Question about Samsung SRP 350 Thermal Printer
Paper feed when i plug the srp350 into the cash register it continously feed out the paper roll :S i see nothing in tech help or troubleshooting
Hi Fieldridle, Im guessing you are connected to the cash register via serial, if so I'd try checking all the serial settings on both the printer and register so they match one another. Next, check that the register is sending the right type of emulation or printer language.
Posted on Feb 06, 2009
Sharp xe a213 - My till receipt is not printing although it still runs through the feeder.
Make sure the paper roll is set in the holder with the SHINY side towards you as it feeds. If no shiny side of paper, you are not using the correct thermal paper.
For those who asked about the XEA213 manual, there is one here:
https://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A213_operating_programming_manual.html
Dec 22, 2016 | Sharp XE-A213 Cash register
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
My shape XE-A207 cash register won't roll out the receipt paper when a sale is made. It is trying to print a receipt but the paper isn't rolling out.
Usually a broken feed gear in the printer. If you can hear the feed motor whirring but no paper movement, it probably needs a new printer.
Sep 07, 2015 | Retail Supplies
How do I load the till roll into a Casio 240CR
While holding down the feed button, feed the end of the paper into the slot at the back of the printer.
If anyone is having trouble programming a Casio 240CR cash register, the manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_240CR_operators_manual.html
Aug 23, 2012 | Casio Parts Cash Register PC Desktop
Sharp electronic cash register xe-a206, what does H mean? and how do I get it to stop printing a blank page when i put the paper roll back and after pressing "CL"?
H means head up. It is telling you to click the paper holder back down after replacing the roll. You must always press clear and it should feed a small amount of paper when the new roll is inserted. this is built in to the program.
If anyone needs a Sharp XE-A206 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A206_operation_manual.html
Jan 11, 2011 | Sharp XE-A402 Electronic Cash Register
Problem with paper roll feed - does not finishing feeding through on transaction need to manually feed to get the whole receipt
hi top of the left side on the cash register their is a button its shape like a arrow .it is the paper feeding key if you wont to manually get the receipt press it
Jan 05, 2011 | Sharp XE-A402 Electronic Cash Register
Display H and do nothing and till left open . can not close the till
hmmmm are you try to install new paper roll?
the paper feed arm didnt lock
open printer cover and again install paper roll
and close the printer arm
then press cl key
Sep 26, 2010 | Sharp XE-A402 Electronic Cash Register
Sharp A203 cash register froze up
then press cl key
Jul 22, 2010 | Sharp XE-A402 Electronic Cash Register
On the screen there is a E94 error messagage on the Casio P260 cash register . How can I correct this error and reopen the cash register.
E94 is a printer error. Open the printer and make sure nothing is jammed in it.Remove the paper roll. Look for old pieces of paper stuck in the gears etc. ----------------------------------------------------------------------------------------------
If anyone needs a Casio PCR-260 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
Jun 16, 2010 | Casio Parts Cash Register PC Desktop
Samsung SRP 350 Thermal Printer Logo
208 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
