Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool Side by Side, Inside meat drawer comes off track
I have a 1 year old Whirlpool model #ED2FHEXTT02. I've had a service tech out once to fix the meat/cheese drawer that keeps coming off it's track. If I look at the metal track that the lip of the drawer rides on, the left side has an edge that forms a U shape, the right side is mor like an L shape which allows the drawer to slip off it. The tech sent a new shelf that contains the metal part the the drawer under rides on, but it's doing it again (4 months later) I have another service call tomorrow 11/18/08, and I'm 2 days from my warranty expiring - anyone have any suggestions of what I need to say to this guy to get it fixed properly? Has anyone heard of a design flaw on this model?
5 Suggested Answers
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
  • 1073 Answers
SOURCE: broken rear stationmary support on mat/cheese drawer
yep, order part number 61005337 and part 67764-1 about 2 bucks each and it will fix ya
Posted on Apr 23, 2008
SOURCE: water always inside refrigerator sometimes ice forms
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
taken from: http://www.repairclinic.com/0088_4_1.asp#Level2_6
Posted on May 19, 2009
richroth
  • 9472 Answers
SOURCE: need under shelf meat drawer for whirlpool 16 cu ft fridge
What is the model number of your unit?
Posted on Nov 24, 2012
I have a Whirlpool bottom freezer fridge model WRF560SEYMOO. The bottom drawer will not close completely. we have emptied and turned down to thaw out any possible ice blockage.
check all the shelves,check the bin on the door,sometimes one side is up farther than the other side keeping the door from closing or remove the bin and shelves and see if it closes,one of them are hitting or the tracks on the sides are bad but most likely it will be the bin or shelf.
Feb 04, 2018 | Whirlpool Refrigerators
Broken shelf
The small meat or deli drawer tracks show to be avail for replacement as a left and right part. Front and rear screws are shown for each track. Since these parts are shown by themselves, the parts should be replaceable alone. Part# 63001371 is the left track Part# 63001372 is the right. About $5.00 each. The full shelf is a Part# 67001532 @ about $31.00. Pleazer Appliance...
Apr 07, 2014 | Maytag MTB1891AR Top Freezer Refrigerator
Water collects under the deli/meat tray of our Samsung RF267 side by side refrigerator and freezes there. Where does the water come from and how to resolve the problem? Help ALSO Our Samsung front...
The water is coming from a leaking water tank behind the deli/meat tray. It only leaks when you use the water dispenser. You will need to disassemble the deli drawer to get to the water tank and replace the water tank. FOR THE WASHER, call Samsung for service. You may have a control board problem.
Jun 18, 2011 | Samsung Kitchen Ranges
Our refrigerator is about 7 years old. The vegetable drawers (clear plastic) are very difficult to pull out. We have washed and dried them, cleaned the tracks, etc., but to no avail. Is there a...
Normally, all vegetable doors can easily be pulled out as there are minimum 1/8" allowance in both side. I think, your refrigerator got corroded with where indoor compartment is fixed. Please check any dental in iron side of the door, If not, just clean drawers both side with an emery (salt) paper to enable it to enter inside freely.
Jan 22, 2011 | Amana ARB8057C Bottom Freezer Refrigerator
Whirlpool refrigerator stop cold but frosting bad
Hello Catherine Fu,
Welcome
You said, you got this whirlpool double door refrigerator for 4 years. cost me about 1.5k. the second year, right after warranty, the main brain is down-the light panel in the refrigerator is off. whirlpool tech told me to replace it will cost me 500, so you decide not to do it. Now you have bad frosting issue for 6 month. Inside the Refrigerator, the water keep on dripping on side wall and glass drawer ceiling. In the freezer, frosting all over each drawer, and the bottom drawer has too many frosting and ice that i can hardly close the door. Last night, the refrigerator section just don't get cold anymore, it shuts up by itself.
Help!! It is an very expensive refrigerator and ONLY 4 years old .
First,I think you need to have a new tech.
It sounds like you have either an air leak allowing out side air in and this causes the icing.
Or you may need some freon (coolant gas) .
If your freon pressure is low it can ice up.
Did that tech that was there check for a freon leak and also check the pressure of the freon in the lines???
You need to call a different tech and let him see what's happening.
Some company that is reliable!
Let me know what they do for you.
God bless, Huuum
please remember to leave a rating.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer Drawer won't open on Kenmore 22" Bottom Freezer Refrigerator
Try raising the door. It may be off the roller tracks inside. If you get it to open you'll find the problem. These tracks are like kitchen drawer tracks.
Jun 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GHW 9400P
Hello! your problem is the motor control unit,MCU.
or the central control unit,CCU. Try unplugging the washer for a few minutes sometimes that will reset the unit.There is a tech sheet inside bottom of the washer cabinet.If youre not sure, may need a service tech.
Dec 17, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
57 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
