Question about Coleman Powermate Premium Plus 6250W Portable Generator
Engine surge up and down
Have coleman powermate maxa 5000er generator that the engine surges up and down
    Problem Solver:
  • 15 Answers
Cleaned the carb again and set idle stop screw up
Posted on Nov 18, 2008
  • Gordon Willoughby
    Gordon Willoughby Jul 22, 2014
    I had the same trouble but cleaning the carb didn't fix it. I took the float out and shook it. Something was inside so i replaced it. Problem solved.
I have a coleman maxa 5000 generator no spark
first look at the oil level some generators have a low oil shut off then remove the front cover of the engine and unplug the small wire on the side of the coil then try to start it if you get spark back the its a wire problem if still no spark then the coil is bad
Aug 15, 2012 | Coleman Powermate Powermate 5000W...
Serges up and down and stalls after a fes coleman maxa 5000 er plus
Hi mxdidit,
Surging is generally caused by carburetor problems. Squirt some carb cleaner in it and see if that helps it at all. If that helps but does not do a lot, then the carb probably needs to be rebuilt. The carb could also just need some adjusting. Check for fuel leaks around the carb and also be sure the air filter is clean.
Good luck.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 10, 2011 | Coleman Powermate Premium Plus 6250W...
Coleman 5000 watt generator Tecumseh 10 hp engine. Surging r.p.m. Carburetor has been gone through 2 times, and still not correct. Any information will help!!!
it's running lean.....try resetting the choke partially when it begins to surge.....not completely closed, but enough to richen the fuel mixture (that's all a choke does btw..)
if that helps or clears the problem, your carb is outta whack.....cheaper to buy a new carb than keep taking back into the shop.
Jan 07, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 3000 surging
Check your air filter to make sure it is clean, especially if the gen. has been run in dirty, dusty conditions. Make sure the gas tank vent is not clogged.
Also, pour some combustion cleaner into the carb. through the air intake to clean the carb. It sounds like it is starving for gas.
Hope this helps.
Rob
Sep 27, 2009 | Coleman Powermate Premium Plus 6250W...
Surging 5000w Coleman Generator
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
May 08, 2009 | Coleman Powermate Powermate 5000W...
Coleman 6875, Does it have an auto idle???
If you've got an auto idle function you'll also have a switch somewhere to shut it off, so look for that first.
Engine surging is almost always a problem somewhere in either the air cleaner or the carb. Check the air cleaner, if it's not dirty take the bowl off the carb and look for dirt in the bottom.
Regards,
Carl
Feb 02, 2009 | Coleman Powermate Powermate 5000W...
No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Coleman generator OHV3000
The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
Sep 10, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
1,121 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
