Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Whirlpool Twin Thin - Water Leak
There is a leak coming from the front center of the washer and it seems that I have to remove the dryer on top to loosen the top cover of the washer and remove the front cover. Is this correct? I cant find the manual on-line for free. Is there such a website?
  • DPHAUL Mar 05, 2009
    I have the same problem but is there any way to get inside the washer without moving it?
  • 370 Answers
It sounds like you have a bad pump. If the bottom of the washer is not solid just lean it back and take the pump off. There should be a streak of water stains on the inside of the pump if it is bad.
Posted on Nov 17, 2008
It leaks in the front when filling
The most common part that leaks is the drain pump. Remove the two screws at the bottom edge of the front of the washer panel. Then with both hands slap the front panel in a downward motion to remove it. You will then be able to see where the water leak is coming from. Start a wash cycle and look for the leak. keep your hands and curious pets out of there while the panel is off and washer is running. turn off the breaker or unplug the unit if you step away from the machine and leave the panel off. If it is in fact the pump that's leaking it's very easy to replace. As you can now see, Just two clips and two hoses. Here's the part http://www.repairclinic.com/PartDetail/Drain-Pump/3363892/2406?ss=c36-x776574333330307871&mr=1
Hope this helps. Good luck,
John
Mar 22, 2015 | Whirlpool Thin Twin Washer and Electric...
Water leaks as you fill it
The most common part that leaks is the drain pump. Remove the two screws at the bottom edge of the front of the washer panel. Then with both hands slap the front panel in a downward motion to remove it. You will then be able to see where the water leak is coming from. Start a wash cycle and look for the leak. keep your hands and curious pets out of there while the panel is off and washer is running. turn off the breaker or unplug the unit if you step away from the machine and leave the panel off. If it is in fact the pump that's leaking it's very easy to replace. As you can now see, Just two clips and two hoses. Here's the parthttp://www.repairclinic.com/PartDetail/Drain-Pump/3363892/2406?ss=c36-x776574333330307871&mr=1Hope this helps. Good luck,
John
I need to replace lid switch on Whirlpool Thin Twin washer/dryer unit. How do I get the switch out and the new one in
The 3 screws across the front of the slanted panel need to be removed, then the panel. At the left and right rear of the main washer top are 2 5/16" screws, these need to be removed, there is a loose fitting steel clip through a slot on the main top these are holding down, when the 5/16" screws are removed slide the entire top forward and it will release from the front fixed clips. Unplug the lid switch unit and the main top can be set aside to replace the switch. Pleazer Appliance...
Jan 14, 2015 | Whirlpool Thin Twin Washer and Electric...
Why doesn't my whirlpool thin twin fill up with enough water to was a large load?
No cannot over ride set at large doe the machine fill to a certain level then stop if so operating correctly if it never stops filling with water then there is a leak in the fill system either a hole in pressure switch hose it popped off tub or water leaking out thru drain system pump or siphoning thru hose again if unit starts to agitate there is enough water in unit per design
Aug 21, 2014 | Whirlpool Thin Twin Washer and Electric...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin YLTE6234DQ2 washer is leaking water from the bottom. I need to remove the front panel to see what the problem is but can't seem to get it off. I have looked at suggestions to push in...
have you looked near the bottom of the front panel near the floor,there are 2 or 3 screws located at a 45 degree upward angle(to hide them from view) so they dont show,remove these and the front should hinge upward like an auto hood and the clips near the top should let go when its raised far enough upward
Apr 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Jul 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Water leaking from stacker unit
No parts are replaceable within the pump. Buy a new pump.
Jun 22, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
453 people viewed this question
Dan Webster
Dan Webster
Sal De
