Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Whe I push the wall mounted button the opener just hums
3 months ago I had an outfit work on this opener. They replaced gear kit adjusted limits and replaced capacitor. It has worked fine till now.
Any help would be Great..Thank you..Bob Bilbrey
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    Is the traveler all the way up to the bolt at the powerhead?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Sound like the "outfit" that worked on your operator did not change the bottom bushing on your motor mounting plate. Some "outfits" only change the white gear #41A2817 and some change the gear shaft assy. #41C4220A without changing the bottom bushing.
Posted on Jan 04, 2009
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
The motor runs but the chain does not move, we just had it worked on 1 month ago and now this, please help
IF THE MOTOR IS JAMMED (JUST HUMS) LOOSEN THE CHAIN AND ADJUST THE LIMITS AND TIGHTEN CHAIN.
IF THE MOTOR ACTUALLY RUNS AND THE CHAIN DOES NOT MOVE THE DRIVE GEARS NEED TO BE REPLACED. THEY SELL A KIT THAT INCLUDES THE BUSHINGS AND SHAFT. DO NOT BUY THE SMALLER KIT AND DO NOT REPLACE ONLY ONE GEAR (THE OLDER WORN GEAR WILL CHEW UP THE NEW GEAR) THIS MAY BE WHAT YOU HAD DONE - IF SO CALL THE SERVICE GUY THAT DID THE POOR REPAIR AND HE SHOULD REPLACE BOTH GEARS UNDER HIS SERVICE WARRANTY. ANYONE WORKING ON THESE SHOULD KNOW BETTER.
GOOD LUCK.
STEVE
Dec 14, 2014 | Sears Craftsman 13953754 Wireless Garage...
Garage opener try to close door when door at close position
There are upper and lower limit settings, it sounds like you have the lower limit set to low. Adjust it so it stops the door as it contacts the floor and see if this solves the problem. It is possible these limit controls are damaged and will not stay set. If that is the case it may be best to replace the opener if you cannot find a replacement.
Apr 06, 2014 | liftmaster Chamberlain Garage Door Opener...
Bought a brand new Williams wall heater a month ago "converted" for propane. It worked great for aprox a month now it wont come on. The piliot is lit but just wont come on?
check thurmostat. check low voltage. check limit switch there may be several.limits should be closed. I usually push re set first, if there is a click,then switch was open.limits trip when they get too hot.is this ventless? is the vent o-k?
Dec 23, 2010 | Heating & Cooling
Garage door does not open or close
You have a stripped drive gear. Remove the cover from the motor unit and you will find white sawdust all over. The part number for the gear kit is 41A2817 and is available at any good door opener service company. It comes with instructions.
Feb 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlin Series 1100 Garage Door Opener will not move over 1 Ft
replaced gears on my neighbors and had same problem< took cover off of limit switches and found a switch had a bent arm. straightened it and all worked good.
Dec 31, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlin Liftmaster 2245 won't open or close, just hums
If your door is stuck in the open position you need to see if the trolley is jammed against the bolt just in front of the motor unit. If it is, loosen the chain enough to remove the tension from the trolley. Run the motor until the door closes and then locate the 'up limit' on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Oct 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Wall Control Button not working after replacing gear
Check wiring back to unit to make sure it's not shorted or broken. You can also reset the garage door opener by unplugging it for a few minutes and plugging it back in.
Apr 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
98 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
