Question about RCA P52926 52" Rear Projection Television
Buzzing in all chanals
I have a buzzing in all chanals. It was on a spliter with my high speed and i removed that but it id not fix the problem. It only occurs with the cable. The sound is fine when the dvd is in use.
0 characters
1 Points
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
Dec 22, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
My chanals on my tv won't work
try moving the antenna around as it is the most common problem where i reside and most of the time when people buy a new TV with an antenna, they have to set it up where it can catch proper network.............or if that doesn't work then i prefer that you take your TV to a technician to check out the fuses.
Apr 27, 2012 | Philips Projection Televisions
My wife said that the tv made a buzz sound then the screen went blank. The tv still turns on, but the screen remains black. I tried leaving it off for awhile, but the problem is the same. Is there a...
This tv have a circuits section call the Deflection board and it is dead,it could be burn any parts of the electronic components on this area.The buzzing sound u hear is the FBT-The high voltage Flyback Transformer have it high voltage current have no where to go,the FBT it could be dead also.This tv can't be done any quick fixes.Must hire a Tv Tech. have to troubleshoot and find out which eclectronic components are dead and require replacing on the tv Deflection sections circuitries of the board.
Dec 04, 2010 | JVC AV-48WP30 48" Rear Projection...
Yellow, blue and green ghosting of picture. Convergence mode will not allow realignment of the red and blue lines
Hi,it sounds like a light engine problem.Lcd Technology uses 3 chips blue,green and red that create the image ,when they start to fail color discoloration will occur.If it's an Dlp pay attention to sounds of buzzing,whirling and high pitch sounds because it could be your colro wheel.
Oct 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
No piture the screen is black. i have volume. it won,t even show the menu on screen
Hi i do a lot of projector tvs. there are a few things it could be i will give cost prices to.
1 it could be high voltage problem flyback cost is 395.00
2 you have audio so tuner is working ok and cable feed ok
3 it could be power supply or horz problem that part to servicer is only 25.00 they charge 200.00
4 it could be your high voltage spliter common with this problem cost plus parts 195. to 295 the high voltage splitter only costs the servicer 45.00 dollars and they are easy to put in sometimes
but you do need a qualified person to do it . There is high voltage
and you have t be careful
to sum it up .you are not getting high voltage to turn tubes on or a weak signal . my guess with out looking at it is hv splitter
I hope this helped doctor video leadingedgeelectronics since 1987
Apr 29, 2008 | Projection Televisions
Sony Grand Wega KDF-42WE655; 2 problems
You have a problem with EFM interference from a light that has a dimmer switch. Turn dimmer all the way up or off, buzzing will cease
Apr 21, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
RCA D52W19 52 in. Rear
open it up and see if any liquid is spilled on the boards, most squeals are from the high voltage transformer and or splitter
Jan 17, 2008 | RCA D52W19 52" Rear Projection Television
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Buzzing noise
It could be a high voltage transformer. The serial number won't help me locate the part, but there should be a part number on it. Anyways, this could be the transformer on it's way out. When they are on their way out, sometimes they will amplify the noise through the system and buzz through the speakers too. If you find a part number, check it out on to see what a replacement would cost.
Jan 13, 2007 | Mitsubishi VS-50805 50" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
Top RCA Projection Televisions Experts
The Wyzzyrd
D. E. Hev
Ron Dufek
Ron Dufek
Are you a RCA Projection Television Expert? Answer questions, earn points and help others
