Question about Kenmore 15864/15862 Top Load Washer
Washine mashine aggitator
The washining machine aggitator does not seem to spin freely. when you load up the machine and it starts its aggitating cycle it does not seem to aggitate when you have heavy items in the machine such as jeans and towels. when i spin the aggitator manually it spins, but it makes a clicking noise.
  • mywash Dec 17, 2007
    the bottom of my machine aggitates but the top barely turns
  • Anonymous Mar 29, 2014
    all cycle working except spin dry
    President:
  • 878 Answers
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Posted on Dec 06, 2006
I have a hot point washin mashine that does not finish a wash and stopes half way through then lights at front of mashine start flashin
Had this with mine. Cleaned the filter (as decribed elsewhere on this site). Also cleaned the component fto which the drain hose attaches - guess this is the pump. Just unclip the drain hose and the hose going into this pump, and check there is nothing obstructing the pump. The clips are a bit of a fiddle, you might want 2 jubilee clips to replace them. Then ran a "maintenance wash" as per manual (ie a hot wash, no clothes, no detergent). Seems OK now
Nov 02, 2010 | Hotpoint Aquarius WF000 Front Load Washer
The washing machine doesnt aggitate
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | GE WBSR3140DW Top Load Washer
Homemaker hmwm8000 washing machine. clicking noise when spinning, same place each revolution, same noise whether full or empty
hi sounds like you have something trapped between the drum and tub casing...
{bra wire ?) it also could be your element has come lose and the protetive plate is touching drum.
Dec 30, 2009 | Washing Machines
My washer won't spin or aggitate. I have a GE
Check the belt and clutch in the front under the lid run a butter knife under the lid and pop the front off and take a look.Have a great Thanksgiving.
Nov 25, 2009 | General Electric WHDSR209DWW Top Load...
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Nov 01, 2006 | Candy CN146 Front Load Washer
Kenmore 15864/15862 Top Load Washer Logo
205 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
