Question about Dayton Electric Heater
Use Breaker for Switch?
I'm preparing to purchase a Dayton 3UG73, 5000 w electric heater. My electrician suggested hardwiring direct from the main electric panel with a new 30 amp circuit and using the breaker for the on/off switch. The heater will be only about 6 to 8 feet from the breaker. Does anyone see a problem with this arrangement? Are there any concerns to be aware of?
    Problem Solver:
  • 8 Answers
Thats ok, but i would put a thermostat switch on it also !
Posted on Jan 07, 2009
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Breaker trips; reset breaker at panel and water heater "on" light comes on. Breaker tripped again in 5 min; reset breaker again and water heater light comes on. Cycle continues to repeat. Bad...
It is possible that the breaker is bad. It is also possible that your water heater is overloading the breaker. It is probably easier to try a new breaker to start with. Unless you are familiar with changing the breaker, call an electrician. Your life is a very valuable asset to you!
Feb 18, 2011 | Water Heaters
Why does my 100 amp main get so hot the black wire is starting to melt, should'nt the breaker trip if there is that much draw?
You need an electrician before there is a fire.
If the breaker is not tripping, then the breaker is bad.
Act now before the heat damages the box and you need full replacement.
Absolutely put the metal cover back over the breaker box and keep the door closed.
Move all flammables away fro breaker box area.
Put a smoke detector right there.
Put a fire extinguisher nearby.
You don't put water on an electrical fire.
Before the electrician gets there, turn off as many electrical devices as you can.
Don't run all at one time.
Run just when needed.
Electric water heater.
Space heaters.
Vent fans.
Electric Stove.
Electric Oven.
Microwave.
Heat AC.
Electric Dryer.
Washing machine.
Power tools.
Big screen TV.
The outdoor lights, and swimming pool pump.
Turn off as many indoor lights as possible.
Now the freezers and refrigerator have to stay on.
Clean out the grilles so they run more efficiently.
Reducing your power consumption will be good practice.
When you call the electrician, tell him the brand and amperage of your main breaker.
If the whole box needs replacement, you might want to upgrade the service to 150Amp.
Some areas, it's code that old panels have to be upgraded to more amperage ... but the electrician will know the details. Call local electric supply house to double-check what the electrician tells you.
Nov 08, 2010 | General Electric 100Amp 3-pole circuit...
Purchased "Reliance Lowboy electric water heater"
The water heater has two 4500 watt elements.
However both elements are not turned-ON at same time
So the water heater is 4500 Watts
Volts x Amps = watts
Amps =watts divided by volts
Amps = 4500 Watts divided by 240 Volts
Amps= 18.75
So that says a 20 amp breaker ... except for the 80% rule
80% rules says for safety, your Amp rating should be multiplied by 80%
20 amp breaker X 80% = 16 amps
20 amp breaker is actually safe for just 16 amps, and your water heater draws 18.75 amps.
The calculation shows you need a 30 Amp breaker.
30 Amp breaker requires 10 gauge wire.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Nov 02, 2010 | RELIANCE ELECTRIC WATER HEATER
I need the the 3 button switch on a dayton model 2E440A electic wall heater. 220 volt. ark-less switch 9334 NC where can I purchase this switch
Hi, what you are going to have to do, is remove the switch, mark the wiring so you know where to terminate and take the switch to a local appliance parts house. write down and take the unit model and serial #'s down also as they may have to match it with an aftermarket type normally closed switch that's if they can't find the OEM switch. Sometimes, you can get away with going to a air conditioning wholesale only parts store and you can pay cash for the exact replacement. But yes, it will have to be a parts house that deals with this equip. I hope this has given you some direction as to you're question. Sincerely,
Shastalaker7
Nov 19, 2009 | Dayton Electric Heater
Where do i connect load wires to 240 volt baseboard heater
this is tricky to some you must connect heater to the load side of thermostat must will have a black set and a red set wires look at the directions to find the line side which you hook wires from panel to them I will tell you some switches are different so with out seeing the schmatics its hard to tell you email me a picof thomastat and i can tell you hope this helps
Oct 27, 2009 | Dayton Electric Heater
I have a home built in the 50's. circuit breakers are pushmatic. 7 breakers on a side. The locking bar down the center will not allow me to replace 2 single pole breakers with double pole. It's for an...
You need to put in what we call a sub box. This should be done by a licensed electrician, but if you really want to do it yourself you will need a distribution box some wire and it has to be connected directly to your main lags from the meter box, this box will have a main breaker built into it and spaces for additional breakers, depending on your existing wiring the electrician might chose to wire the additional box directly to your meter base and not your existing box. Either way you really should seek local professional help on this project, just for your safety and to satisfy your home-owners insurance.
Have a great day..
Tim
Mar 06, 2009 | Connecticut Electric & SWITCH UBIP130...
Curcuit breaker pops
hello elanalex,
When your heater shuts off it trips your main breaker and that is usually associated with the interupt capacity of the breaker ( which means that while your heater is drawing current, if the thermostat says stop.. you are interupting that current demand abruptly and your getting a surge back to your breaker, You may be able to add a surge arrestor to that power feed to suppress that problem. You may also be able to repsecify your main breaker with one that has a higher interupt capacity.. Check with a local electrical supply house..explain the problem and they should be able to provide a hardware solution. Make sure you provide details on your circuit breaker brand so they can provide the proper solution.. GoodLuck
Regards,
Rick
Dec 04, 2008 | Dayton G73 Utility Heater
Dayton 2yu62 doesn't work at all
Need to check heating elements and replace if necessary. If your checks are complete that is the answer I think.I suggest reviewing your findings. The heating elements rarely go bad.
Oct 22, 2008 | Dayton Electric Heater
Dayton Electric Heater Logo
127 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
