Question about XO Vision MD050 5 in. Car Monitor
I need help conecting my xo vision Gx2265 head rest monitors
I need to know what the green wier is for the red is the acc the black is the ground ?Is the green wier the ground for the RCA video huckup
2 Suggested Answers
SOURCE: installation of a XO vision GX6103
can you send me the instructions
Posted on Oct 16, 2008
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
How do i get the xo vision gx2146 to play threw my stereo speakers
Pull up the menu screen and scroll through until you come to FM transmitter. Select FM transmitter and scroll through to select a radio station(88.1, 89.1, etc). Select the station. Now, tune your vehicle stereo to said station. Enjoy.
Jul 23, 2012 | XO Vision GX2146 Car Monitor
Which 2 wiers are the power wiers to the car radio
Hello ruben
These color codes are for the factory radio harness. there are 3 +power wires if you have a pwr antenna, this wire is pink. The ign/acc +pwr. wire is blue with black stripe, the radio memory +pwr.
wire is orange with a black stripe. Hope this helps.
Dec 06, 2010 | 2002 Hyundai Accent
Wiring diagram
getting no singnal to my back monitor
Mar 18, 2008 | XO Vision GX1042 10.4 in. Car Monitor
XO Vision XO-141FM 14.1 in. Car Monitor
Check that you have good ground connections.
Use DVM to check if you have 12VDC to player.
If you have no DVM, you can use small car light bulb with leads.
If bulb lits from ground and hot wires, then player is bad. Or most likely a loose connections.
atdlee@netzero.com
Feb 02, 2008 | Car Audio & Video
Xovision monitor
To what car?
Black wire to ground.
Red wire to +12VDC.
Yellow cable to input of Yellow Input's radio.
atdlee@netzero.com
Dec 21, 2007 | XO Vision 12.1 Flip-Down Monitor w IR"
XO Vision MD050 5 in. Car Monitor Logo
41 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
