Question about Admiral 24 in. DWUA651 Built-in Dishwasher
Armada dishwasher not working
There is power to the dishwasher, however; when you press the start button, nothing happens. The lights on the display are working but the dishwasher will not start. There seems to be a short in the push button panel
Dishwasher bottom part works top part all lights are on and wont work
I'm assuming its a fisher and paykel, you will certainly need more info. Do you have an led display or 3 buttons and lights. Any fault codes, flashing beeping when buttons are pressed etc. If everything is normal no unusual beeps lights etc but nothing AT ALL happens when you press start it is the door 'switch' which is actually a light that is reflected through a plastic prism and back to itself ( originates from the board) check the prism top right drawer frame. Just compare to working drawer. If not more info required.
Jul 07, 2013 | KitchenAid Dishwashers
Won't turn on
Try just pressing the selection pad, without pressing start/cancel and close the door. That has worked for me a couple of times.
May 05, 2010 | Frigidaire Professional Series 24 in....
No power to top draw?
No power to the top drawer needs to be verified.
Are you saying the lights are blank and when you press the start buttion nothing happens?
One reason the controller can shut the power is that the heater overload protection thermal resistor has opened. Unfortunately the only way to fix this is to replace the entire heater plate at the bottom of the drawer.
To confirm if the controller is operational or not, press Keylock and Start/ Pause button together for 5 sec (press Keylock first) and see if the Lights light up. If nothing happens then either the power has shutoff as mentioned above or controller is faulty.
Feb 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher will not start. The 3 second button light is on and when I press it nothing happens . I try pressing any other button and nothing works
It sounds like you have "locked" the dishwasher. This was an added feature that most people never wanted since it only seems to be set by accident.
Try pressing the 3 second button and holding it down for at least three seconds. This should turn the light off. Drove us nuts the first time it happened. If it doesn't turn off then I guess it is broken.
Jan 03, 2010 | Maytag MDB7100AWB Dishwasher
My dishwasher doesnt start
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Apr 22, 2009 | Ariston Technologies LL64WNA Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
All the lights are flashing on Maytag Quiet Series 300
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
Sep 23, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwashers Logo
107 people viewed this question
Top Admiral Dishwashers Experts
Paul Bade
Adam Truesdale
john h
Are you an Admiral Dishwasher Expert? Answer questions, earn points and help others
