Question about Matsunichi MF326 MP3 Player
My MS3/WMA Player will not unlock
Despite moving the Hold Button, & generally pressing different combinations of switches, it keeps coming up the saying 'Goodbye' & switching off before I can try anything else.
I've had this some time now & only recently had this problem whichseems very common according to this website.
Posted on Nov 18, 2008
    New Friend:
On the side of the mp3 along side the earpiece socket has a hold button. Slide the hold button the other way then switch it on this will unlock your player
Posted on Dec 15, 2012
In my car an Audio system is fitted (CD MP3/WMA, NS67L0), which also shows the digital time. But the mannual of the same was not provided. My problem is that I can not adjust the time. Can any one solve my...
Press DISPLAY button to show clock
Now press and hold (up arrow) to adjust hours
Press and hold (down arrow) to adjust minutes
To RESET Timer
Press Display button and Random button at the same time
it will increase or decrease to 00 if more or less than 31 minutes.
Aug 02, 2011 | Car Audio & Video
I charged my swimP3 but it won't turn on when disconnected from the computer.
The Swimp3 Player does need to be charged for at least 3 hours for the best experience. Here are some tips that could help solve your problem:
Problem: The player doesn't turn on.
Suggestion: Charge the battery in the player for at least three hours, this will allow it to fully charge. You can charge it by plugging it into the USB port on your computer or by using a USB wall charger (sold separately). If you do choose to use a computer to charge it, be sure your computer is turned on. If there is no power to the computer, then no power is going to the USB port to charge the Swimp3 player.
Additional Tip: The charging answers are in the Green Indicator Light.
If the green light is flashing off and on, then your SwiMP3 player is charging
If the light is solid green, the SwiMP3 player is fully charged
If you have no green light - then it is not receiving a charge - check the connection, make sure its plugged in properly, or check to see that there is power from the computer or USB wall charger.
Problem: I have charged my player, the light is solid green, but no music plays.
Suggestion 1: Have you loaded music onto the player? Try adding a few mp3 or wma files and test it again.
Suggestion 2: If the power is on, you loaded music, clicked the Play button and no music comes out, press and hold the RESET button for 4 seconds. It's kind of like rebooting your computer when it crashes. Many times a simple reset clears up any challenges.
If that doesn't work, then it could be the
* volume
* incompatible files or
* folders
Volume: On some units the factory volume setting is very low.
Solution: Try turning up the volume by pressing and holding the "+" PLUS button. If you click the "+" button it changes the song, pressing and holding the button will actually control the volume. And if its too loud, press and hold the "-" MINUS button to bring the volume back down.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
Authorized Finis Dealer
Get Swimp3 Deals at
May 21, 2010 | Finis Swi MP3 Player
Ipod nano 2gb wont turn off the songs just keep moving from one to another
Try this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Hope this helps you!
Mar 19, 2010 | Apple iPod MP3 Player
How i change caracter's in game, marvel vs street fighter for psx? what are the corret pressing button for change the 2┬░ caracter in game? thank you
For the main mode of this game, switching between characters is not an option, but you can switch between characters in crossover mode, however here are some interesting secrets involving this game.
Playstation only [edit] EX Options To enable EX Options, beat the game once. Then at the title screen, highlight Options, hold playstation-button-select.png, and press playstation-button-start.png.
[edit] Enable the Hidden Helpers To enable Shadow and Sentinel, simply beat the game once. They can be picked by moving to the bottom of the screen and pressing Down when highlighting Iceman or Colossus.
[edit] Play as Hidden Characters To enable a hidden character, simply beat the game with their counterpart. Then follow the instructions to select them.
Beat with Unlock Selection Venom High-Speed Venom Highlight Chun-Li and press Up. War Machine Hyper-Armor War Machine Highlight Zangief and press Up. Morrigan Lilith-Style Morrigan Highlight War Machine and press Down. Mega Man Roll Highlight Mega Man and press Right. Mega Man Magnetic Mega Man Highlight Mega Man, hold playstation-button-select.png, and pick him. Hulk MSH Performance Hulk Highlight Ryu and press Up. Chun-Li Shadow Lady Highlight Gambit and press Down. anybody Onslaught Highlight Wolverine and press Down. [edit] Fight the Hidden Character The requirements have been simplified a lot for the PSX version. Just do the following:
  • Don't lose a round.
  • Don't continue.
  • Don't have a second player join in.
  • Get the following special finishes during the last round:
Team Finishes MSH-Performance Hulk & Sentinel get 3 Hyper Combo, Variable Combination, or Variable Cross finishes. Lilith-Style Morrigan & Shadow get 4 Hyper Combo, Variable Combination, or Variable Cross finishes. Hyper-Armor War Machine & Sentinel get 5 Hyper Combo, Variable Combination, or Variable Cross finishes. Roll & Shadow get 2 Variable Cross finishes, and 3 Hyper Combo, Variable Combination, or Variable Cross finishes. High-Speed Venom & Sentinel get 3 Variable Cross finishes, and 3 Hyper Combo, Variable Combination, or Variable Cross finishes. Shadow Lady & Shadow get 4 Variable Cross finishes, and 2 Hyper Combo, Variable Combination, or Variable Cross finishes. [edit] Use the same character in a team Beat the game once, and you can do teams like Gambit + Gambit.
[edit] Start off in a different mode You can pick Ryu or Zangief and have them start off in their other modes by doing the following:
Mode Method Ken Mode Highlight Ryu, hold playstation-button-select.png, and pick him. Akuma Mode Highlight Ryu, hold playstation-button-start.png, and pick him. Mech Zangief Highlight Zangief, hold playstation-button-select.png, and pick him.
Apr 14, 2009 | Capcom Marvel Super Heroes vs. Street...
It died and now wont turn back on
maybe if you restart your zune?
if so u To restart the Zune device, follow these steps:
Collapse this tableExpand this table 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position. 2. Press and hold the Back button Collapse this imageExpand this image zune_button_back.gifwhile you press the top of the Zune pad.
Mar 25, 2009 | Sony NWZ-E438F Digital Media Player
My kids locked my rca dvd player model rc5220p
The Disc Tray is Locked
If the message “Tray Locked” appears on the screen, the retail lock feature has
been accidentally engaged. To unlock the disc tray you must press and hold a
combination of keys simultaneously:
On the front panel of the DVD Player, press and hold the STOP, ON•OFF and
OPEN•CLOSE buttons for at least 3 seconds.
I forget the password Your player is equipped with a “back-door” unlock sequence. Press and hold
the STOP button on the front of the DVD Player and the STOP button on the
remote control at the same time. (Hold both buttons down at the same time
for at least 3 seconds).
Dec 28, 2008 | Televison & Video
DVD player locked
I had this problem too. I found this solutiong on another web site and it worked. To unlock the dvd player turn on the tv.Get your remote in hand. Press and hold the stop button for the dvd player on the TV/DVD/VCR. Now press the power button on the REMOTE. This will unlock/lock the dvd player.
Mar 17, 2008 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Sandisk c250
To access Recovery Mode:
-Make sure the player is off (if necessary, hold down the power button
for 20 seconds to turn it off)
-Move the hold switch to ON (move to the right towards the record
-Hold the record button.
-Connect the player to the computer.
-Keep holding the record button till the "new hardware is ready for
comes up, then realease the record button.
Dec 07, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Locked dvd tray.
Press and Hold EJECT Button, While UNLOCK Is Displayed :-)
Nov 12, 2007 | Sanyo DVD-7201 DVD Player
Diamond MP3 player Model DSM921SD-1G LECTEUR MP3/WMA PLAYER manufactured March 2006
there should be a hold button on top of the mp3 player...
turn that to OFF, that should solve your problem...
To turn the mp3 on press the play button and wait a couple seconds...
Sep 21, 2007 | Nefertech Diamond MP3 Player
Matsunichi MF326 MP3 Player Logo
156 people viewed this question
Top Matsunichi Audio Players & Recorders Experts
Are you a Matsunichi Audio Player and Recorder Expert? Answer questions, earn points and help others
