Microboards orbit II duplicator problem
I have a orbit II duplicator that has started to read reject when it attempts to burn. I Have tried numerous cd's and can burn them in my other burner just fine wondering if it could be a bad burner in the orbit II
thanks
3 Suggested Answers
SOURCE: Primera Bravo II
This is not an official solution from Primera by any means, but I find the easiest thing to do is change the drive yourself.
***Do This Only When Your Warranty Is Expired***
This will void out any active warranty but it also is a solution to the problem many of you might have.
Carefully open up the system and replace the burner with a new one. Burners go bad, its a known fact, whether its inside a robot or not. Several thousands of burns tend to lend heavy wear and tear on the system. If you are like me, you are probably making hundreds of copies at a time.
Since PTPublisher lets you use any drive on the system you know its not wired into the robot, :) Hope this helps someone as it helped me.
Posted on May 12, 2008
  • 297 Answers
SOURCE: microboards orbit 2 cd copier Flash R W Error Problems
The mechanism of player is need to clean,that the error will flash .if clean that the performance will be back again.rate me as fixya..
Posted on Jun 19, 2008
SOURCE: Microboards ORPDV-1000-02 Orbit Pro DVD Duplicator
my duplicator keeps on giving this info ''fatal error'' whenever i put it ON kindly assist asap
Posted on Jul 01, 2011
Target drive not ready
This message means that the burning drives are not recognizing the blank media. There are a few things to try and remedy this though the unit may need repaired.
First, try using all of the duplicator bays by burning to another drive bay. If all other drives burn fine then the one drive may need to be replaced.
2nd, try a different blank CD or using a different brand. The most common fault for this message is a bad blank disk.
3rd, It is OK per Microboards to open the unit and check for a loose drive cable. A loose cable can cause this error too.
Finally, try cleaning the drive bays by using compressed air to blow any dust out of the system.
If the error still continues then call Microboards tech support at 952 556 1639 to set up a repair.
Apr 15, 2013 | MicroBoards (DSRDVDD882) Burner
Microboards DX1 input problems
Microboards' New DX-1 Disc Publisher to Ship Microboards’ New Print & Burn DVD/CD Duplicator Ships
Industrial quality of DX-2 and Print Factory in a Compact Package with the DX-1
Chanhassen, MN, August 17, 2004 —Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
You've got an expensive unit (see below for Press Release), with a built-in CD/DVD reader/writer.
Given that your unit could be six years old, it's possible that the reader/writer has "died".
It seems to be a "stand-alone" unit -- not something that requires either Mac OSx or Windows XP/Vista/7 to operate.
I'm guessing that _ANY_ IDE (not 'SATA') HP-brand reader/writer, provided that it has a "LightScribe" capability, could be purchased, and could be inserted to replace the "dead" reader/writer. For about $100, it's worthwhile to try this "substitution" to revive your unit.
____________________________
Chanhassen, MN, August 17, 2004 — Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
Jun 10, 2010 | MicroBoards DX-1 Publisher Printer
How to program an orbit sprinkler system for model number 57881
In case you are looking for the actual programming instructions these are available from the Orbit website.
http://www.orbitonline.com/lib/media/57880-31rA_005316.pdf
User Instructions
http://www.orbitonline.com/lib/media/57880-24rB_005637.pdf
Tutorial
http://www.orbitonline.com/tutorials/6station.cfm
If you already have the instructions but are not clear how to start, then please post a comment if you need specific help.
May 20, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
MICROBOARDS PRINTER LANGUAGE MONITOR........UNABLE TO READ DEVICEID......................this is the error i get when trying to print to my Microboards GX auto printer
The Microboards G3 is the worst duplicator I have ever owned. It has worked a total of 4 times, no response from the company, software is terrible and faulty and I'm pretty much over it. Good luck.
May 17, 2010 | MicroBoards GX-1 50 Disc DVD/CD Publisher...
Microboards pf pro refill cartridge
you can now get continuous inking systems for the microboards pf-pro machines
see here:
http://www.jpldisplays.com.au/catalog/product_info.php?products_id=4150
Mar 17, 2010 | Microboards PF-3 Print Factory Printer and...
Looking for manual Orbit Watermaster 57012 Controller.
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57004-57006-57008-57012-before-2002-Sprinkler-Controller-Owners-Manual.pdf
Jan 10, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
Microboards DX 2 DVD Publisher
May just be the type or mil/thickness of the labels on the cds. Try buying stick on labels and and putting them on prior to burning. They are only $6 at walmart for 20. This will tell you if it is an internal issue or if it is a mil issue
Dec 13, 2008 | MicroBoards DX2 CD 52x Publisher (E01024)...
Microboards orbit 2 cd copier Flash R W Error Problems
Jun 19, 2008 | Computers & Internet
Rejected discs
I had the same problem, with rejections getting more and more frequent. In the end replacing the DVD burners fixed the problem. Apparently, the red lasers that burn the cd surface fade with use. They are still fine reading the disk at low power, but burning at high power becomes progressively more hit-and-miss.
Jan 08, 2007 | Rimage 2000i CDR 2 (52X), CD Duplicator...
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
