How is the best way to get to the coupler on the motor?
The plastick coupler on the motor that makes the tub spin is broken. Do I need to take the top or sides off to get the motor out to replace the coupling. Or is it possible to remove motor from the bottom?
  • Rida Jarrous Nov 17, 2008
    how can i get the coupler out and replace it.
  • phastmac Nov 18, 2008
    Thank you duby 1990.
  • 370 Answers
The simplest way to change a coupler is to take off the washer case. You do this by removing to two screws in the corner of the control panel. depending on the model the screws are on the left and right front or left and right rear. There is only one or two models that dont have screws they hace two clips under the control panels left and right side. After you have taken the screws out or pop the two clips fold the control panel back, unhook the lid switch and pop out the brass case clips. Remove the case. Thats the easiest way. It may take a little longer but it will save you a huge headache.
Posted on Nov 17, 2008
  • Justin Duby
    Justin Duby Nov 18, 2008
    You can take the whole case off by removing the two screws on the front corners of the control panel. Next pop the 2 brass clips that hold the case on, unplug the lidswitch and its off. Taking the case is the easiest. You can do it from the bottom if you want but taking the case off makes your life a lot easier.
Why got noisy sound during spin
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
May 10, 2015 | Washing Machines
Toshiba washing machine aw -9770 s got noisy sound during spin .
Grinding noises
Apr 19, 2015 | Washing Machines
Has become very noisy on spin
Mar 28, 2015 | Washing Machines
Bangs when it spins
usually the sign of a bad transmission spling or tub splines going bad, even a going bad motor coupler, a damaged counter weight.
try these LOUD NOISES IN washing MACHINE;
Mar 17, 2015 | Roper Washing Machines
My samsung top loader washing machine is very noisy while washing
Nov 12, 2014 | Samsung SW62ASP Top Load Washer
Why does my top loader tub work in spin but not wash ?
You have a broken motor coupling. If you look at the motor you will see there is coupler on the end of the the shaft. That coupler is worn out or broken, needs replacing.
Aug 10, 2014 | LG Washing Machines
Viking washer grinding noise on spin cycle
Apr 16, 2014 | Viking Ovens
Top load washer -- no spin during spin cycle
Sounds like you a broken coupler. This is what makes the washer spin. You can check this by leaning the machine back and feeling for a rubber coupler between the motor and transmission. if this part wiggles or is missing replace it, its broke. Another sign of it being broke is rubber under the machine when you tilt it back. If the coupler is ok replace the clutch.
Nov 21, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
