Question about Panasonic PV-DF2004 20 in. TV/VCR/DVD Combo
Lost the remote
I have cable hooked up, how can I change the the antenna to catv so i can get all my cable channels on this tv
    President:
  • 1,284 Answers
Without the Panasonic remote you can not get to those features to program these sets. I have included a link to purchase a replacement remote control. They aren't expensive and much easier to use than a universal remote. Please take a moment to rate my answer. Thanks...
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=pvdf2004&uuid=12592148630250
Posted on Nov 26, 2009
Model VR-4625 wont pick up any channels with auto scan
Look to see correctly hooked and that in the menu the set is now not set to catv or cable but to air/antenna. If no antenna connected to set or if just indoor antenna you may not pickup on auto search--try to direct enter a known channel with the remote--if you get one you can in the set menu manually add to the memory the set has.
Nov 06, 2012 | Westinghouse LTV-19w6 Television
Insignia channel auto scan
If its cable and requires a box the set will have to be on a specific channel---if directly from wall etc go into set menu and make sure it is set to CATV or cable----if in air or antenna it will not save channels.
Jun 13, 2012 | Televison & Video
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Cable):
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
VOL-
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
And here is the manual if you need .
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Good luck and please rate
Sep 24, 2009 | RCA TruFlat 27F520T 27" TV
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Sep 12, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Can't change TV to CATV mode
You must unplug the cable connecting the television and the cable box. Then turn the television off and then back on. Do not turn the cable box off or disconnect the cable in wire from the cable box especially if you use Cable Vision. It will take up to 20 minutes before the box comes back on. Now turn the television back on. When you access the Channel System menu, you have the access to the submenu choices. Change the Antenna option to CATV and the Current Channel to 3. Reconnect the cable box to the TV.
Also those that are having problems with the TV turning off periodically, make sure the sleep mode option does not have a number in it. For example, if the number is 10, it will turn off every 10 minutes.
Sep 05, 2009 | Memorex MT2206 TV
Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Jun 22, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dont know how to get cable channels , i just get local channels.
Hello.
It sounds like you need to change a setting before running the auto or channel scan. On the same menu screen that has the option for running the channel scan, you should see a setting that has next to it the word "AIR" or "ANTENNA". If this isn't changed to "CABLE" or "CATV" then the TV will only scan for a limited number of channels because it assumes you have an antenna hooked up to it instead of a cable line. This is the same for all TVs. Anytime someone runs a channel scan on ANY TV and they only pick up a limited number of channels, they need to change the setting I've described. And remember, it will be on the same menu screen that you go to in order to run the channel scan.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
P.S. On some TVs, autoscan is called autoprogram.
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have no ''tv/catv'' button on my Philips universal remote
You can go here to see if you can get a new factory remote
TV Parts Universal TV Stands DLP Chips ShopJimmy or you can get a Harmony remote that will never go obsolete no matter how many times you change Tv's in the future or add components to your system
Oct 12, 2017 | Philips Magnavox Learning Universal Remote
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
TV in 5th Wheel Camper does not work when hooked up to cable
is there a setting to change to CATV vs off air ?
Jan 07, 2009 | Jensen TS2050J 20" TV
Panasonic PV-DF2004 20 in. TV/VCR/DVD Combo Logo
397 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
