Question about Insignia LCDTV26 26 in. Television
Tv won't turn on
When you hit the power button the tv won't turn on and the red light blinks what is the problem and what should I do.
  • bunnyloesche Nov 17, 2008
    Mine too. I have a Panasonic HDTV. I would love to find the solution. It worked great yesterday, turned it off to go to bed and it's not working now.
  • idsay1 Nov 30, 2008
    insignia 42 inch plasma just turned off for no reason and now` when I try to turn it on the green light is on for a second then I hear a click and the red light comes on again....... argh!!
  • Insignia Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
I have a 2003 sony kp51ws500 television and there's a timer on the tv and it won't turn on. A red light blinks 6 times then nothing happens. I unplugged, I hit the reset button, nothing happen
read the instruction manual and see how to operate.
if the timer is for to sleep, the problem will be the IC associates with him, you must see the block diagram and w.diagram. and tracking the signal.
go to www. retrevo.com and download the diagram. God bless you
Jul 31, 2012 | Sony Televison & Video
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Need codes for a AKARI 14" color TV IC-1494RAK
1. Turn TV on
2. Press TV key on remote.
3, Press and Hold magic button until red light blinks twice, it will blink once and then twice.
4. enter 991 red light will blink twice
5. Hit the power button
6. Aim the remote at the TV and press the channel plus button until the TV turns off.
7. Hit the magic button as soon as the TV turns off to store the code.
Hope this works for you!
Jan 03, 2009 | One For All URC 7740 Remote Control
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Trisonic ts-rc488
OK EVERYONE I FOUND ALL YOUR ANSWERS , IM JOHN FROM NEW JERSEY JAC1NJ@AOL.COM , FOR THE TRISONIC UNIVERSAL REMOTE CONTROL , TC-RC488 AND MAYBE OTHERS , INSTEAD OF THE CODES THIS IS EASIER,TURN ON THE TV OR VCR ETC. FOR THE POWER MUST BE ON WHILE DOING THIS PROCEDURE , PRESS THE YELLOW SET UP BUTTON AND THE DEVICE KEY U WANT SUCH AS TV1 OR VCR1 AND HOLD THEM BOTH DOWN UNTIL THE RED LIGHT ON UR REMOTE STAYS ON THEN IMMEDIATELY AFTER HIT THE YELLOW SETUP BUTTON AGAIN UNTIL UR RED LIGHT STARTS BLINKING THEN POINT THE REMOTE AT YOUR TV OR VCR AND KEEP HITTING THE RED POWER BUTTON AS THEN YOUR REMOTE IS TRYING TO FIND A CODE AND WILL EVENTUALLY FIND A CODE , AND YOUR TV OR VCR WILL SHUT OFF , THEN THE RED LIGHT WILL BLINK LET IT BLINK UNTIL IT GOES TOTALLY OFF, THEN HIT THE POWER BUTTON AND YOUR REMOTE SHOULD WORK , SOMETIMES YOU HAVE TO HIT THE DEVICE KEY AND YELLOW SETUP KEY SEPARTELY AND THEN THE RED POWER BUTTON, I CALLED TRISONIC AND ACTUALLY HE HELPED ME AND I HELPED HIM , HE SAID I SHOULD WORK FOR TRISONIC , THIS IS A QUICK SEARCH , NOT REQUIRING ANY CODE NUMBERS, HOPE I HELPED YOU ALL SINCERELY , JOHN A.CLINE , CHECK OUT MY LIST OF LYRIC BOOKS AND MUSIC AT WORDCLAY.COM BYE!!!!!!!!!!!!!!!!
Aug 19, 2007 | Trisonic TS-1666RFS Remote Control
Insignia LCDTV26 26 in. Television Logo
181 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
