Question about HP LaserJet 4 plus Printer
Hp laser jet 4 plus printer
The printer has starting loading the data from PDF files real slow and shutting down some times it takes 45 minites to print 80 pages. the PCL memory is 34 mbytes Thanks
  • richard pappas Dec 03, 2006
    the PDF file from Yahoo is 2.7 megs have the printer hooked up to a wireless network router no one else uses the printer
  • 624 Answers
Need some additional info: -Network based or connected direct to the workstation? -How big are the pdf files? -Has anything changed with the printer, workstation/server host?
Posted on Dec 03, 2006
  • tomj23 Dec 04, 2006
    My first suspicion is the wireless connection used to connect to your printer. As the signal strength drops so does the connection speed. One way to eliminate the signal strength as a factor is to temporarily move the router, printer and PC in the same room with no obstruction between.
    If that fixes the problem then you simply have too much distance and/or obstructions in the way. Directional antennas are the easiest way to fix that, signal boosters are more complex and expensive.
    If the problem does not go away I would suspect you might have some network or perhaps printer issues. Network issues would cause other problems such as long Internet download times and sluggish web page loads. If none of this works exactly how is your printer connected to the router and what type of router do you have?
SOURCE:
HP Laser Jet 4 Plus + PC Load Legal
PC Load Legal means that the printer has been sent a print job formatted for legal size paper and that is not what is currently loaded into the printer's input tray. So, either change the paper to legal or cancel the job in the printer, reconfigure the document on the computer for letter (or whatever is loaded into your printer), and send the job again.
Jan 22, 2013 | HP LaserJet 4 plus Printer
WHERE DO YOU REPLACE THE TONER CARTRIDGE IN HP COLOR LASER JET 4500N
Hi Mvsantora
If any help I dont know if you got the manual.
I have put a PDF files on my website for you to download.
hp color laser jet 4500n.
Hope it a help to you, You can download from this links.
Just click on the links it will download for you.
http://www.4all2sell.com/pdf/hp-color-laser-jet-4500n.pdf
you need a adobe reader to see this file If you not got a pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
All The Best: Pineworks
Jan 27, 2010 | HP Color LaserJet 4500n Printer
I have streaks on my print outs from hp laser jet
check your toner cartridge, check your fuser rollers and check your transfer roller assembly.
Sep 23, 2009 | HP LaserJet 4 plus Printer
My hp 2420 printer show me an error 49.2FD9
power on your printer, after you see processing data the second time, press cancel.
Everytime I have seen this error is because the user tries to print a PDF file that is corrupt.
This has worked for me in the past.
and look here:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1245403811282+28353475&threadId=74920
Jun 19, 2009 | HP LaserJet 2420 Printer
Laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Oct 18, 2008 | HP LaserJet 2430dtn Printer
Slow printing of Acrobat pdf files on HP Laserjet 1300
Ok this is simply because of the printer spooler and because PDF's are much larger that is why. Here are the instructions on how to print another way to print a little quicker.
Sep 26, 2008 | HP LaserJet 1300 Printer
Laser Jet 4 plus can't print with USB?
1.check the cable compatibility
2.install the driver HP laser jetIII
Sep 05, 2008 | HP LaserJet 4 plus Printer
Hp Laser jet 4 plus
Bad toner cartridge or fuser is burned out.
Aug 15, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
140 people viewed this question
Clive
Clive
Thomas F. Schneider
