Question about Frigidaire Dryers
Clothes aren't drying properly
This dryer is fairly new (no warranty).
We pulled it out from the wall to check for lint blockages and found none. We vaccuumed the hoses and out side vents anyway and then put in a small load of towels. It took over 2 hrs and they were almost dry.
You can hear the gas go on and it does get hot. Although maybe not hot enough? How can we fix this?
Linda
  • lalahanson Nov 19, 2008
    We checked all and my husband decided to run a towel through the vent from the dryer to the outside of vent and pulled out an old pair of boxer shorts (LOL) and other debree. We thought it was clear because we saw light but we were wrong.
    Thank you so much for your help. It was greatly appreciated.
    Genius:
  • 1,028 Answers
Look behind dryer is vent hose kinked or mashed flat? ck a load with hose completely disconnected may get warm and a little dusty but if problem solved reck hose all the way through
Posted on Nov 18, 2008
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
Clothes not being dried in drying cycle. Fan is working.
Your washer dryer will only dry half the clothes that it can wash, so you may need to reduce the amount your trying to dry. Also the drying side works by condense drying,it wont be vented outside, it needs a trickle of water which runs behind the draw where you put the powder in. When its on pull out the draw and check that there is a trickle of water going in, if not it's the solenoid valve gone, not a major job to change, and it is a fairly common fault. Have you checked the hose that leads to outside? They get stuffed with lint,etc and sometimes they need to come off the dryer and the blockage removed, or buying a new hose could be necessary. Check the exit point on the machine and the entrance and exit point in the wall of the building. Make sure your lint trap is the machine in clean and it should be washed every three months.
May 17, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
My dryer does not heat. Clothes do not dry.
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose. If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
Dec 06, 2010 | Kenmore Dryers
Clothes arent getting dry
If yours is a gas dryer check out the ignitor for the spark for the burner. It should click within 30 seconds upon starting up ther dryer with the switch set to the heat mode. If not clicking the ignitor is in need of a replacement
Mar 29, 2010 | Dryers
Our dryer doesn't get hot enough to dry the clothes
u probably have the dryer pushed too close to the wall and u have kinked the dryer vent or u have a buildup of lint in the dryer vent or the lint trap pull the dryer out and pull the dryer vent off and dry a load with it off and away from the wall if it works the u have a kinked hose or a lint blockage in the hose good luck hope this helps
Feb 25, 2010 | LG DLG2532 Gas Dryer
Our Amana Dryer is not drying clothes properly. It does not seem to heat up properly and takes quite a long time to dry a load. The air flow seems to be good. There is not build up of lint in the hose and...
Hello there:
- If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 110 degrees and 150 degrees. Check that the drum seals are not worn out.
Dec 23, 2009 | Amana Dryers
Dryer takes to long too dry
You need to check your vent and vent hose for blockage. Pull the drier away from the wall and remove the hose check the hose for any thing that will stop it up, then look at the vent outside for blockage. These vents must be clear or it will not let out the moist air to dry the clothes. Also you may have to ck down in the lint screen area for lint that has fallen in there, run your vacuum in the blow mode and blow this area out.
Dec 07, 2009 | Roper Dryers
Frigidaire gas dryer trouble shooting gas dryer taking too long t
Check the fins on the fan impeller. They may be covered in lint or not spinning adequately.
Mar 05, 2017 | Frigidaire FGQ332ES Gas Dryer
My dryer is really hot when it is running, but is taking a really long time to dry the clothes
Make sure you check your exhaust hose. It shuld be clear of any lint , and properly exhausted to outside of the home . Try turning on the druer with no load and no heat , find your outside vent and check for air flow . If none is felt you suhld move your dryer away from wall ( if aplicable ) and disconnect the hose and check for any blockage , You can even try the above step with the vent hose disconnected to make sure that the dryer it self is properly venting ( feel for ALOT of air coming out of exhaust port ) . If only a miniscule amount of air ( or none at all ) is coming out of the back of the unit you may have to call a technician to come in and clear out the internal duct work .
Jun 09, 2009 | Kenmore 600 6962 Dryer
My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Feb 21, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
