Question about Refrigerators
More on bad smell
Hi- the front panel is there but to remove it you have to take off the doors. Does that seem like the thing to do. My husband is about ready to do it. thanks
Hi, if the doors have to be removed lets check for somethimg more simple. slide the frige out from the wall and check to see if the pan can be removed from the rear. also some units have a heater in the pan to evaporate the water. i would not think you would have to remove the doors to get to the pan.
Posted on Nov 17, 2008
Where does the door wiring connect to completely remove door
Need to remove the inside door panel. When you do that you can save the door lock which you need for the new door. As for the wire inside. Remove the kick panel on the floor side. You may have to remove some screws or clips or it may just pull out. Once it's removed you didn't say what the year and car is so not sure what to tell you. With some cars you have a plug or plugs to connect inside the kick panel and is easy. Others you have to remove the wiring from the door and slide it all out the hole and install the same way.
Feb 12, 2018 | Cars & Trucks
My machine smells damp and musty in between uses. it smells like there is stale smelly water in it, it`s so bad that we can`t leave the door open. This is only a recent thing, we have pulled it out and...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Washing Machines
Wash Machine smells bad
Gain access to the internal area (removal of cabinet panel) of the washer and inspect for source of smell.
Feb 19, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a Kenmore 'Elite' front loading washer that stinks
Have you been leaving the door cracked open after washing a load? If not, mildew will form and smell. If you have, then it would be something else. Respond with any questions.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Odor coming from front door jams after shutting car door
I have the same problem in my 2011 sonata and i finally figured out where its coming from, its inside the doors! Put your window down and then smell the top of the door where the window slides down in...its so gross....its been making me sick to my stomach!
Apr 11, 2009 | 2002 Dodge Durango
LG washing machine has AWFUL mildew smell
Causes of grease, slime and black mould inside washing machine Your problem has nothing to do with the washing machine, any washing machine - even the best can be affected. I suspect your problem is mostly related to using liquid detergents that contain no bleaching agents
Jan 13, 2009 | Washing Machines
KENMORE ELITE HE3 WASHER
2 things you may try if you haven't already ..let washer fill with hot water ..pause and open door pour in about 2 cups chlorine bleach before starting back up..with rag soaked in bleach/water clean inside front door boot ..be sure to roll boot toward front and clean out accumilation under it wash as much as possible off door seal..allow to finish cycle (normal wash should be fine)..may also try removing lower panel remove pump acess plug and clean pump out thoroughly..you are not alone ALL front washer have same issue and if some sort of routine cleaning isn't done problem reoccurs also leaving door slightly open between usues will help ..by the way that is a german made washer
Sep 12, 2008 | Kenmore Elite 45986 Front Load Washer
SMELL PROBLEM
have you tried a wash with chlorine bleach? if not aloow washer to fill with hot water open door pour in 1-2 cups clorine bleach aloow to wash a few min open door and with rag wet in bleach/water and wash inside front door boot rolling it toward you to get into inner portion alow to finish wash and rinse ..in future leave door open a little to allow to air out ..moisture remaing in door boot tends to cause mold/mildew problems ..you are not alone ALL front loads have same issue not just yours
Jul 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Intermittent problem with door not latching correctly
Hi Your husband can replace the Door Lock Hoop Assembly Part Number #22003269 also have him make sure the door hinges are in good working order and aligned correctly. this should make you happpy and save a lot for beer... Let me know if this helps?
Aug 18, 2007 | Maytag Neptune MAH5500B Front Load Washer
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
