Panasonic DMR-E95HS DVD Recorder
Problem for Panasonic DMR-E95HS DVD Recorder
Self check for no reason - always
By Pitt on Dec 22, 2006
Any action requested triggers a self check that goes on and on, always starts over and over again, with no apparant reason. Pushing the ON button on the machine for 10 seconds after some time puts the machine back in operation. This does not work with the remote.
Consequently, usage of my universal remote is impaired.
Any ideas whta this might be?
Same Problem
Feb 11, 2008
-   I have found a solution. See Ebay, Panasonic DVD recorders 3rd page for
DVD recorder REPAIRS. He fixed mine for a very reasonable charge and it works a treat. Great service too! Barney 6779-   barney6779
Dec 31, 2007
-   I have the same problem. The unit is permanently stuck in self check mode. Pressing off button displays 'bye', but when you start again its stuck in self check. Any ideas?-   sanrho
Best Solution
posted on Feb 11, 2008
Very Helpful)
barney6779
Rank: Apprentice
Rating: 100%, 1 votes
See my comments above. The solution really works. barney6779
Was this helpful?
Yes
No
Solution #2
posted on Jan 01, 2007
Helpful)
henlopen
Rank: Wiz
Rating: 84%, 650 votes
First thing I would do is unplug this unit for about 30 seconds and see if that clears up the problem. If it does then the microcontroller was probably just stuck in a loop and all confused. If you still have the problem after doing this, it will probably have to go to a professional repair shop or authorized panasonic service center for repair. I would guess that bad capacitor(s) in the power supply lines going to the logic section of the main PCB could cause the symptoms you're experiencing. Good Luck.
Was this helpful?
Yes
No
Solution #3
posted on Jan 03, 2008
Helpful)
sanrho
Rank: Apprentice
Rating: 85%, 2 votes
Hi, I took advice from this site and changed a 5 pin regulator chip on the Power supply board; STR-G6353. The chip cost £6.33 + £4.99pp +Vat from Nikko Electronics.
This unit cost me £500. I don't think I will be buying Panasonic again. Note, I also tried resoldering the joints before changing the chip. It made no difference. Seems the chip had genuinely blown. Possibly due to heat dissipation issue, suggest adding extra heat sink to stop issue reoccuring.
Was this helpful?
Yes
No
Solution #4
posted on Sep 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I fix 3 e95h using the str g6353.
Popular Solutions for Panasonic DMR-E95HS DVD
Questions and Unsolved Problems for Panasonic DMR-E95HS DVD
Do you recommend Panasonic DMR-E95HS DVD Recorder?
Answer
Answer
it keeps saying self check on the model dmr-e95h
Answer
I have Problem for Panasonic DMR-E95H DVD Recorder Self check for no reason - always.can you help... (More)
Answer
Hello, Out of the blue my Panasonic DMR-895H stopped receiving audio to my HDD drive. I went away... (More)
Answer
self check stays on all day. Help!!
Answer
Same recording problem as other poster. It seems somehow tied to the program schedule or time... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in , HI
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
