Question about HP LaserJet 4 plus Printer
50 service flashing on display screen
Will not allow me to print
  • DennisC2 Jan 15, 2009
    I am having the same problem. I ordered a new fuser assembly, put it in and am still getting the "50 service" error. The printer had been off for several weeks when I replaced the fuser assembly. Any other ideas, or is it time to buy a new printer?
    Thanks
  • HP Master
  • 4,338 Answers
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 27, 2008
I just changed the oil and filter on my LX420 twin cam how do I get the blinking light to go out. Its a 2006
  • The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display.
  • The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time.
  • CHG"/"OIL"/TIME will alternate on the display for five (5) minutes after the meter reaches 50 hours.
  • While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five (5) minutes.
The display will also flash as described above for five (5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two (2) hours.( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...)
THE METER DISPLAY WILL RESET TO NORMAL AUTOMATICALLY, after the reminder maintenance time interval of two (2) hours. There is no method of manually re-setting this Service Monitor gauge.
May 01, 2017 | Cars & Trucks
How do you fix error code fault platen cal 190 on tally 6306
just clear nvram first. then in operator menu go to print gap then mode select manual then enter.
now press clear key adjust print gap by pressing + & - key together when it show 190 then decrease it to 50 and save value.
Dec 03, 2014 | Tally Office Equipment & Supplies
520230. 31520193. 7Polaris 550 Xp eps 2009About 20 hours on unitStored indoorsI understand one code is Idle air and the other is power steering is disabled or not functioning. First I would try and...
Diagnostic Mode
The diagnostic mode is for informational purposes only. Please return your ATV to your dealer for all major repairs.
As long as the gauge is in the diagnostic mode, the wrench icon will remain lit.
To leave the diagnostic mode, turn the key switch off and on.
NOTE: Any movement of the tires will also take the machine out ofthe diagnostic mode.
To enter the diagnostics mode:
1. Turn the key switch off and wait 10 seconds.
2. Set the park brake and shift the transmission to neutral.
3. Hold the mode/reverse override button and turn the key switch on.
4. Release the switch as soon as the display is activated.
The initial screen display refers to the software version installed in
your ATV. This information is displayed briefly.
Use the mode/reverse override button to toggle through the diagnostic
screens.
Screen 1: Battery voltage
Screen 2: Tachometer
Screen 3: AWD diagnostic
This gauge indicates whether or not current is flowing through the
AWD coil (only on models with switchable AWD).
Screen 4: Gear circuit diagnostic
This screen displays the resistance value (in ohms) being read at thegear switch input of the gauge.
46 FEATURES
Instrument Cluster
Rider Information Center
Diagnostic Mode
Screen 5: Programmable service interval
The purpose of the programmable service interval is to provide the consumer and dealer with a convenient reminder for routine maintenance. When your vehicle leaves the factory, this feature is set at 50 hours. You must enable the programmable service interval before it
can be used.
Once the service interval mode is set with the hours when service is due, the hours of actual engine operation are subtracted from the set
hours until 0 is reached. When the counter reaches 0, the wrench icon will flash quickly for 5 seconds each time the vehicle is started as a reminder that the periodic maintenance is due.
To set the hours, press and hold the mode/override button until the wrench icon flashes. When it begins to flash, release the button. The setting will increase by one hour each time the button is pressed.
Pressing and holding the button will allow the numbers to escalate much faster. When the desired time increment is displayed, release the button and wait for the wrench to stop flashing. When the wrench stops blinking, your service hours are set.
NOTE: If you scroll past the intended number, hold the button down until the count turns over to 0. You can then reset the number.
If the service interval is enabled on your ATV and you wish to turn it off, toggle to the service interval mode. Press and hold the mode button for approximately 7 seconds until the word OFF appears in the
Rider Information Center.
Jun 28, 2013 | Polaris 2009 Sportsman 550 EFI XP With EPS
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
What do I do to remove the plasma settings and advertisement from flashing on screen during tv viewing
Look at the display settings and change it to your liking. As for advertisements, it is done by the service provider.
Jul 28, 2012 | LG 50PQ30 50 in. Plasma HDTV
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My pixma ip8500 is printing with some colour missing, all cartridges have ink in them?
When Printing Becomes Faint or Colors are Incorrect.
When printing becomes faint or colors are incorrect even if the ink remains in the ink tanks, the print head nozzles are probably clogged. Print the nozzle check pattern to confirm the condition of the nozzles and then perform the Print Head Cleaning.
Note : Before performing maintenace
*Open the Scanning Unit (Printer Cover) and make sure that all lamps for the ink tanks are lit red.
-If any one of the lamps is flashing slowly, the associated ink tank is running low. You can continue printing for a while, but we recommend you to have replacement ink tank available.
-If any one of the lamps is flashing fast, the associated ink tank is emty. Replace the ink tank.
If an ink tank is flashing fast even though ink remains in that ink tank, it is inserted into the wrong position. Make sure that the ink tank of the correct coloris inserted in each position matching the label.
-If the ink lamp is not lit, the tank is not set properly. Press the <PUSH> mark on the ink tank until the tank clicks into place. Make sure that all the packaging material is peeled off the ink tank.
*Increase the print quality setting in the printer settings.
Step 1 : Printing the Nozzle Check Printer.
1) Make sure that the machine is turned on, open the Front Feed and extend the Output Paper support.
2)Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder.
Set the Paper Thickness Lever to the left.
3) Press the Paper Feed Switch to select the paper source where you have loaded paper.
4)Print the nozzle check pattern.
a) Press the Menu button.
b) Use the right and left arrow buttons to select the Maintenance/settings, then press the OK button.
The maintenance /setting screen is displayed.
3) Use the right and left arrow buttons to select Maintenance, then press the OK button.
The Maintenance screen is displayed.
4) Use the Up and Down arrow buttons to select the Nozzle check and then press the OK button.
The pattern confirmation screen is displayed.
5) Use the Up and Down arrow buttons to select Yes and the press the OK button.
The nozzle check print is printed, and the pattern confirmation screens are displayed alternately.
Examine the pattern and take the appropriate action.
Step 2: Print Head Cleaning
Clean the Print Head if lines are missing or if white streaks appear in the printed nozzle check pattern. Cleaning unclogs the nozzles and restores the print head condition. Note that cleaning the Print Head causes used inl to be absorbed in the ink absorber. Cleaning the Print Head consumes ink, so perform Print Head Cleaning only when necessary.
1) Make sure that the machine is on, open the Fron Feeder, and extend the Output Paper Support.
2) Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder/
4) Start Print Head Cleaning.
b) Use the right and left arrow button to select Maintenance/settings, then press the OK button.
c) Use the right and left arrow buttons to select Maintenance, then press the OK button.
d) Use the Up and Down arrow buttons to select Cleaning and then press the OK button.
The confirmation screen is displayed.
e) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Print Head Cleaning starts.
Do not perform any other operations until Print Head cleaning finishes. This takes about 50 seconds.
The pattern print confirmation screen is displayed.
f) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Note : If the problem is not resolved after performing steps 4 and 5 twice, try Print Head Deep Cleaning.
If print quality does not improve by standard Print head Cleaning, try the Print Head Deep Cleaning, which is more powerful process. Note that cleaning the Print Head causes used ink to be absorbed in the ink absorber. Print Head deep Cleaning consumer more ink than the standard Print Head Cleaning, so perform this procedure only when neccessary.
d) Use the Up and Down arrow buttons to select Deep Cleaning and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep cleaning finishes. This takes about 100 seconds.
5) Check the condition of the Print Head.
a) Print the nozzle check pattern to check the print head condition.
If a particular color is not printed properly, replace the ink tank of that color.
b) If the print head nozzles are still not cleaned, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
c) If this does not solve the problem, the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 01, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
How do you print at 50% w/ an 5610 all in one
I am taking you literally in as much as you did not say "copy at 50%" which is done through the 5610's front control panel.
To print at 50% you use the browser printer settings.
Firefox:
1. Go the the "File" drop down (upper left)
2. Go down to the "Print Preview" selection... a preview screen will then be displayed.
3. Look to the top right part of the screen to find the "Scale" field and set this to 50%. The page will repaint to show you the new print size.
5. Hit print
Internet Explorer:
3. Look along the top-right of the screen for a drop-down field that may say "Shrink to Fit" or a percentage. click this and set it to 50%. The page will repaint with your new setting.
4. Hit the printer icon in the upper left to print.
Hope this helps. Best of luck - Dan
Oct 07, 2009 | HP Officejet 5610 All-In-One InkJet...
LIGHT FLASSING CANT PRINT
Error 50: Purge cam problem. mfc/dcp has to be taken to service. No chance to fix it by yourself. sorry!
Mar 29, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP LaserJet 4 plus Printer Logo
505 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
