Question about Abit IS7-E2G Motherboard
Comp won't start
Nothing happends when i press the start button. It seems during the night there was a power shortage (computer was on) and now it won't repsond at all. there is a green light on the lower right corner of the motherboard blinking continously. If i recall correctly that light should be a steady one, not blinking.
  • Gabriel Butanche Dec 03, 2006
    Power supply is functional, i tested it with a gem from green to black wires
  • Fatal17y Mar 07, 2009
    I have the same prob. i have a almost new powersupply its been in my other comp for a while but its not been damaged or stopeed working..the only thng thats working is the 2 flashing lights aka .Led 14 and 21 i think
    Problem Solver:
  • 28 Answers
Your MotherBoard has 2 LEDs in the lower right corner, each designating a power condition. They are labeled LED14 and LED21. LED14 lights when there is a power source connected. If this is the one blinking it likely indicates a failed power supply. If you have an alternate power supply available that is comparable in power supply capabilities I would try that. LED21 lights when the system is powered on. Replace the power supply.
Posted on Dec 03, 2006
  • Joe Swoboda Dec 04, 2006
    Did you try a different power supply with your suspect motherboard? The owner's manual for your motherboard does not state what a blinking light means, so I guessed it would mean bad power supply. The manual also gives a procedure for you to send the motherboard in for repair, if that is an option for you.
    The fact that it doesn't power up would also indicate the same. If it's not the power supply then I would suspect a damaged motherboard from the power "shortage" (is that supposed to be outage?) Oftentimes when the power goes out, and more importantly when it comes back on, there is a surge (hence the proliferation of power surge protectors for just this reason) on the AC line that can damage sensitive electronic equipment. If there is ever stormy weather, especially with lightning, in your area and you have a history of power outages, it is best to disconnect your computer from both the AC and phone/cable lines. I have seen MANY, MANY fried computers from just this problem alone.
The power went out of My place last night... I woke up and my Mother board was flashing orange... I tried to restart my computer. Nothing happened can somebody help me? It is a Dell computer
Steps:
1. Unplug all the cables from the computer. (If you are not sure then make a note of which cable goes where)
2. After you've unplugged the cables. Press and hold the power button on your computer for about 3-5 secs.
3. It wont start the comp :). This steps is done remove any left over power in the comp...
4. Re-connect all cables and check.
Let me know if this helps, If not, then i'll tell you what to do next. :)
Also, please let me know if you use Dial or ADSL Internet. Because if previous steps dont work then we need to try anther steps.
Dec 21, 2012 | Computers & Internet
My Acer Aspire M1201 won't turn on.
More than likely your power supply got fried from a power surge during that storm anyway. You'd be surprised at how worthless most surge suppressors are these days.
Jul 25, 2012 | Computers & Internet
My dell xps m1530 laptop seems to be on but nothing on screen
Remove the battery and power cable from the system and press the power button for about 5 seconds, then plug in the charger and start the laptop. it will work. shutdown it and put the battery back and start once again . now you can see its working
Feb 12, 2010 | Dell XPS M1530 Laptop
My computer has frozen during shutdown it has never happend before.Please help !!!
this sometimes happens with operating systems.nothing to worry just press and hold down the power button of the pc for 5-6 seconds and you will see that the system will shut down completely.then just turn it on the normal way you do and it should work fine.if it is vista then it may give you a prompt to start windows normally.just hit enter on that option.
Jan 14, 2010 | Sony VAIO VGC-RA840G PC Desktop
Compaq C500- Will not turn on no lights except for battery LED lit. It was working fine last night. The computer was left on and the battery ran down so it did not shut down correctly. When i push the...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
   and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 22, 2009 | HP Compaq Presario C500t Notebook
My Laptop boots occasionally
Let me see if I understand this right!...you turn the power on, the lights come on, the hard this spins and nothing happends???...Does this happend always??? Has it ever taken you to windows since then? Does it ever stay on more than 2 secs?? does it shutdown afterwards?
let me know
Apr 04, 2009 | HP Compaq nc6000 Notebook
Computer wont turn on after 2 months of no use
clean the switch on/off connectors
give the motherboard a good clan with brush
Aug 18, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Comp won't start
maybe there is something wrong with your power supply.. i think you need to change it
Mar 01, 2008 | Computers & Internet
Comp won't start
Sounds like the pc power supply is bad... U can replace it, but if supply went out it may have damaged the motherboard. In future, have monitor blank off automaticlly and install UPS to supply pc. HP has histroy of weak power supplies.
Dec 09, 2007 | Computers & Internet
Abit IS7-E2G Motherboard Logo
206 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Daniel Dollive
Daniel Dollive
Mike
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
