirlpool LER5636P Electric Dryer
My Whirlpool dryer LER3624EQ1 is overheating
If you open the dryer quick enough during a cycle, you will see the element glow. That's normal. It sounds like a belt problem. Something is causiing the drum to drag which will cause the belt not to turn as easy. This, in turn, will make the motor work harder and overamp as it is trying to move the belt but it is just sitting and spinning and burning the belt. Look for something like a rear drum bearing or tensioner pulley causing the problem. Continuity test just show that there is a complete circuit. This is confirmed by the element getting hot. Also, if you motor is not turning at the correct speed, this will slow down the amount of air being moved across the element. This will also cause excessive heating of the element.
Good luck and hope this helps.
Mar 01, 2009 | Whirlpool LER4634J Electric Dryer
Voice is dragging
Common problem. A friend's is giving him the silent treatment. Of all the reading I've done, it's related to a corrupted audio file. A reinstall of the system might help but a software update or firmware update most likely would provide a fix.
Apr 29, 2008 | Garmin StreetPilot C330 GPS Receiver
Its slow
Sounds like you need to re install windows. And maybe upgrade the amount on RAM in your machine.
Aug 17, 2007 | Gateway 40G / 40GB for laptops /...
Acer Aspire 5315 Notebook Logo
410 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
