Question about Samsung SC-D103 Mini DV Digital Camcorder
Too blured to record
Mine plays back fine, but can't record, badly blured, but has sound. also many times there are lots of wide lines while playing back but eventually clears up. Main problem is being to blury to record.
  • Barry Brown Dec 08, 2008
    Thank you for the info. I placed a call to samsung after reading about the law suit against the company. I was informed my camera wasn't involved in the suit. It is a newer model. They said they could fix it for $180. I told them I would never buy anything made by their co. again. Since then I have ordered another camcorder from another co. Thanks again to fixya, for their help full info.
  • 107 Answers
You have a blue filter inside the lens assembly was decolored by heat and moisture it require a qualifier Tech from Samsung to replace that filter because it must dismantle the lens, in AUSTRALIA it would cost between $80 to $110 to replace it
I hope that give you some ideas
Posted on Dec 05, 2008
Gigaware no sound
If you have audio cables from your source connected to the capture card, then your Recording device needs to be the Line In of the capture card.
If you connect the source to the Line In on the computer, then you use that as the default recording device. Until I set this, the default audio recording device was my microphone (not connected at the time). In Windows, you need the Manage Audio Devices Recording tab. (In Windows 7 and 8, it's under Control Panel > Hardware and Sound > Sound > Manage Audio Devices.)
If you are recording something playing on your computer, then the stereo mix option may work.
You should be able to use any video&audio software if the drivers are compatible. Thus the software you used for the video recording should work. (Stereo mix may be an exception - not all sound cards actually work when you try to record that content.)
I hope this helps.
Dec 03, 2013 | Televison & Video
How to record live sounds
Plug a monitoring headphone into the monitor socket and try to record if the sounds that you try to record with is working. With an oscilloscope check the recording head is there a sine wave signal if not then the oscillator is kaput record switch operating correctly?what is the age of the tape itself? Was it played back a lot of times? I found this when some tapes refuse to take other recordings when used a lot
It is difficult to say what went wrong if you do not have access to the unit
May 28, 2013 | Technics RS-TR575 Single Dual Cassette...
Grey Lines across video display
Same thing is happening to mine, it's not the minidv because i tried that one on a diffrent camera and it works fine. It's got to be a setting or something. If anyone can figure it out, that would be great.
Sep 01, 2009 | Canon ZR200 Mini DV Digital Camcorder
Images not recording
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
Jan 03, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Sound problem
if ur usung win xp OS U shold restore OS (pgm-accessories-system tool.restore )to back date while it in workinfg fine
Jul 19, 2008 | Edirol UA-4FX External Sound System
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Discs I have recorded I get the disc can neither be played nor recorder, and it erases what I have already and already watched.
I have the same unit. Similar problem but mine does not erase the disc. It says disc error on almost all dvd that are store bought and kicks them out. Will play almost all of the ones I recorded on it and finalized. I must let a disc in it at all times or door will not open. Lots of bad stuff on the net about this unit. It is a lemon! Mine is out of warranty and sony wants $175 to fix. Saw some blogs where it was serviced 3 times and still not right. Buy a new one before investing in the unit you have as there are many gremlins in it! Sorry I cannot offer specific help but this is where I am at!!
Nov 01, 2007 | Sony RDR-GX315 DVD Recorder
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
Samsung SC-D103 Mini DV Digital Camcorder Logo
100 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
