Fusing Unit Replacement - IM3511
There was a paper jam in our office printer/copier and someone moved the fusing unit out to remove the paper. Now the fusing unit won't go back in. There is a small gray lever on the front side of the copier but the fusing unit won't push back inside far enough to relatch it in place.
    Problem Solver:
  • 18 Answers
Make sure all the covers/doors are open.at the fuser unit area.
Posted on Nov 27, 2008
Paper keeps jamming in my fs2100 kyocera
One possibility regarding paper jamming is the weight of the paper you're using. For example some printers have difficulty feeding 20 lb. paper. I suggest that you first try loading your printer with a lighter weight paper, starting with 12 lb. paper. If that works, then move up to 16 lb. paper. If that fails, then consider cleaning the rubber rollers that control the paper feed.
Nov 02, 2017 | Kyocera Office Equipment & Supplies
Sir ,ir 2020 paper jam at fusing unit.some times half of paper will come out,sometimes jams at the entrance of fusing unit.i changed every sensors,then changed new fusing unit,then feeding assembly...
Sometimes you can vlear a fuser jam with a manilla folder. Open the copier let it coll a bit and slide a manilla folder through the fusing unit. If it is just pieces of stuck paper the folder can sometimes push them out of yhe wsy ad you gorce it through and pull it out the other side. The fuser has two rolls one heat and one pressure both of these rolls have small fingers which are supposed to kerp paper from sticking to them. Sometimes these fingers get bent or damaged and this causes the actual jam. There is also an exit sensor that detects jams in this area it can have a damaged part as well
Jan 20, 2018 | Canon iR 2020i Laser Printer
AL1655CS Paper jammed in Fusing Unit. How to get it out?
If you can not remove it by flipping open the gate with all the teeth on it then you may have to remove the fusing unit. This is easily done by removing the 2 silver screws, one at each end of the fusing unit. Then the unit will just wiggle right out. This will give you better access to the top and bottom areas where the paper enters and exits. Then just re-install.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Sharp AL-1655CS Copier
The copy will print, but parts of the copy are smeared and can be wiped off with fingers leaving nothing on the copy in those areas.
Bad fusing unit. The fusing unit is the assembly that get hot and "fuses" the toner onto the paper just before the paper exits the machine. If you or someone you know is mechanically inclined you could replace the unit yourself. $150 to $180 for the fusing unit.
precisionroller.com has them. Part# R3200
Replacement consists of removing the back cover so you can unplus the wiring. The opening the right side door and removing 2 mounting screws.
Good Luck and Thank You for uning Fixya.
Jun 21, 2010 | Xerox WorkCentre XL2140df Laser Printer
Paper jams at fusing unit. It appears there is a
That sounds like part of the pressure roller. What color is the rubbery type obstruction? What brand of copier do you have? Which model number?
Nov 02, 2009 | Office Equipment & Supplies
Call for service
Cause The fusing JAM is not completely
removed. (Jam paper remains.)
Fusing unit installation failure
Check and remedy:
Check for jam paper in the fusing section.
(paper winding, etc.)
Check fusing unit installation.
Check the jam sensors in the fuser.
Aug 24, 2009 | Sharp AR-M237 Copier
Remove a paper jam under the fuser unit on a canon image runner 5070
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
Aug 17, 2009 | Canon imageRUNNER 5000 Copier
Message, paper jam
DON'T WORRY GENTLEMEN! FIRST U LOOK OUT THE PAPER IN FUSING UNIT & FEEDING UNIT ELSE CHECK FUSING- HOME POSITION SENSOR,REGISTRATION SENSOR,PICK UP SENSOR.I TELL CONFIDENTLY UR PROBLEM CLEAR..... BY......SELVA-SINGA.
Nov 25, 2008 | Canon ImageClass D880 Copier
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Jammed papler
inspect your fusing unit carefully, do not use any sharp things, you can damage the fusing roller. see that the sensor is moving fine, that the separator are OK, not broken.
if thats not helping and you wont find anything, last thing is remove back and side covers, carefully remove TBU, unhook the connectors and remove two screws in fuser sides and remove fusing unit to inspect it a little closer.and find the problem.
Mar 21, 2008 | Konica Minolta magicolor 2400 Laser...
151 people viewed this question
k24674
jasbo
jasbo
