Question about Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
Lost product key code
I had my computer restored and I found my installation disc for the older Roxio CD& DVD burning progrem but I can't find my envelope the disc came in with the key code to reinstall my program
  • JamieLing444 Dec 05, 2008
I have roxio in my pc,  when i click the icon, i get a message saying your last command could not be completed, an unknown error.
how to solve this problem
please help me
yogaraja62@yahoo.co.in
Posted on Nov 19, 2008
How do I install Roxio cd-dvd burning from a disc
Load the disc and should automatically go to "SETUP" if not them open the fiel manager and search that drive for "SETUP"
Jan 28, 2015 | Roxio Easy CD & DVD Burning for PC
Roxio burn exe file problem
I can't find the Roxio Burn on my computer. I keep using the shortcut on desktop, but it keeps popping up that the shortcut isn't useful if not installed. But it came installed on my computer when I bot the computer a month ago, and I have actually used it to burn a couple of cd's, but I can't locate it now. What is the problem?
May 01, 2010 | Roxio Easy CD Creator 5.3 for PC
DVDs I burn will not play on other players. Players reject disc
Check that the burner is finalizing the discs. This can be set in Roxio or in the optical drive properties. In Windows 7, right click on the optical drive, choose Properties, then the Recording tab. Then the Global settings lets you choose to finalize the disc on eject. Try a different brand of DVD+R and check that the other players support DVD+R discs. (I know some DVD players only support DVD-R.)
I hope this helps.
Apr 15, 2010 | Roxio Easy CD & DVD Burning
At the beginning of the install, it shows user name, computer system (mine is HP), then asks for serial #. Which one? I've tried all the numbers I could find on my computer and the Roxio install disc...
It wants the Roxio serial number. That should be on the box or inside on the CD envelope. It should be clearly labeled Serial number. Also if there are dashes or spaces in the serial number try putting them in one number after another with no dahses or spaces. Hope this helps.
Aug 01, 2009 | Roxio Easy VHS to DVD for PC
Roxio help
download the latest version of roxio viz roxio creator 10 (if you dont have it) .. disc copier is available in that..
Jul 10, 2009 | Roxio Easy CD & DVD Creator Platinum...
Roxio Cine Player Decoder Pack instalation package
Remove any older versions of Roxio or Sonic from the computer and do a clean install (uninstall then reinstall).
Mar 30, 2009 | Roxio Easy VHS to DVD for PC
My dvd +/- rw drive stopped working
You will need to download a decode programme such as power dvd or as i did vlc media player.(this was free)
Mar 07, 2009 | Roxio Easy CD & DVD Burning
I have roxio creator & my dvd 9.0 de ; how do i burn my movies
I am trying to burn a movie onto a dvd using Roxio easy cd & dvd burning. The problem is that when I do burn it, it burns as a data disc. I try other things on it and it says to use the disc copier application to burn a dvd. I have searched everywhere on this progmram and there is nothing that says disc copier.
Jan 19, 2009 | Roxio Easy CD & DVD Creator Platinum...
Lost key cde
astalavista.box.sk is a very good site, and all that I can tell you without comprising anything legal.
Nov 17, 2008 | Roxio Easy CD & DVD Creator 6...
EZCD 5.0 and EZCD 6.0
I don't think that 6 and 5 are compatible 6 is an upgrade from 5. I have just 5 on one of my old XP computers and it works fine, but that's all I have. I went to the website and they are not giving any support for Roxio 6 anymore.
I will tell you that Roxio Easy Media Creator is fantastic. The things you can do with that are unbelieveable. I got it at Sam's Club for about $70. But I know that does not solve your problem.
Roxio 5
To burn data files, Open project selector, make a data cd, click data cd project. WhenEasy CD Creator 5 opens and you choose your files to burn, try this: Select Disc at Once Radio button, click okay and click burn.
ID Number: 000008GN Products: General Information
OS: Issue When burning a CD or DVD, you receive an error, burning does not complete, or your media is rejected. Resolution Burning errors can happen for a variety of reasons. Roxio has found that doing the following steps resolves about 80% of all burning issues. Please give all these steps a try and see if it fixes your writing problems.
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. The media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  5. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  6. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Roxio 6
OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: EE6000132 Products: Easy CD Creator 6.x Platinum Suite
OS: Windows 98 Second Edition
Windows ME
Windows 2000 Professional
Windows XP Home Edition
Windows XP Professional Edition
Issue Roxio does not recognize the blank CD/DVD media in the recorder drive.
Resolution Follow the listed procedure to ensure that the CD/DVD media you are using is supported by your CD/DVD Recorder.
On Easy CD and DVD Creator:
  1. Open Creator Classic.
    1. Launch Roxio Easy CD & DVD Creator 6.
    2. Click on the Creator Classic icon.
  2. Check the supported media types.
    1. Click on Tools on the top left hand corner of the window, then select Drive Properties.
    2. Under the Devices section, click on your CD/DVD Recorder drive.
    3. Under Supported Media, click on down arrow to see a list of supported media your CD/DVD Recorder supports.
    4. Ensure that media type that you are using is listed here. If it is not listed then your CD/DVD Recorder does not support that type of media.
On Easy Media Creator:
  1. Launch Disc Information.
    1. Launch Roxio Creator Home menu.
    2. Click on the Tools tab, then select Disc Information.
    1. Under Supported Media, ensure the media type is listed.
    • Reboot.
I do know if you have Roxio5 you cannot installed Nero 6 InCD, not compatible. Other than all of the above, I have no more suggestions. I am really sorry, wish I could work on your computer to figure out the problem. This is my specialty. Reloading computer and figuring out problems. It is so much easier hands on.
Good Luck
Mar 30, 2008 | Roxio Easy CD & DVD Creator 6...
Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC Logo
191 people viewed this question
Top Roxio Computers & Internet Experts
Marvin
Marvin
Alun Cox
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
