Question about SanDisk Sansa e250 MP3 Player
Wont charge my sandisk e250 mp3 player is having a problem charging . i have it plugged into the charger . i had it hooked up to the computer , and that didnt charge it either . where can i get another battery at ??? i dont want to buy one online , i just want to be able to go to a store .( i live in ft. wayne , indiana ) and get one. please help me.... but even if the battery is dead , when i'm charging it on the computer or on the charger - i should still get some power right ??? how will i know what the problem is??
  • Anonymous Nov 18, 2008
    i have the problem for turn on the mp3 nad i try to charge by computer its result is nothing
  • 8,596 Answers
No one sells the batteries directly in a store. Call Sandisk (they probably don't have any left, either).
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
Computer doesn't notice MP3 player
the requirments are not made. i had the dame problem, just download sansa updater installed, can you help my problem
Sep 25, 2009 | SanDisk Sansa e250 MP3 Player
My sansa 2gb went dead now it wont charge @ all
It's either problem with the player or the charger if you usually charge it when you connect to the computer then it's more likely to be a problem on the player itself and it will have to be replaced ,if it has warranty then return it.
You can also try a different USB cable or USB port.
Sep 23, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 wont charge when plugged into the computer.
Sounds like the internal battery needs to be replaced.
Hope this helps. Good Luck!
Aug 07, 2009 | SanDisk Sansa e250 MP3 Player
My SanDisk Sansa e250 MP3 Player is messed up.
sounds like a defective battery i would consider purchasing a new one, i have the same player ive never had that problem but these players are a bit dickey with computer connections
Apr 06, 2009 | SanDisk Sansa e250 MP3 Player
Charging pro
I believe the cable is the charger. I have an e250 which charges from the computer. Simply connect the player to the computer using the cable, and when the player is detected by the computer - it is charging!
My friend have a different charger though, but she bought it from the store.
Mar 27, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa MP3 Won't charge or come up on computer screen!?
sometimes if the mp3 is very cold or if it has been completely drained from battery it will do that, first try using a charger that you might have for your car, or something that you can charge it from a wall outlet.
Jan 29, 2009 | SanDisk Sansa e250 MP3 Player
Sansa E250 won't turn on after trying to plug it into an an ipod docking station my sansa mp3 player wont turn on or off the only way i can get it on is to plug it in to charge. and i cant take it to work...
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
Jun 27, 2008 | SanDisk Sansa c240 MP3 Player
Sansa MP3 player charges, plays while plugged into wall, but not unplugged.
When you plug it into the wall make sure you turn it off and let it charge all the way before you start using it again. see if that helps
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
53 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
