Question about Sanyo DS31520 31" TV
Sanyo DS31520- high pitched whine, picture is fine
32" tv, about 4 years old. Picture is great, but there is an annoying high pitched whine, that seems to be involving the area where the video imputs ect go. If you move them around or bang the TV, it sometimes stops for a while. Any suggestions as to what is causing it, and could it be repaired by a handy person? Thanks!
  • 143 Answers
Sounds like bad solder connections on ground of the inputs radioshack has a cheep solred gun and solder make sure set is unpluged
Posted on Nov 02, 2007
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
I have a Samsung DLPTV, picture is fine. There is a "whining" noise associated with the TV the whole time its on. Stops as TV shuts down, It's about 4 years old and have not replaced lamp. Could this be...
Google your model number; I suspect it is a bad color wheel--lots of these sets have a fan like noise or even a grinding sound sometimes called a high pitched whine.
The part can be customer replaceable and YOUTube has actual video instructions for its replacement.
Let me know if you have questions as I am here to help.
SD TECH---Steve
Jun 08, 2010 | Samsung DLP HL-P5663W 56" TV
The picture is taking longer and longer to come on. It's not a consistent length, last night had it on several hours, it was off for an hour and a half, turned it back on and it took over 90 seconds for...
if you can get another one for a reasonable i would certainly consider that. the cost to get these lcd's fixed sometimes is not worth it. you seem to have more than one problem with the set.
Oct 30, 2009 | Zenith C32V37 32" TV
Rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
Jun 17, 2009 | RCA HD52W59 HDTV Projection Television
My TV won't turn on.
warranty.once you tamper with it,it is void.
besides there is 30000 volts in there and it is dangerous.
the picture tube stores the high voltage,and is there even unplugged
Apr 18, 2009 | Sanyo DS31520 31" TV
Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Apr 21, 2008 | Sanyo DS31520 31" TV
An Annoying High Pitch Sound
Can be either noisey yoke or noisey flyback transformer........T.
Dec 12, 2007 | RCA F32450 32" TV
Sanyo DS31520 31" whining, high pitch screech, very annoying!
two audio out RCA type lacks a red and white. only thing I can think of is make sure nothing is connected to the outputs unless your running it to a stereo. now for the inputs are 3, video yellow ,left and right audio is white and red, make sure the yellow has yellow input rca plug. still problems take them all loose and see it feed back goes away.
Dec 22, 2006 | Sanyo DS31520 31" TV
No picture only a high pitch sound
Yes,it can be repaired,sometimes for no reason components fail and they need to be replaced,if you are familiar with tv service you can check the horizontal output transistor,it might have gone bad(shorted out)and is all is going to take to get the set back running,sometimes the output trasformer damages the transistor and both have to be replaced,first just change the transistor and if it blows up again then replace the transformer,if you are not too familiar with servicing a tv be safe and call for assistance from a servicer,if you take the set to them it should be expensive.Let Us know how it goes or if you need more information.
Nov 08, 2006 | Sanyo DS31520 31" TV
Sanyo DS31520 went dead
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Squealing noise is from the power supply teling you that there is an overload condiction. The overload is shifting the operational frequency of the power supply into upper audio hearing range. Check the diodes and caps in the supply circuit and the active components in the deflection circuit. also resolder the LOPT, h-output, h-driver, and h-driver transformer. Good luck
Jun 19, 2006 | Sanyo DS31520 31" TV
Sanyo DS31520 31" TV Logo
166 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
