Question about Hanns.G Corporation JW-199DPB 19" LCD Monitor
Monitor takes up to and over an hour to boot up !
In 3 days my I-INC IU191A 19" Monitor Warranty is up. For past week it has been taking longer and longer to boot up. The orange lite is on in the morning and when I turn my computer on it go's out. Now an hour or more later the Green light blinks for a few Min's and then the Monitor starts to work. I am waiting for I-INC to answer my emails but not holding my breath!
  • Steve Jones Mar 12, 2009
    Same issue here.. HN199D monitor, about 3 years old, and has worked great.. Medium duty at home, and I turn it off any time I remember, so it's probably been on for half the time! :-) Over the last month or so, it's gotten increasingly bad about doing "the flashy thing" where you can see it's trying to sync to the video, but it gives up and flashes off, over and over.
    I have mine attached to a KVM with about 12 servers hooked up to it, and my answer has been to keep switching to different sources 'till it comes up, but after reading this thread, I'm convinced that I'm just wasting effort, and the fix is just to WAIT. Today, I did just that - I decided just to wait after fighting with it for 10 minutes (off/on and switching sources), and after I left it alone, maybe 5 minutes later, it just came up...
    I bet it's a problem in the circuit that detects whether you're using the VGA or DVI connector, but I dont yet know how to fix..
    After I get a new (non HANNS-G) monitor, I may take this apart and have a look around for a bad cap in the power supply.. I dont know what else it could be.
    Sergeant:
  • 180 Answers
I think I'd hurry before that warranty up! Sounds like it's time for a new one
Posted on Sep 15, 2017
    Top Expert:
  • Hanns.G Corp... Master
  • 12,962 Answers
Sooner or later it will not work at all. Time to go shopping - not worth fixing. Go ebay for great prices on used/new units. eBayeBay
bunnydawg
  • 5158 Answers
SOURCE: hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Posted on Dec 18, 2008
  • 563 Answers
SOURCE: A couple of weeks ago the monitor would come on
This failure is caused by a semiconductor (perhaps a IC or Power transistor), as the part is getting worse, the display will taken longer to work. Unfortunately, today displays are getting cheaper and repairs on this kind of issue is not recomended. You may need to consider to get a new one.
Posted on Oct 09, 2009
Sphynkter
  • 221 Answers
SOURCE: The monitor starts up displaying no signal
This means that the monitor is not receiving a video signal from the computer. When it doesn't receive a signal, it goes to sleep. You should check to make sure that the video cable is tightly connected, and also, if you have another monitor around, connect the other monitor to the computer and see if it works. It's possible that your monitor has malfunctioned.
Posted on Mar 03, 2010
budmrtn
  • 11361 Answers
SOURCE: Hi, it seems I have
It may have dying power suply due to bad DC filter caps, you will need to inspect that first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 02, 2010
  • 1288 Answers
SOURCE: For the past few weeks
From the description you give, this sounds like a failure in the circuit board, normally the capacitors go and the thing refuses to power up, however, the fact it defaulted to a low resolution indicates that the actual board is in some way failing, possibly a damaged circuit, or component.
I would think it could be repaired and it may be a simple job for someone who can identify the failing component, however, I think that the cost of getting it repaired would outweigh the cost of replacement
Posted on Jun 22, 2011
All of a sudden X223w ghostly lines and fuzzyness when 1st turned on. Taking longer and longer to clear up. Have had the monitor for about 6 months. A few days ago this problem occurred and lasted for half...
This problem is caused by a defective power supply. The unit is still under warranty so you will need to contact Acer to get it serviced. We web site is www.Acer.com click on the service link and they will set up a return authorization for you. The normal repair time is 7-10 days including shipping times.
I hope this helps, if so please rate our solution.
Buddy
Corporate Compute
www.ccl-la.com
Jan 07, 2010 | Acer 22" X223w LCD Monitor
Monitor going to sleep after 5PM and other times during day.
first thing you can do is go into personal settings/ power management and set the screen time to eather stay up all the time, ajust it to your settings. second thing is to go into the bios and check to see if the setting are correct. making sure that its not overclocked and save the settings if these thing dont help then you will have to ship it out one other thing is, if this is the trial version of win7, then your 180 day trial is over that will cause the system to be shutting down all the time also
Dec 17, 2009 | Intel Motherboard
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
My HP vs19e flat panel monitor began taking longer and longer to come on and now it's hours. I'm afraid that one day it's not coming on at all. I have been leaving it on to keep from having to wait but...
Haven't run into this particular problem, but many have been able to fix their monitors that won't come on with my tutorial. See the link below:
http://boredprojects.blogspot.com/2009/09/hpvs19e-monitor-fix.html
Sep 25, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Trying to find out if this ACER monitor is under warranty
Your monitor is still under the 3-year warranty. Go to this Acer website https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
to begin the process. Hope this helps.
Jul 09, 2009 | Acer AL2216WBD LCD Monitor
Monitor takes a long time to wake up
replace 2 caps 1000uf each 16 volt
I purchased 5 of these babies (new) at the same time and 3 of them had this problem
Sep 25, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
No image
Sounds like the monitor power supply may be faulty or noisy - most probable cause is that it needs the capacitors changing. If it has an external supply try changing it as that is a cheap fix worth a gamble - if power is internal then change the monitor.
Jul 23, 2017 | Samsung SyncMaster 930BF 19" LCD Monitor
Output flicks very heavily
Speak to HP/Compaq they will be able to advise. They are usually pretty good with hardware faults. You probably have a three year warranty on it so take advantage. Your mobile phone is not by your pc or any other wireless phone?
Feb 27, 2008 | HP f1905 19" Flat Panel LCD Monitor
Hanns.G Corporation JW-199DPB 19" LCD Monitor Logo
94 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
