Question about Northern Tool Vaper 2.0mm Hvlp Spray Gun with Stand 19120
Vaper primer gun has intermittent air supply
I purchased vaper 4-piece triple gun kit. used it once and 1.4 primer gun spits. 1.7 finish gun works o.k..I returned kit for free replacement & new primer gun is good for 1 use only. I thoroughly cleaned primer gun but when I tried to use it I can see bubbles coming up thru paint cup, Indicating to me that air is escaping thru cup.Repeated cleaning does not help, so I try finish gun to check air supply & it works fine. Is there repair kit for something in trigger line concerning air supply?
  • 50 Answers
Does it come with instructions? The material thickness is VERY IMPORTANT when choozing the proper nozzle.
Posted on Feb 04, 2009
What is the best way to lay down the clear coat over my finish coat on the fender I just painted but ruined when I shot the clear coat?
Refer to the paint manufacturer's data sheet to ensure the new gun has the right setup for clearcoat.
Could be the new gun was supplied setup for spraying a high solids primer or something that needs something like a 0.7 mm fluid tip. Clearcoat would need a 0.4 mm tip, an appropriate needle and a different air cap.
Data sheets are very valuable things. Don't forget to pick one up when you buy spray paint. A viscosity cup is another useful addition to the tool kit along with a graduated paint stirring stick.
Nov 24, 2015 | Air Tools & Compressors
What is the problem? will not load the plunger to drive a nail
It sounds like the nail gun might need a lower end seal/repair kit.
Aug 09, 2014 | Porter Cable-Cable FN250C 1-inch...
Hey yall i got a sharpe finex3000 hvlp spray gun model sh-880 1.4 finish gun. and ive used this gun before and i cant remember how 2 set it up etc or what the best working pressure is. anyways i was tryen...
There is a step by step description in the manual of the Finex3000 itself (incl. pressure set-up, etc...). In case you don't have it anymore, you can look online: http://sprayfinishingstore.com/manuals/
Jul 25, 2011 | RTO Sharpe Finex 3000 Hvlp Gravity Auto...
Hi After shooting my 4 + 1 primer ( 4 coats ) Via a Trans tech 110 and 1.4 tip I wet flat with 800 but kept breaking through the primer seeing the gel coat underneath even though I was applying only enough...
Im a spray painter it sounds like there is some type of sheen on the primer what are you trying to finish wood metal why 4 coats of primer what kind of finish are you applying over it Get back to me i have been doing this for 40 years will see if we can figure this out
Jan 06, 2011 | DeVilbiss 1.6mm Fluid Tip - Devilbiss...
Where can I find an illustrated parts breakdown for a vaper hvlp spray gun
mine came with a one page manual with exploded views of the guns with numbered and named parts on the back.
Nov 10, 2009 | Vaper Titan 3 Pc Hvlp Dual Setup Spray...
Once I connect the airhose to finishpro 25xp it leaks through the exhaust. what would cause this, and what repair parts would I need to fix it.
your air piston is seized,go to a parts store and get a bottle of "AIR-TOOL" Lube pour into air-line in the tool, put air in and excercise the trigger and make sure it works again,and also drain your air tanks too!!!
Oct 26, 2009 | Senco Finishpro 25XP, 18 Gauge
Ring gone
go to dewalt service center for porter-cable parts. get a repair kit for the gun
Oct 10, 2009 | Porter Cable-Cable NS150B 1/2-inch to...
Air is coming out but no primer
  1. primer viscosity to thick
  2. internal filter clogged
  3. internal passage clogged
  4. gun not adjusted properly
  5. high build primer uses more air pressure
  6. wrong needle and fluid nozzle
  7. gun needs cleaned
Aug 07, 2009 | Vaper 4 Piece Set 3 Gravity Spray Gun +...
New to spray painting and am spraying baked enamel paint
To fix this problem you need to turn up the pressure both at the wall(coming from the air compressor) and at the gun. I would suggest 10 more psi at the wall and 5 at the guns but you can play areound to find whats best for you.
May 14, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Northern Tool Vaper 2.0mm Hvlp Spray Gun with Stand 19120 Logo
416 people viewed this question
Top Northern Tool Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Northern Tool Air Tool and Compressor Expert? Answer questions, earn points and help others
