Question about Cell Phones
How does the voice activation work?
The directions are not clear as to how the voice activation works. It only says to push the mult-function button once. Then what?? I did and no further directions were given.
Thanks, Bob Manrubia
  • Lisa Fortunato
    Lisa Fortunato May 11, 2010
    Bob - Perhaps I am not reading your question correctly but can you tell me what you are trying to activate via voice? Thanks!
BT COOL
  • 13 Answers
SOURCE: Voice mail - Samsung C417
call your company and ask them is your voice mail turned on
Posted on Jul 14, 2007
Neto
  • 123 Answers
SOURCE: One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
Posted on Feb 14, 2008
  • 20 Answers
SOURCE: pantech duo voice mail keylock issue
try sending the call str8 to ur voicemail so u will be back into the regular call menu
Posted on May 30, 2008
SOURCE: No voice on gps
I had the same problem. Whit i did was chenged the voice from english (UK) to English. It worked. Try checking if the volume isn't down.
Posted on May 11, 2009
  • 3 Answers
SOURCE: kenwood dnx7120 (automatic volume lowering stoped working)
hit setup...then under AV setup...click over to the 3rd screen...and it should give you options for navagtion volume and and options for muting and overiding the sounds comming from the speakers either front left, right or both....
Posted on May 29, 2009
Messaging is inactive on all lines after push functions button and enter 981
Hi. Inactive feature often means that there's a problem with your connection to the call pilot. Do you have lights on your call pilot? Did you assign a mailbox to the extension you're working on? Did you remember to connect the call pilot to a station port?
Jun 11, 2015 | Nortel T7316E 2-Line Corded Phone
I was told that 2006 dts had either onstar or radio/dvd/cd/gps system not both i spent over three hundred dollars at gm dealer for hm to diagnose this and that even though my dvd nav is factory it will...
ok this is what I just found concerning your issue.
Now this is just the beginning so Im sending this complete in sections for you.
  • Turn ON the ignition. The Cadillac emblem screen appears on the navigation radio.
  • Press the POWER/VOLUME button on the radio.
  • When the navigation disclaimer screen appears, press the I AGREE button on the display.
  • Press the NAV button on the radio. The display should show the current position of the vehicle. The navigation map should be clear and have clear color.
  • Press the voice switch on the steering wheel. Speak a valid voice command. The system should repeat your command and then perform the function.
  • Does the system operate normally?
  • Nov 10, 2009 | Car Audio & Video
    No voice dialing
    hi when you press and hold the button you redial the last call, and when you press just once quickly this button your phone pass in voice call( if your phone has this function...lol) and don't forget to activate the function voice call in your cell phone.
    hope this helps you
    sserpentio
    Feb 12, 2009 | Motorola Mobility H700 Wireless Headset
    What specific buttons do I push and in what order do I push them to get a text message?
    Messages: Version A: Hit OK, hit 4 (or hit DOWN four times and hit OK) Version B: Flip out the keyboard Afterwards, you can hit 1 to send a new message or 2 to read existing ones. Phone calls: Hit END to clear any open windows or end any active calls. Type the number you want to call, then hit Talk. Alternatively, hit the Contacts soft key (right above the Back and End buttons), locate the contact you wish to call and hit Talk. Special note: The two "soft keys" (as they're called) above the Loudspeaker and Back buttons are the same as the two silver buttons along the side of the screen. You use the black ones when the phone is "closed", and the silver ones when the keyboard is out.
    Jan 04, 2009 | LG RUMOR Cellular Phone
    How do I work the lap timing function work?
    hello,the buttons are numbered 1-4
    clockwise-top right button #1
    bottom right button #2
    bottom left button #3
    top left button is #4
    in normal time push #3,then #1 to start and stop lap time.
    for lap time press #2 while chronograph is running,it keeps running while lap time is displayed push #2 again to return to chronograph time display,to clear push #1 to stop then #2 to clear.
    Sep 03, 2008 | Timex 1440 53591 Sports Quotient...
    VN-4100pc
    That device will sometimes allow a clear. This will clear any contained info but should restore function of the device. Turn on the recorder and once you see ERR press and hold stop and erase until the word clear appears. If the word is not up at 15 seconds it will not work, but if clear pops up on the screen just press the REW or FW button to choose yes and then press play to execute. This will clear any contained info but should restore function of the device.
    Jul 29, 2008 | Olympus VN-3100PC Digital Voice Recorder
    Voice comand
    Try pushing the button on the headset 1 time to see what happens. We are using Motorola Razors and it works very well after you push the button once but have your phone open to see what you activate after pushing the button.
    Jul 28, 2008 | Motorola Mobility H700 Wireless Headset
    Pantech duo voice mail keylock issue
    May 26, 2008 | Pantech Duo Smartphone
    Earbuds
    If you are using vox (voice activated transmit) go into the menu and make sure you don't have the VOX setting too high. You should be able to put the headset on... hit the "push to talk" button on the radio and transmit you audio. Turn the other radio on and make sure the radio is "keying" (tx with no auio) then make sure there is audio. If you don't have audio but the radio is transmitting.. you might have the wrong type of plug on your headset for the audio..... there are 2 plugs... 1 for transmit audio....1 for recieve audio. It could be the wrong type of plug for the jack in the radio. Regardless.. the way the headset works is either you push the "push to talk button" onj the radio OR you use the VOX function... with the vox function you just have to talk into the mic to transmit. This is what your headset is designed for. You will have to go into the menu and set up the radio for VOX. If you still have problems follow my directions at the top of this page ( check mic jack and stuff) I think you just have to set the radio up for VOX operation and set the VOX setting. You should be able to push the push to talk button and talk through the mic on the headset. If you don't get any audio that way there is a problem and you should check the jack and plug on the headset.
    Aug 25, 2007 | Motorola Talkabout T5720 (7 Channels)...
    Cell Phones Logo
    Top Cell Phones Experts
    Marvin
    Marvin
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
